![]() Don't forget the dreaded C clamp that requires two hands to apply to two pieces already requiring two hands to hold in place. Also the uncalibrated torque wrench used to snap off studs that are thoroughly seized in your crankcase. The nibbler that is designed to swell your forearm to a new size while it digests the skin in the web of your hand between the thumb and forefinger. All of the Tools are necessary items in the Post Doctoral course in cussing. I now attract a small crowd when I'm working with my tools. They are thoroughly impressed that I can cuss for 15 minutes without repeating myself. -- Stuart Fields Experimental Helo magazine "Blue" wrote in message u... Bloody Brilliant, cried with laughter.... -- Regards Blue "ORVAL FAIRAIRN" wrote in message news ![]() I got this one from a friend. How true! Thought you might enjoy these. They are RIGHT on the mark! a. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying. b. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...." c. ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age d. PLIERS: Used to round off bolt heads. e. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. f. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. g. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside a wheel hub you're trying to get the bearing race out of. h. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes. i. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper. j. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle. k. TWEEZERS: A tool for removing wood splinters. l. PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack. m. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-do off your boot. n. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit. o. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of bolts and fuel lines you may have forgotten to disconnect. p.CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle. q.AVIATION METAL SNIPS: See hacksaw. r. TROUBLE LIGHT: The home builder's own tanning booth. Sometimes called drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. s.PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads. t.AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last tightened 70 years ago by someone at Ford, and rounds them off. u.PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. v.HOSE CUTTER: A tool used to cut hoses 1/2 inch too short. w.HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit. x.MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats, chrome and plastic parts. |
![]() "Stuart & Kathryn Fields" wrote I now attract a small crowd when I'm working with my tools. They are thoroughly impressed that I can cuss for 15 minutes without repeating myself. ROTFLMAO ! I have to use that line, with your permission! It sounds like me. I recently topped my best, by shooting a air powered roofing nail, all the way through my little finger, on the outside of my fingernail, coming out the middle of the bottom. Ouch! -- Jim in NC |
Morgans wrote: "Stuart & Kathryn Fields" wrote I now attract a small crowd when I'm working with my tools. They are thoroughly impressed that I can cuss for 15 minutes without repeating myself. ROTFLMAO ! I have to use that line, with your permission! It sounds like me. From the trivia page on IMDB for Full Metal Jacket: http://www.imdb.com/title/tt0093058/trivia Former US Marines Drill Instructor R. Lee Ermey was hired as a consultant on how to drill USMC style. He performed a demonstration on videotape in which he yelled obscene insults and abuse for fifteen minutes without stopping, repeating himself, or even flinching - despite being continuously pelted with tennis balls and oranges. Director Stanley Kubrick was so impressed that he cast R. Lee Ermey as Gunnery Sergeant Hartmann. -- John Clear - http://www.clear-prop.org/ |
Shhhhhhh,
You know Marines can't cuss at recruits during boot camp ![]() mommies and daddies may get upset ![]() Patrick student SPL aircraft structural mech "John Clear" wrote in message ... In article , Morgans wrote: "Stuart & Kathryn Fields" wrote I now attract a small crowd when I'm working with my tools. They are thoroughly impressed that I can cuss for 15 minutes without repeating myself. ROTFLMAO ! I have to use that line, with your permission! It sounds like me. From the trivia page on IMDB for Full Metal Jacket: http://www.imdb.com/title/tt0093058/trivia Former US Marines Drill Instructor R. Lee Ermey was hired as a consultant on how to drill USMC style. He performed a demonstration on videotape in which he yelled obscene insults and abuse for fifteen minutes without stopping, repeating himself, or even flinching - despite being continuously pelted with tennis balls and oranges. Director Stanley Kubrick was so impressed that he cast R. Lee Ermey as Gunnery Sergeant Hartmann. -- John Clear - http://www.clear-prop.org/ |
Morgans wrote:
I recently topped my best, by shooting a air powered roofing nail, all the way through my little finger, on the outside of my fingernail, coming out the middle of the bottom. Ouch! Well, if it's time for war stories... My best involved a jigsaw. In a bit of rush, so didn't clamp the work down solidly. The blade (Did I mention that I get extra use out of every blade by using them until they're totally blunt?) snagged, the whole saw jumped so that the blade was about an inch above the work, and, crucially, higher than my thumb. Down it came, through the thumbnail, and out the fleshy part of the thumb. Actually, the worst part was about a week later. The tissue in my thumb was healing into a big lumpy mass, and the doctor decided that liquid nitrogen was the way to get rid of it. Tears to the eyes stuff, that is! |
![]() "Frank van der Hulst" wrote Actually, the worst part was about a week later. The tissue in my thumb was healing into a big lumpy mass, and the doctor decided that liquid nitrogen was the way to get rid of it. Tears to the eyes stuff, that is! Mine healed very nicely; antibiotics right away, and the nail was clean, unlike your blade. I have experienced the LN, for big warts when I was a kid. They would kill the flesh, and turn it black, then it would form a scab and fall off. I hated that doctor. -- Jim in NC |
way through my little finger, on the outside of my fingernail, coming out the middle of the bottom. Ouch! This coming from a "professional" carpenter! :-) |
![]() "john smith" wrote This coming from a "professional" carpenter! :-) Sad, huh? The more familiar you are with something, the more you take it for granted. I jerked a tangled air hose, and the gun and my finger met in mid air. One thing is true, I think. The more you do something, the more likely you are to have a problem with it. If you never use a nail gun, you never will shoot a nail into your finger! :-) -- Jim in NC |
Stuart & Kathryn Fields wrote:
Don't forget the dreaded C clamp that requires two hands to apply to two pieces already requiring two hands to hold in place. Also the uncalibrated torque wrench used to snap off studs that are thoroughly seized in your crankcase. The nibbler that is designed to swell your forearm to a new size while it digests the skin in the web of your hand between the thumb and forefinger. All of the Tools are necessary items in the Post Doctoral course in cussing. I now attract a small crowd when I'm working with my tools. They are thoroughly impressed that I can cuss for 15 minutes without repeating myself. Don't forget the english wheel which is terrific for extracting blood from under one's fingernails. Dan, U.S. Air Force, retired |
Camloc Installation Tools | jls | Home Built | 13 | May 7th 04 05:11 AM |
EAA Chapte Tools | [email protected] | Home Built | 7 | March 8th 04 10:51 PM |
What tools do you take? | Michael Horowitz | Owning | 31 | March 8th 04 02:53 AM |
FS: MORE of my aviation parts, tools, instruments on ebay | Bill Berle | Owning | 0 | January 14th 04 09:40 AM |
Why do you buy Snap-on tools? | Anonymo421 | Home Built | 12 | November 9th 03 09:40 AM |
