It doesn't matter if the airspace around the airport is class C or B it only
matters if the requriements for the approach are met. Usually the hangup is centerline lighting which is expensive to add. I'm sure that the airports with frequent low weather are more likely to have the centerline lighting although many airports in the PNW, including KBFI, do not have it.. I suspect that there is an element of politics in who gets the money. Mike MU-2 "Peter R." wrote in message ... Mike Rapoport wrote: Most Cat II and III approaches are at major airports. One of the requirements is that the runway must have centerline lighting which is generally only found at the largest airports. Could the presence of a CAT II or III approach also be a function of a greater occurrence of low visibility? My home airport, Syracuse (KSYR), has a CAT II ILS, yet it is only a class C airport. During the winter we experience heavy lake effect snow bands off Lake Ontario and I had suspected that this was the reason for a CAT II ILS rather than its size. -- Peter |
oups.com... Is there somewhere I can find out if this airport (KORH) has an appropriate Cat II or Cat III Approach? Generally speaking, you can look at the A/FD information which is usually up-to-date at www.airnav.com. If a Cat II or Cat III ILS approach is not listed, then the airport isn't equipped for Cat II or Cat III approaches (I think lighting and airport markings is the primary criteria). Compare entries for major commercial airports, like KSEA, KLAX, or KLGA, to see what an airport that does have Cat II and Cat III approaches looks like. As far as your original question goes: It is theoretically possible for an airplane to land using a Cat I approach in fog. I don't know the exact cut-off to differentiate between "fog" and "mist", but I doubt the article you're concerned about is actually using an official definition. So, in the colloquial definition of "fog", visibility could be anywhere from as much as a mile, maybe even more, to as low as 0 feet. A Cat I approach isn't sufficient for 0 visibility, but it's plenty for 1 mile (and visibilities lower than that). So...the answer to "can anyone legally land in fog" is "yes", even if the airport has only a Cat I approach. Pete |
As someone who lives in fog and flys in it often, I say yes. Fog is
almost never uniform. The odds of the flight visibility being the same as the tower reported vis is almost zero. Most of the time, I just start to make out the runway lights nearing 100 feet AGL. Once at 100 AGL you can see A LOT more (probably because fog effect slant line vis). Remember you can go down to 100 feet after seeing the rabbit. Its kind of cool to look outside and see nothing but fog but a white electric rabbit running back and forth!! -Robert, Sacramento CA |
Worth trying with a safety pilot while under the hood is to fly your
airplane all the way down a time or two. Full ILS to mins, keep the localizer centered, maintain rate of decent. Sometime when everything is stacked against you you may have to do something like that in real life. It's a confidence builder knowing you can get down in near zero/zero. Mooneys with their low wings tell the pilot when they are a few feet agl. I don't know how a Cessna would feel though. |
If you are really landing 0/0 I would toss out the idea of trying to
flare. The glide slope is good down to 100 feet, after that it does wacky. You would want to get the plane in a nose up attitude and a slow decent rate and just wait for impact. Those of us that fly sea planes were required to do that for our checkride. Berry Scheff wrote about doing this during an ocean crossing flight. -Robert (Mooney owner too) |
In article .com,
"Robert M. Gary" wrote: If you are really landing 0/0 I would toss out the idea of trying to flare. The glide slope is good down to 100 feet, after that it does wacky. eh? For Cat III systems, the glide slope is good all the way to the runway. -- Bob Noel New NHL? what a joke |
![]() Bob Noel wrote: In article .com, "Robert M. Gary" wrote: If you are really landing 0/0 I would toss out the idea of trying to flare. The glide slope is good down to 100 feet, after that it does wacky. eh? For Cat III systems, the glide slope is good all the way to the runway. I think you got lost in the thread. We've not talked about CAT III at all in this part of the thread just flying an ILS down to the ground. If you notice, some other trees from this thread moved off and talked about cat III. You won't find any talk of CAT III going up the chain of my post. |
In article .com,
"Robert M. Gary" wrote: eh? For Cat III systems, the glide slope is good all the way to the runway. I think you got lost in the thread. We've not talked about CAT III at all in this part of the thread just flying an ILS down to the ground. If you notice, some other trees from this thread moved off and talked about cat III. You won't find any talk of CAT III going up the chain of my post. ok. But let me add that a Cat I glideslope could be ok down to runway, but usually isn't. It just won't be flightchecked -- Bob Noel New NHL? what a joke |
Robert M. Gary wrote:
If you are really landing 0/0 I would toss out the idea of trying to flare. The glide slope is good down to 100 feet, after that it does wacky. You would want to get the plane in a nose up attitude and a slow decent rate and just wait for impact. Those of us that fly sea planes were required to do that for our checkride. Berry Scheff wrote about doing this during an ocean crossing flight. -Robert (Mooney owner too) Naw. Autoland systems exchange crab to wing low at 150' AGL and at 50' AGL the throttles come to idle and the aircraft enters Flare. At wheel spin up it changes to "Roll Out" and continues to track the localizer centerline to keep the aircraft on the runway. It makes beautiful landings. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
