Prop pitch cycling?
Old April 24th 06, 03:27 AM posted to rec.aviation.piloting
Default Prop pitch cycling?
"Jim Macklin" wrote in message
news:nqW2g.7077$ZW3.4090@dukeread04...
That's is true, but except for the Beech 18, are there any
HS props on an airplane under 12,500 pounds?
The feathering on the HS is a electrical relay that turns on
a high pressure pump that operates at a pressure above
governor pressure. The Prop is feathered and the pump shuts
off. To unfeather the button is held in so the pump
continues to run and that causes the internal valve to move,
re-routing the oil so it unfeathers.
I wonder many pilots will take this to heart and open their
POH to the systems section?
James H. Macklin
ATP,CFI,A&P
Oh for the simple life of fighters!! :-) I used Hamilton Standard props
quite a lot, but few of them feathered.
The 24D50 on my Mustang didn't feather of course :-) If I remember right,
the pitch range on my prop was something like 42 degrees.
Dudley
Old April 24th 06, 03:29 AM posted to rec.aviation.piloting
news:lqW2g.7075$ZW3.2577@dukeread04...
I look forward to winning the lottery and buying you a
drink.
Hell, unless one of us has to put gas in our cars, we should be able to
afford a bottle of Jack Daniels between us :-)))
Dudley
"Dudley Henriques" wrote in
message
link.net...
| I've done this a few times myself. :-)
| On Usenet, if you underpost someone already in the thread
but NOT the
| original poster, what you post is considered addressed to
the person you
| underposted rather than simply an addition to the general
thread.
| Any general comment should be picked up as a post to the
original poster by
| clicking his/her post for reply. Then the comment appears
referenced to the
| initial question and not the sub poster.
| I did the same thing once and gave a hundred word
"lecture" on how to do a
| slow roll to one of the world's best acro pilots by
accidentally picking him
| up to underpost instead of the initial poster who had
asked about rolls. :-)
| The pilot I gave the lecture to simply gave me a one word
reply "Thanks"
| with a smilie attached :-)
| That get together sounds like fun. I'll bring the bottle!
| Dudley
| "Jim Macklin" wrote
in message
| news:nZT2g.6827$ZW3.3603@dukeread04...
| No, I know that, I just tacked it on the thread for the
| benefit of the others. I think most pilots and many
| mechanics don't really understand these things, judging
by
| the number of twins that feather before the prop lever
gets
| to the gate.
| If I win the lottery, odds 146 million to one, we can
have
| that CFI round table and sell tickets to anyone without
a
| CFI. CFIs can come for free. I'll pay for you and me.
If I
| don't win the lottery, it will have to be in Wichita,
can't
| afford to go elsewhere without the lottery. ;-)'
| James H. Macklin
| ATP,CFI,A&P
| The people think the Constitution protects their rights;
| But government sees it as an obstacle to be overcome.
| some support
| http://www.usdoj.gov/olc/secondamendment2.htm
| See http://www.fija.org/ more about your rights and
duties.
| message
nk.net...
| | If all this was meant for me, I'm pretty sure I just
| might already know
| | these things
| | Dudley Henriques
| | "Jim Macklin"
wrote
| in message
| | news:yZS2g.6789$ZW3.6526@dukeread04...
| | The prop governor controls within a range and should
| hold a
| | steady rpm within that range. When the run-up is
done
| at
| | say, 2400 rpm the prop should be cycled to the
minimum
| rpm
| | and allowed to stabilize for a few seconds to check
that
| the
| | governor is working properly. On a multiengine
airplane
| the
| | prop should be reduced to just outside the feather
| detent
| | and allowed to run for several seconds to be sure
that
| the
| | prop isn't feathering at the minimum governed speed
| [usually
| | 2000 rpm on most piston engines]. If the prop
control
| is
| | not rigged properly the prop will feather too soon.
| Then
| | the prop feather check should be done.
| | Most props have a certain amount of internal leakage
to
| keep
| | warm oil circulating in the prop hub, but several
cycles
| on
| | a cold engine/prop will assure that the prop does
reach
| | proper operating temperatures.
| | In very cold temperatures, I like to vary the rpm
every
| some
| | often to be sure the prop is functioning, but normal
| | internal flow should make this mostly an unneeded
habit.
| | Remember, on a single-engine reducing rpm send oil
to
| the
| | prop and on a multi, reducing rpm/feathering drain
oil
| from
| | the prop.
| | James H. Macklin
| | ATP,CFI,A&P
rights;
overcome.
| | some support
| duties.
in
| | message
ink.net...
| | | "Frode Berg" wrote in
message
| | | Hi!
| | | I was told by my mechanic to only pull the prop
| handle
| | until I could
| | | audibly
| | | hear a slight pitch change to establish that it
was
| | working.
| | | However, the aircraft manual says it should be
| cycled
| | completely, and on a
| | | cold engine three times to make sure oil is
applied
| to
| | the governor, or
| | | the
| | | pitch mechanism.
| | | Can someone elaborate on this?
| | | What is recommended?
| | | Thanks,
| | | Frode
| | | POH rules of course, but aside from that, I always
| liked
| | to exercise a prop
| | | through several cycles, especially when cold, just
to
| get
| | everything nice
| | | and warm and fluid up there.
| | | Dudley Henriques
Old April 24th 06, 04:07 AM posted to rec.aviation.piloting
On Sun, 23 Apr 2006 21:06:12 -0500, "Jim Macklin"
Heh. I typically "cycled" a freshly o-hauled HS to feather and back
static, then started the engine and function-checked it after
installation.
Got really busy one afternoon/evening, cycled the prop, but didn't get
the test run in. Aircraft in question got dispatched on a last minute
run-and I got a phone call @ 3:00 am.
Line guy hopped up on the wing and topped off the oil tank (to
replace what I had pumped into the engine). When the plane arrived at
its destination, the pilot attempted to check the oil-took the cap
off, oil started running out, cap back on, called home and asked for
help.
Was also a really pretty fan-shaped spray pattern of oil on the ramp
where the run-up was done prior to the first departure.
In this forum, probably quite a few.
TC
Old April 24th 06, 06:19 AM posted to rec.aviation.piloting
Sounds good. Right now I'm trying some cheap brandy, but
Jack is awfully good. I don't drink much, maybe one once a
week now. But I'm going to have one tonight, a toast to all
the WWII pilots, to Scott Crossfield, to Dale Earnhardt and
to Tiger Woods dad. And all the troops in harm's way.
James H. Macklin
ATP,CFI,A&P
some support
message
nk.net...
| "Jim Macklin" wrote
in message
| drink.
| Jim
should be able to
| Dudley
| message
link.net...
thread
| but NOT the
to
| the person you
general
| thread.
| original poster by
appears
| referenced to the
word
| reply "Thanks"
bottle!
| | Dudley
| | "Jim Macklin"
wrote
| in message
judging
| by
lever
| gets
| | to the gate.
can
| have
without
| a
me.
| If I
Wichita,
| can't
| | James H. Macklin
| | ATP,CFI,A&P
rights;
overcome.
| | some support
| duties.
in
| | message
nk.net...
just
| | might already know
| | | these things
| | | Dudley Henriques
| | | "Jim Macklin"
| wrote
| | in message
should
| | hold a
is
| done
| | at
| minimum
| | rpm
check
| that
| | the
| airplane
| | the
feather
| | detent
sure
| that
| | the
speed
| | [usually
| control
| | is
soon.
| | Then
leakage
| to
| | keep
several
| cycles
| | on
does
| reach
rpm
| every
| | some
normal
unneeded
| habit.
oil
| to
| | the
drain
| oil
| | from
| | | the prop.
| | | James H. Macklin
| | | ATP,CFI,A&P
| rights;
| overcome.
| | | some support
and
| | duties.
| | | "Dudley Henriques"
wrote
| in
| | | message
ink.net...
| message
| | | | Hi!
prop
| | handle
| | | until I could
| | | | audibly
it
| was
| | | working.
be
| | cycled
| applied
| | to
| | | the governor, or
| | | | the
| | | | pitch mechanism.
| | | | Thanks,
| | | | Frode
always
| | liked
| | | to exercise a prop
just
| to
| | get
| | | everything nice
| | | | Dudley Henriques
Old April 24th 06, 01:21 PM posted to rec.aviation.piloting
Jim Macklin wrote
But if you are
flying a multiengine aircraft in cold weather and shut an
engine down in training including feathering, the oil may
congeal to the point the prop won't unfeather. So ME CFI be
careful what and where you practice.
That is true of course unless you happen to be flying a big
turboprop that uses something similiar to hydraulic oil for
its prop control mechanism. We routinely shutdown (feathered)
numbers 1 and 4 for endurance purposes.
Bob Moore Allison T-56 operator
Old April 24th 06, 04:06 PM posted to rec.aviation.piloting
Skydrol and similar are great. Turbine oil is also mostly
synthetic and doesn't congeal. But most people don't fly C
130s and hang out here, in rec.piloting.
Most ME training is done in a piston powered light twin with
petroleum based engine oil shared by the prop.
James H. Macklin
ATP,CFI,A&P
some support
"Bob Moore" wrote in message
. 121...
| Jim Macklin wrote
| But if you are
an
may
CFI be
big
for
(feathered)
Old April 24th 06, 11:19 PM posted to rec.aviation.piloting
Jim & Dudley, I've a question I've been meaning to ask.
The prop governor controls within a range and should hold a
steady rpm within that range. When the run-up is done at
say, 2400 rpm the prop should be cycled to the minimum rpm
and allowed to stabilize for a few seconds to check that the
governor is working properly. On a multiengine airplane the
prop should be reduced to just outside the feather detent
and allowed to run for several seconds to be sure that the
prop isn't feathering at the minimum governed speed [usually
What is the minimum governed speed on a constant speed prop?
It has been my experience that below 1200-1400 rpm someplace, a C/s prop
will no longer cycle. In a glide, the RPM is generally below that. In
another thread, some time ago, you(Jim) mentioned that to get the best glide
out of a single engine(without the engine), one should pull the prop control
out fully. I have tried this in a Mooney 201, and could not make the RPM
change a bit, (Power off, best glide).
Have any of you ever been able in influence a glide with the prop
control?
Al
Old April 24th 06, 11:50 PM posted to rec.aviation.piloting
On the C-182 I have always been told to cycle 3 time just enough for a 200 rpm
drop. This verifies it is working and the oil is flowing.
Ron
Frode Berg wrote:
Hi!
I was told by my mechanic to only pull the prop handle until I could audibly
hear a slight pitch change to establish that it was working.
However, the aircraft manual says it should be cycled completely, and on a
cold engine three times to make sure oil is applied to the governor, or the
pitch mechanism.
Frode
Old April 25th 06, 12:23 AM posted to rec.aviation.piloting
But did you notice a change in rate of descent when you
repositioned the prop? The rpm may not change but it should
change the blade angle and thus the drag.
James H. Macklin
ATP,CFI,A&P
"Al" wrote in message
| "Jim Macklin" wrote
in message
hold a
at
rpm
detent
[usually
prop?
below that. In
get the best glide
not make the RPM
with the prop
| control?
| Al
Old April 25th 06, 02:16 AM posted to rec.aviation.piloting
Hi Al;
May I refer you to an article written by John Deakin. John has written an
excellent explanation for exactly what you are asking about here.
http://www.avweb.com/news/columns/182082-1.html
All the best,
Dudley
prop will no longer cycle. In a glide, the RPM is generally below that.
In another thread, some time ago, you(Jim) mentioned that to get the best
glide out of a single engine(without the engine), one should pull the prop
control out fully. I have tried this in a Mooney 201, and could not make
the RPM change a bit, (Power off, best glide).
control?
Al
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 11th 03 11:42 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
