Flying Video...
Old January 4th 07, 02:20 AM posted to rec.aviation.piloting
Morgans[_2_]
Default Flying Video...
ps.com...
As you guys know a few weeks ago I was messing with putting a camera
into the plane... so I did, and recorded my flight on new years day
from Honolulu to Lana'i.
I still have to tweek the filter setup as the lighting didn't work out
perfectly. Also I need to work out a way to stabilize it a bit more,
because regardless of how soft I land it gives it a nice shake at
touchdown... (don't mind the wheel shimmy)
http://www.youtube.com/watch?v=vyals4jYJBM
I like it.
Some suggestions.
Less panel, move the camera off center, so the #&*$ magnetic compass isn't
dead in the middle of where you are going. Also, if possible, put the
sunvisor up on both sides. Wear a ball cap to keep the sun out of your
eyes, if that is needed.
Definitely get the headset audio onto the tape. I suggest a quick and easy
fix of putting a small mic under your headset.
Old January 4th 07, 04:01 AM posted to rec.aviation.piloting
Unfortunatley my camera is too cheap to have an audio-in hook-up.
Old January 4th 07, 04:16 AM posted to rec.aviation.piloting
John T
ups.com
Maybe it's worth getting a voice recorder and dubbing in the audio during
post-processing? Some folks actually prefer the mix of prop/wind noise with
the clear capture of voice/radio audio.
John T
http://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://openspf.org
____________________
Old January 4th 07, 05:57 AM posted to rec.aviation.piloting
Bravo Two Zero
During ground movement is it not more advisable to be watching out the
windows rather that turning knobs on the center panel ?
"Morgans" wrote in message
ps.com...
I like it.
Some suggestions.
easy fix of putting a small mic under your headset.
Old January 4th 07, 07:24 AM posted to rec.aviation.piloting
Morgans[_2_]
ps.com...
easy
Lash up a speaker to plug into the intercom or wherever you passenger would
be pluged in, or add a Y to your speaker output, then mount that speaker
over the camera mic with ductape or rubber bands, or something. It will
take some experimenting, but it will make the difference between droning
engine noise and air noise, and hearing what is going on with ATC plus
whatever other narration you want to add. All the difference in the world,
IMHO.
Another choice is to tape record the intercom, then add a slapstick at the
start of the tape to sync the sound and movie, then learn how to post edit
with a sound-over dubbing program.
I would go for the lash-up with the speaker, or take the camera apart and
add a mic input. That isn't too tough, either.
Old January 4th 07, 07:34 AM posted to rec.aviation.piloting
Morgans[_2_]
isn't dead in the middle of where you are going. Also, if possible, put
the sunvisor up on both sides. Wear a ball cap to keep the sun out of
your eyes, if that is needed.
Where did I advise turning knobs, or what in my suggestions would require
turning knobs?
If you decided that from watching the video, you should reply to his post
where he first gave out the video link, not to my post.
Old January 4th 07, 02:00 PM posted to rec.aviation.piloting
Stefan
Wouldn't change much with those sunvisors obsucuring his view anyway.
But then, I didn't see him look over the shoulder before initiating a
turn, either.
Stefan
Old January 5th 07, 03:30 AM posted to rec.aviation.piloting
Bravo Two Zero
Sorry Man...
turning knobs?
Flying and capturing video drclive Piloting 6 August 13th 06 09:25 PM
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Piloting 365 March 16th 06 01:15 AM
the thrill of flying interview is here! Dudley Henriques Piloting 0 October 21st 03 07:41 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
