#11
There is the chance that the parachute will ice up itself; when deployed
in icing conditions. If long enough(duration) in icing conditions there is a risk of collapse. Of course it will deploy but it is not made to collect ice and function properly. unicate wrote: can't see who wrote this: Maybe I am too dense but if icing conditions were forecast as likely doesn't it make sense to AVOID the ice in the first place? The parachute should not be a substitute for proper flight planning and judgement. Maybe this is a dumb question, but I heard someone say if the plane can't fly because of icing, the parachute won't work because of the icing, either. I'm not a skydiver or scientist ... is that true? Is a parachute of no value when there's icing? |
The Visitor wrote:
There is the chance that the parachute will ice up itself; when deployed in icing conditions. If long enough(duration) in icing conditions there is a risk of collapse. Of course it will deploy but it is not made to collect ice and function properly. Thank you. That was my question ... not whether or not a parachute could sustain an airplane with ice, but whether or not a parachute itself is susceptible to ice and resulting failure. |
On Sat, 28 Oct 2006 11:11:57 -0700, unicate wrote:
The Visitor wrote: There is the chance that the parachute will ice up itself; when deployed in icing conditions. If long enough(duration) in icing conditions there is a risk of collapse. Of course it will deploy but it is not made to collect ice and function properly. Thank you. That was my question ... not whether or not a parachute could sustain an airplane with ice, but whether or not a parachute itself is susceptible to ice and resulting failure. http://fl250.blogspot.com/2006_01_01_fl250_archive.html Check the "Craziest Pirep Ever" section. |
"Peter Clark" wrote in message
... On Sat, 28 Oct 2006 11:11:57 -0700, unicate wrote: The Visitor wrote: There is the chance that the parachute will ice up itself; when deployed in icing conditions. If long enough(duration) in icing conditions there is a risk of collapse. Of course it will deploy but it is not made to collect ice and function properly. Thank you. That was my question ... not whether or not a parachute could sustain an airplane with ice, but whether or not a parachute itself is susceptible to ice and resulting failure. http://fl250.blogspot.com/2006_01_01_fl250_archive.html Check the "Craziest Pirep Ever" section. Isn't there a difference between known icing, forecast probable icing, and forecast possible icing--in addition to the severity of said conditions? Peter |
![]() wrote in message ... The Visitor wrote: There is the chance that the parachute will ice up itself; when deployed in icing conditions. If long enough(duration) in icing conditions there is a risk of collapse. Of course it will deploy but it is not made to collect ice and function properly. Thank you. That was my question ... not whether or not a parachute could sustain an airplane with ice, but whether or not a parachute itself is susceptible to ice and resulting failure. Bogus answers. The amount of time under chute is brief, and significant icing would not be likely in that amount of time. Even if ice did build up somewhat, this is not an airfoil parachute, like some skydivers use, so performance degradation would be minimal, most likely. The real answer is that the parachute has not been tested to not tear away, at deployment speeds above 133 knots (I think, but that is close) so there is some question at what speed it would tear away. Your are a test pilot at speeds above the maximum tested speed, but it might hold and save you at speeds higher than that. The fact that icing was significant would mean that the plane has to fly faster to stay in the air without stalling, so it might not have been possible to slow down enough to get under the deployment speed. It seems like a intentional flat spin would slow you down enough, to me, but that is just an idea. The real rub is that because a totaled airplane is likely to be the result of deployment, and saving your life is not guaranteed, so a pilot is liable to try to fly it down and land, and if the plane stalls and spins in at too low of an altitude, there is no time for the chute to save you. This is a possible scenario in this accident. We don't know why he flew into the icing. It is obviously best not to fly into icing, thinking the chute will save you. Anything after that is a gamble. -- Jim in NC |
"Peter Dohm" wrote:
Isn't there a difference between known icing, forecast probable icing, and forecast possible icing--in addition to the severity of said conditions? Peter Not to me. I won't fly anywhere near any of those. Ron Lee |
Peter Clark wrote:
On Sat, 28 Oct 2006 11:11:57 -0700, unicate wrote: Thank you. That was my question ... not whether or not a parachute could sustain an airplane with ice, but whether or not a parachute itself is susceptible to ice and resulting failure. http://fl250.blogspot.com/2006_01_01_fl250_archive.html Check the "Craziest Pirep Ever" section. I searched the NTSB database for non-fatal Cirrus accidents that mentioned icing and this looks like it may be the report for the above mentioned accident: http://www.ntsb.gov/ntsb/brief.asp?e...18X00086&key=1 The narrative makes it clear the pilot had gonzo amounts of experience, yet seemed oblivious to the on-board XM Satellite Radio AIRMET updates and relied on weather reports that were out-of-date when he departed. This pilot doesn't fit the alleged pattern of low-time but financially well-off pilot that people are accusing Cirrus of marketing their product. |
and forecast possible icing--in addition to the severity of said conditions? Peter Not to me. I won't fly anywhere near any of those. Ron Lee I should have been a bit more thorough in my post. The question as asked was regulatory; but I had neglected to ask whether the icing conditions became known as a result of the Cirrus pilot's pirep. A search revealed that the icing conditions were predicted by the NWS, although transmitted in a manner other than expected, and previously known to ATC. All in all, I was left with more questions than answers and much food for thought. Peter |
On Sun, 29 Oct 2006 04:37:18 -0000, Jim Logajan
wrote: Peter Clark wrote: On Sat, 28 Oct 2006 11:11:57 -0700, unicate wrote: Thank you. That was my question ... not whether or not a parachute could sustain an airplane with ice, but whether or not a parachute itself is susceptible to ice and resulting failure. http://fl250.blogspot.com/2006_01_01_fl250_archive.html Check the "Craziest Pirep Ever" section. I searched the NTSB database for non-fatal Cirrus accidents that mentioned icing and this looks like it may be the report for the above mentioned accident: http://www.ntsb.gov/ntsb/brief.asp?e...18X00086&key=1 The narrative makes it clear the pilot had gonzo amounts of experience, yet seemed oblivious to the on-board XM Satellite Radio AIRMET updates and relied on weather reports that were out-of-date when he departed. This pilot doesn't fit the alleged pattern of low-time but financially well-off pilot that people are accusing Cirrus of marketing their product. Just for the record, I was only addressing the question of whether a parachute would deal with being pulled in icing and getting the aircraft back down in one piece, I'm not going anywhere near the marketing debate. And of course we now have a sample of exactly one where it's known that there was severe icing and a chute was popped - who knows if the next one would be as successful... |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Aviation crash videos on-line | Dudley Henriques | Piloting | 113 | September 12th 04 08:54 PM |
Aviation crash videos on-line | F.L. Whiteley | Military Aviation | 110 | September 9th 04 07:51 PM |
Crash involved veteran Navy airmen | Otis Willie | Naval Aviation | 0 | August 2nd 03 10:49 PM |
