On 2/15/2016 8:16 AM, Eric Greenwell wrote:
kirk.stant wrote on 2/8/2016 9:55 AM: Extra bonus - you get some lift off the fuselage! Maybe this is intended as joke, but the last thing you want is a very low L/D "airfoil" like the fuselage involved in providing any lift. Eric, That's pretty dogmatic. Why do you say so? Thanks! Bob W. |
Perhaps a good rule of thumb while landing with winglets is to land with the same number of winglets you took off with.
This didn't work for the Voyager's round-the-World flight, but most times it does. Jim |
On Mon, 15 Feb 2016 07:16:51 -0800, Eric Greenwell
wrote: Maybe this is intended as joke, but the last thing you want is a very low L/D "airfoil" like the fuselage involved in providing any lift. Depends on the type of glider. An open class ship needs a lot of sideslip while thermalling. I learned that a long time ago from Uli Schwenk, who told me that he learned that from a guy named Klaus Holighaus. Thermalling with the yawstring 30 degrees outwards makes a huge difference in climb performance. Huge. Explanation: The yaw costs a lot of drag due to the "low L/D fuselage" - but it saves even more drag because you barely need any opposite aileron anymore, therefore you get a much better lift distribution (and therefore much less induced drag) on the wing. One other glider that needs a lot of yaw in a thermal: Arcus. Best regards Andreas |
Andreas Maurer wrote on 2/15/2016 2:17 PM:
On Mon, 15 Feb 2016 07:16:51 -0800, Eric Greenwell wrote: Maybe this is intended as joke, but the last thing you want is a very low L/D "airfoil" like the fuselage involved in providing any lift. Depends on the type of glider. An open class ship needs a lot of sideslip while thermalling. I learned that a long time ago from Uli Schwenk, who told me that he learned that from a guy named Klaus Holighaus. Thermalling with the yawstring 30 degrees outwards makes a huge difference in climb performance. Huge. Explanation: The yaw costs a lot of drag due to the "low L/D fuselage" - but it saves even more drag because you barely need any opposite aileron anymore, therefore you get a much better lift distribution (and therefore much less induced drag) on the wing. One other glider that needs a lot of yaw in a thermal: Arcus. I agree there are gliders where that drag would be an acceptable trade-off, but the pilot I was responding to thought it was a "bonus", and it's clearly not that. I am curious about why a 20 meter glider would need a lot of yaw to climb well, when my 18 meter ASH 26E hardly needs any. 20 or 30 degrees would be a poor choice for the 26E, but you say an Arcus needs that much? Is that part of the operating manual for the glider? I would expect the inner winglet to be stalled, and the outer winglet to be producing outward lift. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm http://soaringsafety.org/prevention/...anes-2014A.pdf |
On Monday, February 8, 2016 at 12:55:19 PM UTC-5, kirk.stant wrote:
On Sunday, February 7, 2016 at 6:11:14 PM UTC-6, Martin Gregorie wrote: Doesn't this follow from the fact that the yaw string is a fair distance in front of the wing? Think about it: if the tipwise axis of the wing is exactly aligned with the radius of the turn, which it should be for maximum climb efficiency, the yaw string should also be at right angles to the turn radius but, being a good 2m/6ft or thereabouts in front of the wing, the turn radius it is on is angled forward of the turn radius the wing is on, which therefore makes it point out slightly out. This looks like a slight slip to the pilot. Draw this situation on a piece of paper, but exaggerate the situation by drawing the circle diameter and about twice the wingspan and you'll see what I described. If you redraw the diagram with correctly scaled turn radius and wingspan, the angular difference between the wing radius line and the yaw string radius line will be very small, but this needs to be adjusted because the curved shape of the canopy will amplify the angle of yaw string in a slip. Now Dick Johnson's advice makes perfect sense. Practically, if the yaw string is central or pointing slightly out in a thermal you're doing it right. If its pointing a long way out or to the inside of the turn you're sideslipping while turning and this is hurting your climb rate by generating excessive drag. Martin, I believe this is only part of the answer. You are correct that a perfectly coordinated turn (slip ball in the center) should show some slip if the yaw string is forward of the CG (and conversely, a centered forward mounted yaw string indicates a skidding turn - beware in the pattern!) but there is also the overbanking effect of long wings seeing different local airflow velocity in a turn; this can be countered by holding aileron out of the turn (inefficient and draggy) or by adding a little bit of slip via top rudder. This slightly increases the angle of attack of the lower wing and decreases the angle of attack of the top wing and voila, no overbanking, ailerons are flush and efficient, and you gleefully outclimb the newb with the perfectly aligned yaw string. It's really noticeable in my LS6 (probably due to the dihedral) - it settles into a nice slipping climb with the yaw string off about 10 degrees to the outside, no aileron deflection, and just a touch of top rudder. Extra bonus - you get some lift off the fuselage! (See "String Theory"). Kirk 66 John Coutts, world champion, stated this as well. I had the pleasure of two days dual instruction with him in Minden. His demonstration of this effect convinced me of the benifit of a little top rudder, increasing the angle of attack of the inner wing, while thermaling. |
On Sunday, February 7, 2016 at 3:09:42 PM UTC-7, wrote:
I know this is a silly question, but I was reading an article by Dick Johnson that talked about holding a slight slip while thermally. This article was written before winglets and I was wondering if the same idea applied to gliders with winglets. Also, as for slipping to lose altitude for landing in a glider with winglets, does this place a lot of side load on the winglets. Should you not slip in landing with winglets? Sorry for the questions, but would appreciate any help in this. There are two other considerations: A. The side of the fuselage meeting the airflow in a slight slip produces some lifting force. And: B: A bit of top rudder reduces the back pressure on the stick needed to hold your turn. That reduces the induced drag at the horizontal. So what do you think? Bob |
On Wednesday, February 10, 2016 at 8:03:15 PM UTC-5, Bob Caldwell (BC) wrote:
On Sunday, February 7, 2016 at 3:09:42 PM UTC-7, wrote: I know this is a silly question, but I was reading an article by Dick Johnson that talked about holding a slight slip while thermally. This article was written before winglets and I was wondering if the same idea applied to gliders with winglets. Also, as for slipping to lose altitude for landing in a glider with winglets, does this place a lot of side load on the winglets. Should you not slip in landing with winglets? Sorry for the questions, but would appreciate any help in this. There are two other considerations: A. The side of the fuselage meeting the airflow in a slight slip produces some lifting force. And: B: A bit of top rudder reduces the back pressure on the stick needed to hold your turn. That reduces the induced drag at the horizontal. So what do you think? Bob I think both are a crock of stuff. Lift is better generated by a wing and top rudder only serves to make the turn rate lower than it should be for the bank angle. UH |
On Thursday, February 11, 2016 at 4:09:52 AM UTC+3, wrote:
On Wednesday, February 10, 2016 at 8:03:15 PM UTC-5, Bob Caldwell (BC) wrote: On Sunday, February 7, 2016 at 3:09:42 PM UTC-7, wrote: I know this is a silly question, but I was reading an article by Dick Johnson that talked about holding a slight slip while thermally. This article was written before winglets and I was wondering if the same idea applied to gliders with winglets. Also, as for slipping to lose altitude for landing in a glider with winglets, does this place a lot of side load on the winglets. Should you not slip in landing with winglets? Sorry for the questions, but would appreciate any help in this. There are two other considerations: A. The side of the fuselage meeting the airflow in a slight slip produces some lifting force. And: B: A bit of top rudder reduces the back pressure on the stick needed to hold your turn. That reduces the induced drag at the horizontal. So what do you think? Bob I think both are a crock of stuff. Lift is better generated by a wing and top rudder only serves to make the turn rate lower than it should be for the bank angle. The best LD ratio of the side of a fuselage is not very good, but if it's heading directly into the airflow then the lift is zero but there is still drag, which makes the LD ratio zero. Having just a little bit of yaw giving just a little bit of lift does not significantly affect the drag, so that first little bit of extra lift is for free. |
On Thursday, February 11, 2016 at 4:14:58 AM UTC-5, Bruce Hoult wrote:
On Thursday, February 11, 2016 at 4:09:52 AM UTC+3, wrote: On Wednesday, February 10, 2016 at 8:03:15 PM UTC-5, Bob Caldwell (BC) wrote: On Sunday, February 7, 2016 at 3:09:42 PM UTC-7, wrote: I know this is a silly question, but I was reading an article by Dick Johnson that talked about holding a slight slip while thermally. This article was written before winglets and I was wondering if the same idea applied to gliders with winglets. Also, as for slipping to lose altitude for landing in a glider with winglets, does this place a lot of side load on the winglets. Should you not slip in landing with winglets? Sorry for the questions, but would appreciate any help in this. There are two other considerations: A. The side of the fuselage meeting the airflow in a slight slip produces some lifting force. And: B: A bit of top rudder reduces the back pressure on the stick needed to hold your turn. That reduces the induced drag at the horizontal. So what do you think? Bob I think both are a crock of stuff. Lift is better generated by a wing and top rudder only serves to make the turn rate lower than it should be for the bank angle. The best LD ratio of the side of a fuselage is not very good, but if it's heading directly into the airflow then the lift is zero but there is still drag, which makes the LD ratio zero. Having just a little bit of yaw giving just a little bit of lift does not significantly affect the drag, so that first little bit of extra lift is for free. I suspect that the gliders that seem to benefit for slight slip do so for 2 reasons. First, as mentioned above, is that the slight slip in a glider with a good bit of dihedral will have the force opposing over banking provided without much or any control deflection. Profile drag and spanwise lift distribution benefit a bit. Second is likely related to wing root separation issues which vary a lot from ship to ship. From my simple observation the gliders with larger well developed root fillets seem to be the ones that are not in the group described as benefiting from notable slipping. One guys opinion. UH |
FAA PTS "Slips to Landing" requirement vs No-spoiler landings | kirk.stant | Soaring | 24 | September 15th 09 02:21 AM |
Slow flight and Slips to Landing - Video | [email protected] | Piloting | 3 | February 6th 09 03:55 PM |
Slow flight and Slips to Landing - Video | A Lieberma[_2_] | Owning | 9 | February 4th 09 01:28 AM |
Slow flight and Slips to Landing - Video | [email protected] | Instrument Flight Rules | 0 | January 31st 09 04:39 AM |
slips to landing in PTS | BB | Soaring | 6 | April 17th 07 05:58 AM |
