#11
Cherokee 180
90% of the time I'm cruising between 3000 AGL and 5000-7000 MSL. I'm occasionally between 2000 and 3000 AGL for sightseeing, never lower, and rarely above 9000 MSL (takes too long to get there). |
Mxsmanic wrote in
: When you are flying VFR in good weather, what is your "comfort zone" for altitude (irrespective of regulatory or other restrictions)? At what altitude AGL do you find that you feel a little too close to the ground, and at what altitude MSL do you find that you feel too high for your own comfort? Also, what type of aircraft do you normally fly (just to put these numbers in perspective)? I fly all sorts, send me 50$ and i'll tell you how low I fly in each one. Oh and that's $50 for each type. Bertie |
the smooth one
wrote in message ... Mxsmanic wrote: When you are flying VFR in good weather, what is your "comfort zone" for altitude (irrespective of regulatory or other restrictions)? At what altitude AGL do you find that you feel a little too close to the ground, and at what altitude MSL do you find that you feel too high for your own comfort? Also, what type of aircraft do you normally fly (just to put these numbers in perspective)? The question makes no sense as written. Generally 3000 AGL minimum to have some glide room if the engine quits. For short trips, 4500/5500 MSL, longer trips 5500/6500, real long trips or over mountains, 7500/8500. A Tiger. -- Jim Pennino Remove .spam.sux to reply. |
Completely agree with the 'depend on circumstances' crowd, although I
have found that the aviation community tends to be split into two personalities - those who prefer to get "as high as practical", and those who tend to enjoy staying lower, enjoying the view (for what its worth, the latter crowd in my experience seems to do more to make sure they stay over easily land-able terrain, whereas the 'get-high' group tends to take more direct routing, so I'm not sure one is particularly more dangerous than the other). Kinda a 'get up, get there' vs 'low, slow, and enjoy the view' dichotomy. I think most of us fall somewhere in between, it the main thing is what do we want to get out of a particular flight. About the only exception i'll say in terms of other 'altitude preference'. When flying heavily congested, open vfr airspace (such as SF bay on a bay tour), I've always been most comfortable flying at '250 and '750 altitudes rather than '000 and '500... The rational is pretty simple - its still trivially easy to track my altitude precisely (the mind responds faster to vertical or horizontial orientations on the altimeter than it does reading particular values), while at the same time, it gets me 'off the beaten path' so to speak. The safety value is marginal, if nill in reality (between sightseeing pilot's not holding altitude and differing altimeter calibrations), but I still do it now out of habit. |
Dan writes:
In mountainous areas, I like to stay at least 1000 ft. above the highest terrain along the course. More if the winds aloft are high. Out here in the west, it always seems like I'm bumping up against the oxygen altitude limits if I'm IFR though... Why only when you are IFR? I note that a lot of the areas in the western U.S. have sizable mountains. If you have a choice between continuing straight on and climbing several thousand feet to clear some mountains (with the potential need for supplementary oxygen), and taking a detour to go them without a change in altitude but at the cost of extra time and distance, which do you usually prefer or consider more prudent? -- Transpose mxsmanic and gmail to reach me by e-mail. |
george writes:
anything that clears the granite overcast :-) I presume that "granite overcast" is a slang term for terrain? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Danny Deger writes:
More that once over the plains around Amarillo Texas I would fly cross country at about 3 feet. I had to climb to go over the barbed wire fences. Perfectly legal as best I could tell. I could easily have landed if my engine quit. It is REALLY flat up there. Three feet would make me uncomfortable, but to each his own. It also wouldn't be legal, since it violates 91.119(a), although in Texas I suppose there isn't anyone around to watch and enforce. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Paul kgyy writes:
Given favorable winds, I like to fly at 7-9000 over the plains. In mountains, which I don't do much any more, I like to be as high as I can without oxygen considerations, which usually means 10-12,000 if not for too long, or if more than half an hour I start using O2. Do you always keep oxygen on hand, or do you only bring it along if you suspect you'll be needing it? -- Transpose mxsmanic and gmail to reach me by e-mail. |
EridanMan writes:
About the only exception i'll say in terms of other 'altitude preference'. When flying heavily congested, open vfr airspace (such as SF bay on a bay tour), I've always been most comfortable flying at '250 and '750 altitudes rather than '000 and '500... The rational is pretty simple - its still trivially easy to track my altitude precisely (the mind responds faster to vertical or horizontial orientations on the altimeter than it does reading particular values), while at the same time, it gets me 'off the beaten path' so to speak. Do you risk getting into any trouble by not following the x500 rule for altitude? Wouldn't it be safer to fly at x200 or x700 altitudes, since the transponder rounds off to the nearest hundred? Unusual altitudes appear to violate 91.159 unless you're at 3000 AGL or below, although I thought I had read somewhere that VFR flights could fly at any altitude as long as they were not directed otherwise by ATC. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Danny Deger writes: More that once over the plains around Amarillo Texas I would fly cross country at about 3 feet. I had to climb to go over the barbed wire fences. Perfectly legal as best I could tell. I could easily have landed if my engine quit. It is REALLY flat up there. Three feet would make me uncomfortable, but to each his own. It also wouldn't be legal, since it violates 91.119(a), although in Texas I suppose there isn't anyone around to watch and enforce. -- 91.119(a) says: (a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface. You didn't read my post. I clearly stated I could have safely landed if the engine failed. Danny Deger |
Vector altitude for ILS below GS intercept altitude? | M | Instrument Flight Rules | 23 | May 20th 06 07:41 PM |
Least favorite ATC instructions... ... ... | caleb | Owning | 72 | January 15th 06 02:48 PM |
Favorite Av Weather sites | Fred Wolf | Instrument Flight Rules | 28 | November 19th 04 08:40 PM |
Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 10:48 AM |
Favorite Aviation Reminiscense | EDR | Piloting | 31 | March 13th 04 08:36 PM |
