Buying questions - which plane?
Old July 22nd 05, 12:03 PM
John Doe
"Kyle Boatright" wrote in message
"John Doe" wrote in message
nk.net...
Ok,
First time plane buyer, I've been looking for some time now.
I've narrowed it down to a few, looking for some big picture comments
pro/con on these:
Commanche 250 or 260
Commander 114
Mooney M20J
Socata TB20 Trinidad
Dont' care about purchase price right now, avionics, etc. Looking for
performance/maintenance/operating costs/issues people know of.
We will normally be loaded with myself, wife and son (400lbs) Plus
weekend bags (100lbs max).
My wife wants speed, speed, speed. I'm not as concerned about speed as I
am performance. I need short field performace as one of our primary
fields is a 2500' grass strip at 2000' DA. I'd also like to climb up
into the teens if needed to get over minor w/x.
Any advice would be appreciated.
tks.
How good are the approaches into the grass field? Unless they are pretty
good, it won't be comfortable going into or out of that field in the
Commanche, Commander, or Mooney unless you're fairly light. Even then,
you'll need to be on your game, particularly on landing. I don't know
about the Trinidad.
If I was looking at your mission, I'd be thinking C-182, C-182 RG, or
C-206, if only for the short field performance with a decent load...
KB
KB,
Very good points. I've flown into the field several times and am
comfortable landing. Takeoff, I just need to get off the ground without too
excessive of a ground roll in the summertime. Would like to carry enough
fuel to make a 350nm trip with standard reserves.
Old July 22nd 05, 12:07 PM
John Doe
nk.net...
Ok,
pro/con on these:
Commander 114
Mooney M20J
We will normally be loaded with myself, wife and son (400lbs) Plus weekend
bags (100lbs max).
fields is a 2500' grass strip at 2000' DA. I'd also like to climb up into
One addition: Short field Take off performance desired is to load the plane
with the family (as above) and carry enough fuel for a 350nm trip plus
standard reserves.
tks
Old July 22nd 05, 12:30 PM
John Doe
"Bob Noel" wrote in message
In article et,
"John Doe" wrote:
Ok,
pro/con on these:
A couple of things to consider wrt the Commanche
1) Will you be comfortable with (iirc) one fuel gauge that you
need to switch to each of the four tanks to read?
2) Not a lot of room behind the instrument panel for avionics
(at least that's what my avionics shop told me a number of years
ago)
1) Unless they're known for uncommanded fuel venting or leaks, I don't have
a problem with that. I've done it before in other aircraft.
2) The one I'm looking at is allready completely loaded IFR/GPS/AP. Not
much more I think I could add to it, but it will be something I look at
before I buy.
Thanks.
Old July 22nd 05, 12:32 PM
John Doe
"Thomas Borchert" wrote in message
John,
Well, in that case: Cirrus? Lancair?
I've looked at both of those and a Columbia 400 is at the top of my list,
trust me. Just can't afford the sticker price. I just didn't want folks to
start writing about market prices of used airplanes on this thread.
I was flying XC on Wed and I heard a Lancair on the radio and I had to wipe
the drool off my mouth.
Old July 22nd 05, 12:34 PM
John Doe
"Dave Butler" x@yy wrote in message
I'm a M20J owner and big fan of the model, and it will meet your speed
requirements, but for flying off grass, the field had better be smooth.
The gear doors hang down so low that you're going to munch one the first
time you drop one of the main gear into a small hole.
Thanks Dave, I am too. I've got about 400 hours in Mooneys and always
enjoyed it. I've looked at a couple of M20J and they're in the running.
Old July 22nd 05, 12:36 PM
John Doe
"Maule Driver" wrote in message
. com...
Seems like the 2500' grass is a major gating factor in this one.
Perhaps add a 'Bo to the consideration and definitely the big Cessnas.
The really difficult is to making accurate assessment of your needs and
the priorities. For example, my mission profile has changed considerably
over 8 years as my "primary fields" have too. In retrospect, the only
part of my mission that hasn't changed has been my home field. Everything
else can change and compromises made given the a/c I have.
You're right. The good news is, about 5nm away from the grass strip is a
5500' paved. I sure would like to land on the grass though.
Old July 22nd 05, 05:08 PM
B. Jensen
John Doe wrote:
Ok,
If cost isn't a factor, buy a Cirrus.
BJ
Old July 22nd 05, 05:19 PM
Mark Hansen
On 7/22/2005 09:08, B. Jensen wrote:
John Doe wrote:
Ok,
BJ
English really is a strange language. What I read was that he wanted
to first consider factors other than cost, not that cost wasn't a
factor.
Mark Hansen, PP-ASEL, Instrument Student
Sacramento, CA
Old July 22nd 05, 06:09 PM
Mike Rapoport
"Doug" wrote in message
You seem to want a low wing. Bonanza's do pretty good on rough and
short fields. Mooney's don't. Another piece of advice. Get it equipped
with the avionics you will be happy with. IFR GPS and autopilot.
Upgrading avionics is expensive and you don't get the money back at
sale.
For high wing a Cessna 182 is hard to beat. The RG's do ok on grass.
Gear is an anethema, but if you want to go fast, you need it.
If you are going to go up high, you are going to have to have oxygen
for everyone. Kind of a hassle. Pressurized is the way to go, but it's
BIG bucks. But a pressurized Bonanza would do everything you specify,
if you have the money.
I wasn't aware that there was any such thing as a pressurized Bonanza.
MU-2
Old July 22nd 05, 06:28 PM
Nathan Young
On Fri, 22 Jul 2005 17:09:46 GMT, "Mike Rapoport"
roups.com...
sale.
How about a P-Baron with one engine caged?
Purchase a Info on Purchasing a Plane and Leasing Back to a School pjbphd Piloting 3 August 30th 04 02:10 AM
It sure makes a difference to own your own plane!! Marco Rispoli Piloting 9 June 29th 04 11:15 PM
BUYING PLANE !! jure Aerobatics 0 September 13th 03 01:07 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
