ATC is required to call the regional office and log the event whenever a
for hire aircraft does something unusual, such as aborting a takeoff. Reporting that their DG is busted and then cancelling does not meet that requirement. At the facilities I've worked at we would never call FSDO or the regional office because of what you said. Andrew Gideon wrote: One of our club aircraft was recently on an IFR flight plan in VMC. The instrument student and his instructor noted that the DG was precessing excessively. They eventually canceled the flight plan and returned to their point of origin VFR. In canceling with ATC, they mentioned something about the DG having a problem. Later that day, the club received a call from the FSDO about the "vacuum failure" experienced by one of our aircraft. I've since chatted with the [nice] fellow from the FSDO myself (as one of the people involved in aircraft maintenance in the club). He explained that this was a part of a long-standing policy. Equipment failures that are reported to ATC are reported by ATC to the local FSDO. The FSDO checks into this, confirming that the problem was "resolved" by a mechanic before the aircraft flies again. The example he used was that of an RG with a flickering gear light. Assume the pilot reports the light to the tower. Further assume that the landing is uneventful (ie. the gear holds) and the flickering stops after landing. In this case, the FSDO is going to check that the aircraft received maintenance before it was flown again. I asked about the case where the above landing occurred at a field w/o services. He said that a mechanic should be brought in before the plane is flown to confirm that the gear is down and locked. There was a significant level of ambiguity in what I was told. He mentioned several times in the explanation that part of the trigger in the case of our aircraft was cancellation of the flight plan. I pointed out that I'd canceled IFR flight plans plenty of times. He then said that the difference was that my cancellations were typically when starting a visual approach to my intended airport, and the event under discussion involved an airplane not reaching its original destination. I pointed out that, once I was VFR, nobody knows where I land. He agreed with a little confusion. I know that the FAA has an interest in assuring that aircraft with problems are repaired. So do pilots. But I have never heard of this before. I wonder how well this long-standing policy handles subtleties like a VFR flight in an aircraft with a too-quickly precessing DG. And what are the possible sanctions? I was a little afraid to ask about that last point laugh. Is anyone familiar with this policy? I'd love to see some of the gaps filled in. Thanks... Andrew http://flyingclub.org/ |
On Wed, 26 Jul 2006 15:37:51 -0600, Newps wrote:
for hire aircraft The situation that brought this to my attention involved a club aircraft, but there was an instructor on board instructing. I cannot imagine how TRACON would know about that, but - had they - would that cross the "for hire" threshold such that you'd have to report an equipment problem? Or do you mean something like a 135 or 121 flight? - Andrew |
![]() Andrew Gideon wrote: On Wed, 26 Jul 2006 15:37:51 -0600, Newps wrote: for hire aircraft The situation that brought this to my attention involved a club aircraft, but there was an instructor on board instructing. I cannot imagine how TRACON would know about that, but - had they - would that cross the "for hire" threshold such that you'd have to report an equipment problem? Or do you mean something like a 135 or 121 flight? Yes, part 121 or 135. |
But I have never heard of this before. I wonder how well this long-standing policy handles subtleties like a VFR flight in an aircraft with a too-quickly precessing DG. And what are the possible sanctions? I can tell you I've told ATC of a number of problems while VFR (some within class B) and never heard anything about it including: 1. inoperative transponder 2. total electrical failure 3. smell of smoke in the cockpit 4. plugged static system |
On Wed, 26 Jul 2006 15:43:08 -0400, Andrew Gideon
wrote: One of our club aircraft was recently on an IFR flight plan in VMC. The instrument student and his instructor noted that the DG was precessing excessively. They eventually canceled the flight plan and returned to their point of origin VFR. In canceling with ATC, they mentioned something about the DG having a problem. Later that day, the club received a call from the FSDO about the "vacuum failure" experienced by one of our aircraft. I've since chatted with the [nice] fellow from the FSDO myself (as one of the people involved in aircraft maintenance in the club). He explained that this was a part of a long-standing policy. Equipment failures that are reported to ATC are reported by ATC to the local FSDO. The FSDO checks into this, confirming that the problem was "resolved" by a mechanic before the aircraft flies again. The example he used was that of an RG with a flickering gear light. Assume the pilot reports the light to the tower. Further assume that the landing is uneventful (ie. the gear holds) and the flickering stops after landing. In this case, the FSDO is going to check that the aircraft received maintenance before it was flown again. I asked about the case where the above landing occurred at a field w/o services. He said that a mechanic should be brought in before the plane is flown to confirm that the gear is down and locked. There was a significant level of ambiguity in what I was told. He mentioned several times in the explanation that part of the trigger in the case of our aircraft was cancellation of the flight plan. I pointed out that I'd canceled IFR flight plans plenty of times. He then said that the difference was that my cancellations were typically when starting a visual approach to my intended airport, and the event under discussion involved an airplane not reaching its original destination. I pointed out that, once I was VFR, nobody knows where I land. He agreed with a little confusion. I know that the FAA has an interest in assuring that aircraft with problems are repaired. So do pilots. But I have never heard of this before. I wonder how well this long-standing policy handles subtleties like a VFR flight in an aircraft with a too-quickly precessing DG. And what are the possible sanctions? I was a little afraid to ask about that last point laugh. Is anyone familiar with this policy? I'd love to see some of the gaps filled in. Thanks... Andrew http://flyingclub.org/ I used to never have FSDO follow-up (and I've been flying for about 35 years). One year I had to replace five generators. I've had in-flight vacuum failures. I've declared emergencies for a variety of other equipment issues over the years with never a call from ATC. About a year ago, I declared an emergency and landed about twenty minutes after takeoff because of a fluctuating oil pressure indication. Troubleshooting revealed a blown Garlock seal on an oil scavenger pump. It was repaired. I received a followup call from FSDO (Portland, ME). I asked and was told that the reporting and followup had been "policy" for years. Needless to say the answer did not make sense to me in light of my previous experiences. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
IFR use of handheld GPS | [email protected] | Instrument Flight Rules | 251 | May 19th 06 02:04 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
