#11
"Roy Smith" wrote in message
... What I would have done in that situation was to read back, "Understand I'm cleared into the Class Bravo". When I'm in that situation, I prefer "Confirm cleared into Class Bravo", to make it explicit that I'm requesting a response. --Gary |
"mvgossman" wrote in message ups.com... I have a question that I am curious about having stumped several CFIs locally. I'm flying from my home base, St. Cloud, Minnesota, to St. Paul Downtown Airport. Pull out your Twin Cities sectional if you have one... Along the way my son and I are going to do some sightseeing over the State Fairgrounds. The MSP class B airspace is 100/70, 100/40, 100/30, 100/23, and 100/SFC. The fairgrounds are just outside the inner surface ring. The terrain is around 1000 ft MSL and some significant towers in the area also. I would rather stay at 2500 which would place me inside Bravo of the 100/23 ring over the Fairgrounds. Complicating matters are two class D areas, virtually touching, at [34] between St. Cloud and the Fairgrounds. So I am VFR, flying to the southeast at 5500, I speak to approach and ask for direct to the Fairgrounds for sightseeing with clearance to enter class B. That is denied but I am advised to continue, maintain 3000. As I get close to the class D at [34], but still under the 100/40 shelf pf course, I point out that I will need to speak to Anoka Class D to traverse their airspace unless Approach can get me clearance. They told me to maintain 3000 "and you'll be OK". By this I assume they meant "no traffic in the class D area at that altitude" but I was unsure. Having faith they were not out to get me, I complied and remained at 3000, bored through the upper reaches of Anoka's Class D. I was next to enter the 100/30 ring at 3000. I have always understood that 100/30 means inclusive so I advised approach I would either need lower or a clearance to enter Bravo. I was told "Stay at 3000 and you'll be OK." No "cleared to enter Bravo" magic words, so I said "how about 2800 to remain clear of Bravo?" and clearance for this was granted. Next I was to enter the 100/23 ring so I advised approach "In order to maintain terrain and obstacle clearance, I'll between 2500 and 2800 and clearance to enter class Bravo over the Fairgrounds". I was switched to the tower frequency and given clearance to enter Bravo and advised to stay northeast of the active runways, and after a few circles, on to STP. So all's well that ends well, but: 1. Can Approach grant clearance to go thru intervening class D when VFR? I am accustomed to this as a matter of routine when IFR but I do not know about VFR. There are no clearances to transit Class D airspace while VFR. If you're receiving flight following the radar controller is required to coordinate your transition with the tower. You are not expected to do it yourself. 2. Why was I given in effect "permission", but no clearance, to enter class Bravo at 3000, therefore permission to bust class Bravo and potentially get cited? Is it conceivable that a controller would be so sadistic as to send a place through Bravo without clearance and then bust them? I'd make "cleared to enter Class B airspace" part of my readback. If the intent was to deny entry he'll have to correct the readback, if he doesn't correct the readback I have a clearance. |
The response was something like "both requests approved as requested" ...
No "cleared". Yet I felt that there was sufficient clarity in the approval of my request. Should I drag out and send in a NASA form? Yes. I agree there was sufficient clarity. However, if the FAA is willing to bust people who don't hear "cleared" (or is willing to allow such a rumor to circulate unchallenged) then they have to give us the correct wording. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
"Jose" wrote in message . com... I believe so. What they do is "coordinate" with the tower under letters of agreement that the pilot has no access to. But if they drop the ball, it's your problem. Negative. If they drop the ball it's the radar controller's problem. FAA Order 7110.65R Air Traffic Control Chapter 2. General Control Section 1. General 2-1-16. SURFACE AREAS b. Coordinate with the appropriate control tower for transit authorization when you are providing radar traffic advisory service to an aircraft that will enter another facility's airspace. NOTE- The pilot is not expected to obtain his/her own authorization through each area when in contact with a radar facility. |
"Roy Smith" wrote in message ... You weren't. Unless you hear "cleared into the class bravo", you're not. Odd, then, that that phrase appears nowhere in Part 91. |
link.net... You weren't. Unless you hear "cleared into the class bravo", you're not. Odd, then, that that phrase appears nowhere in Part 91. What other clearance would VFR traffic get that would allow them to enter the Class B airspace? I'm drawing a blank at the moment. I agree that the specific phraseology is not required. But *some* kind of clearance is required, and that is stated in the FARs. I doubt VFR traffic is going to get a landing clearance while still outside the Class B, and I'm hard-pressed to think of another one that would be applicable to VFR traffic. Pete |
On Tue, 24 Oct 2006 20:27:03 -0400, Roy Smith wrote:
In article , Andrew Gideon wrote: Should I drag out and send in a NASA form? Depends. Do you think you violated some FAR? You don't need to have violated any rules to file an ASRS report. The idea of the system is to gather data on safety issues. Immunity is just a bonus to encourage reports. If you think that an unsafe condition exists, feel free to tell about it, regardless of whether you think you're on the hook. Data submitted when you've done everything right are just as useful as data submitted when you've screwed up. Don't worry that the safety issue isn't serious enough, let the NASA analysts worry about that. The report costs nothing (well, postage), might protect you from FAA action, and might help make the system safer. It's a win/win. If you're worried that you need to file a NASA ASRS report, then why not just do it and get some sleep? http://asrs.arc.nasa.gov/ Has anyone tried the electronic filing yet? If so, how about a pirep? RK Henry |
In article .net,
"Steven P. McNicoll" wrote: "Roy Smith" wrote in message ... You weren't. Unless you hear "cleared into the class bravo", you're not. Odd, then, that that phrase appears nowhere in Part 91. You're picking nits, as you always do. The wording in part 91 is "The operator must receive an ATC clearance from the ATC facility having jurisdiction for that area before operating an aircraft in that area." It does not say that you must hear the particular phrase "cleared into the class bravo". It just says that you need "an ATC clearance". That could be an IFR clearance ("cleared to the Gopher VOR 150 radial 12 DME fix, via radar vectors, maintain 3000"). In response to a request for a class bravo clearance, it could be "Cleared as requested". The real magic word is "cleared". The most common thing a controller will say is "cleared into the class bravo". That's what you want to hear. Variations on the theme are OK, as long as they include the word "cleared". What's not OK are things like "approved as requested", "proceed", or the wonderfully vague "You'll be OK" that the OP reports having heard. Nowhere in Part 91 does it say, "The operator must be told that they'll be OK". |
Nomen Nescio wrote:
You folks can be awfully anal, sometimes. It comes from working with an agency who's main goal in life seems to be ramming uncomfortable objects up your ass. |
On Wed, 25 Oct 2006 05:40:03 +0200 (CEST), Nomen Nescio
wrote in : You folks can be awfully anal, sometimes. I would have gone with......... "Yea, go for it" "You got it, Pal" or "Sure, why the hell not" That would explain why you hide behind an anonymous news server. Have you ever stopped to consider that these are matters of life and death? Anyone who is so flippant as you has no place acting as Pilot In Command. |
| Thread Tools | |
| Display Modes | |
