#11
just noticed you are in florida. I have the bugee replacement tool and the
gear load check adapter at my hanger at FMY if you need to borrow for an inspection. R. burns "comanche driver" spamawayassh.ole wrote in message . .. just a couple of quick things to check first. check the gear trunion pins- ad on thoses they crack. check logs for dye inspection, repeditive, or replacement with webco units, non repetitive. check gear bungee arms they crack also, no ad but ad on bungees. check main gear castings at the web, they crack there also. check tension on the push-pull gear cables, need a adapter most twinco owners will have one or were to get one, they are easy to make the drawing is in the service manual. if they are dragging to much the need to be replaced, they are available but not cheap to replace. check fuel valves for leaks and screens for corrosion, also part of a AD. check rear bulkhead for cracks and horizonal bearings for play. also AD those are the biggest things right off the top of my head for the twinco check the ad list there are a few repetitive AD's R. burns PA30 N31952 "Jim Burns" wrote in message ... There are many things to think about when buying an airplane but a couple that concern airframes a 1: you can't make it younger 2: you can't make it straighter (reasonably) Money can fix just about everything else, but no amount will never roll back the TTAF meter. As the fleet of GA airplanes gets older there are more and more airplanes approaching 9000+ hours, so the question becomes with all things considered, how much of an effect does the high time have on this airplane's value? The TwinCo is not so rare a bird that there aren't or won't be other comparative examples on the market with lower total airframe times, even if they have slightly higher asking prices. If you look around it's normally easy to find older twins advertised for no more than the value of their engines, props, and radios but even in these instances they often have much less than 9000 hours TT. Jim "E Andersen" wrote in message ... On a twin of that age and advertised at that sale price, I would set aside NO LESS than an additional 50% for additional repair and maintenance that you may incur during your first year of ownership. yeah, I am aware of that, I was more concerned about the airframe, 9000 hours sounds like a lot, I dont know |
![]() "comanche driver" spamawayassh.ole wrote in message . .. just noticed you are in florida. I have the bugee replacement tool and the gear load check adapter at my hanger at FMY if you need to borrow for an inspection. R. burns Hi that sounds really good. I am a bit vary about the comanche, looks like its the same guy at "the local airfield" that have done service for a long time, I think I'm gonna pass on this one and look at another instead, or maybe a nice seneca. Erik |
Hi
the more I look into it, the more I keep returning to the comanche, it must be the fastest small twin and at the same time very economical, how can that go wrong :-) I might go and have a look at this one http://www.schomeraircraftcenter.com/inventory5.htm during the week, does anyone know this particular aircraft? Erik check the gear trunion pins- ad on thoses they crack. check logs for dye inspection, repeditive, or replacement with webco units, non repetitive. check gear bungee arms they crack also, no ad but ad on bungees. check main gear castings at the web, they crack there also. check tension on the push-pull gear cables, need a adapter most twinco owners will have one or were to get one, they are easy to make the drawing is in the service manual. if they are dragging to much the need to be replaced, they are available but not cheap to replace. check fuel valves for leaks and screens for corrosion, also part of a AD. check rear bulkhead for cracks and horizonal bearings for play. also AD |
![]() On 25-Feb-2007, "E Andersen" wrote: Hi the more I look into it, the more I keep returning to the comanche, it must be the fastest small twin and at the same time very economical, how can that go wrong :-) I might go and have a look at this one http://www.schomeraircraftcenter.com/inventory5.htm during the week, does anyone know this particular aircraft? Erik check the gear trunion pins- ad on thoses they crack. check logs for dye inspection, repeditive, or replacement with webco units, non repetitive. check gear bungee arms they crack also, no ad but ad on bungees. check main gear castings at the web, they crack there also. check tension on the push-pull gear cables, need a adapter most twinco owners will have one or were to get one, they are easy to make the drawing is in the service manual. if they are dragging to much the need to be replaced, they are available but not cheap to replace. check fuel valves for leaks and screens for corrosion, also part of a AD. check rear bulkhead for cracks and horizonal bearings for play. also AD Don't know anything about this particular but if an autopilot is part of your consideration (seem to remember a previous reference) I would not consider this aircraft. I owned a 64 model TC a number of years ago with this autopilot and it is very old technology even at that time (about 15 years ago). It was in and out of the instrument shop several times trying to keep the thing working, especially the altitude hold. The people at the shop were an old family business that had been around since shortly after WWII and they didn't have anything good to say about it. Several boxes, all interconnected with RF cables (old style coax, with the hollow dialectric for the center conductor). The plane was great, a real honest four person plus baggage plane even with full fuel. Reasonable operating costs for a twin. But the old autopilot was garbage. Good luck in your search. Rick |
Before we found our 66 Aztec C model with it's STEC 60-2, we
considered a 65 C with an Altimatic II that was inoperable. I called Autopilots Central and discussed this autopilot with Bob Ferguson. He took plenty of time and explained the problems with the Altimatic II and didn't simply brush me off. His recommendation was to totally discount this autopilot, even it was fully functional. He said that we'd be looking for a replacement just as soon as we had our first problem with it. I have a friend with an Altimatic III in his Aztec and he hasn't any problems, plus it's still serviceable by most shops. YMMV Jim Burns |
![]() I wonder if the upgrade to an STEC would be relatively easy, if the servos are already in place? wrote in message ups.com... Before we found our 66 Aztec C model with it's STEC 60-2, we considered a 65 C with an Altimatic II that was inoperable. I called Autopilots Central and discussed this autopilot with Bob Ferguson. He took plenty of time and explained the problems with the Altimatic II and didn't simply brush me off. His recommendation was to totally discount this autopilot, even it was fully functional. He said that we'd be looking for a replacement just as soon as we had our first problem with it. I have a friend with an Altimatic III in his Aztec and he hasn't any problems, plus it's still serviceable by most shops. YMMV Jim Burns |
Bob Ferguson would know the best route for you to follow. His email and
contact info are at http://www.autopilotscentral.com/contact.htm He's a straight shooter. You'll find his name, recommendations, and accolades in the archives of many newsgroups. Jim |
twin comanche | E Andersen | Owning | 10 | February 23rd 07 09:57 PM |
Twin Comanche vs. Mooney/other singles | E Andersen | Owning | 18 | December 17th 06 07:32 PM |
aftermarket de-ice for Twin Comanche | Dico | Owning | 1 | February 5th 06 05:51 PM |
Twin Comanche comparisons | Dico | Owning | 6 | January 30th 06 06:00 PM |
AOPA Twin Comanche | Rosspilot | Piloting | 79 | December 8th 04 07:23 PM |
