Question about the Arado...
Old July 26th 03, 07:59 PM
Pooh Bear
Nikolaos Deligiannidis wrote:
Hallo,
excuse me my curiosity. Would you be so kind and
tell my to whitch Arado aircraft these informations apply?
Thanks.
Nikos D.
http://www.simons-warbirds.pwp.bluey...SpecsPage1.htm
http://www.compsoc.man.ac.uk/~wingman/arado234.html
A couple of nice links, Graham
Old July 26th 03, 11:36 PM
Nick Pedley
"Bill Silvey" wrote in message
. com...
Why didn't it have an internal bomb-bay? It certainly looks like it had
capacity. The only photos I've ever seen have it hauling two bombs
underwing...
Where would you fit a bomb-bay in a biplane? Between the pilots feet?
Underwing bombracks were the only place to put the bombs.
Nick
Old July 26th 03, 11:47 PM
The Blue Max
"Pooh Bear" wrote in message
The Blue Max wrote:
Interesting post. Do you know of a link to a profile view of this
aircraft?
Is this what you want ?
http://www.luftfahrtmuseum.com/htmi/ite/ar234.htm
Perfect. Thanks.
Old July 27th 03, 07:51 AM
machf
On Sat, 26 Jul 2003 23:36:41 +0100, "Nick Pedley"
.com...
underwing...
The Ar 234 -the one they've been talking about- certainly wasn't a biplane...
But of course, not specifying *which* Arado model in the original question
wasn't a good choice.
__________ ____---____ Marco Antonio Checa Funcke
\_________D /-/---_----' Santiago de Surco, Lima, Peru
_H__/_/ http://machf.tripod.com
'-_____|(
remove the "no_me_j." and "sons.of." parts before replying
Old July 27th 03, 09:35 AM
robert arndt
To enable the original recon machine loaded with fuel to outrun enemy
fighters at 461 mph. But at least the Ar-234 has one small claim to
fame. In March 1945 B-2s repeatedly hit the Remagen bridge with 2,000
lb bombs until it finally collapsed. The Germans had tried everything
from frogmen to V-2s to collapse the bridge but failed until the
Arados did the job.
Bob,
The Ar 234s never hit the Remagen Bridge, although they attacked it
on a number of occasions. They sure as shootin' couldn't carry
2,000# (or more tp the point, 1,000 lg/2200# bombs.) - there just
wasn't enough clearance between the racks & the ground. The Ar
234 wasn't a very big airplane - it's about 2/3 the size of a P-38
or Me 110.
FYI, from 3/7-3/17/45 Ar 234B-2s from III/KG 76 hit the bridge several
times using the "Egon" blind bombing system in horizontal attacks from
16-26,000 ft. Their cumulative attacks weakened the bridge to the
extent that it finally collapsed 10 days after its capture. Some
Fw-190s and a few Me-262s from KG 51 also targeted the bridge but
failed to hit it. The Arados, however, did repeatedly. A total of
fifty-five Ar 234B-2s attacked the bridge over a 10 day span with a
loss of 5 aircraft.
Heavywieght 234s could cary 3 500 kg/1100# bombs, one
under each nacelle, and one semi-recesses under the fuselage, but
I've seen no credible evidence that they were ever used on
operations.
The Ar-234B-2s of III/KG 76 used both the 500 kg bombs and the single
PC 1400.
Rob
Old July 27th 03, 03:05 PM
The Enlightenment
. com...
underwing...
The book "Arado 234 Blitz" by J Richard Smith, & Eddie J Creek (Monogram
Monarch 1) provides a lot of detail.
It had 3 weapons racks. One semi (more like quarter) recessed under the
fuselage. One under each engine nacelles Jumo 004B or in the case of the
rare 234C under the paired BMW 003 nacelles.
It also had hard attachment points for RATO packs outboard of the engine
nacelles. These might also have become available for weapons racks as the
latter Arados (like the 234C) or the HeS 011, Jumo 004D turbojet versions
had sufficient power to lift a full bomb load without RATO. Certainly the
Turbo prop version (Daimler Benz DB 021) might have used these.
For level bombing the patin pds-11 3 axis auto-pilot flew the aircraft while
the human pilot pointed the sights cross hairs of the Lofte 7K computing
bombsight on to the target. The sight automatically tracked the target
according to the aircrafts velocity and height above target. The pilot only
making adjustments fine for drift. A computer in the sight controlled the
autopilot and directed it to the correct release point and released the
bombs at the right time according to their ballistic properties. After bomb
release the bomb sight was swung out of the way.
For dive/slide bombing the PV1B periscope sight was used. This was tied to
the BZA computer. It was only neccesary to keep the cross hairs on target.
When not in use this swung around to point rearwards to give the pilot some
rear vision which was limited otherwise.
Although farily heavu bomb loads could be carried many attacks were
conducted using a single SC500 or SD500 or AB500(which dispensed SD 15
submunitions) presumably to get adaquete range and speed and avoid need for
RATO. Typical attacks being a 4000m to 2000m glide attack using the BZA.
At Altitudes of between 30,000-36,000 feet the Lofte 7K level sight could be
used safely. (The use of a sight such as this was controversial since the
pilot could not keep a lookout and some pilots were very passionatly pro and
some were dive bombing enthusiasts)
Apart from the teething problems of the Jumo 004B and their low thrust
(which were progressively been solved) the Arados biggest flaw was pilot
egress in an emergency which was not easy as he had to climb out through the
roof of the cockpit. The Arado 234 Prototypes (like all German prototypes)
used Heinkel Compressed Air Ejection seats. Unfortunately this seat was
only standard in Heinkel He 219s and Do 235s and some He 177s. presumably
becuase of its weight, cost and maintenance requirements; latter version
would have recieved the lighter Pyrotechnical style ejection seats seen in
the He 162 Salamander.
http://www.delversdungeon.dragonsfoot.org
Remove the X's in my email address to respond.
"Damn you Silvey, and your endless fortunes." - Stephen Weir
I hate furries.
Old July 28th 03, 03:17 AM
Bill Silvey
"machf" wrote in message
On Sun, 27 Jul 2003 17:41:25 GMT, "Bill Silvey"
"The Enlightenment" wrote in message
. com...
it had the capacity. The only photos I've ever seen have it
hauling two bombs underwing...
(Monogram Monarch 1) provides a lot of detail.
snip
Fascinating.
Along the same lines, have any of you ever visited the Luft'46
website?
Yep.
MiG-15-like jet fighters armed with A-A missiles, slugging it out against
P-80's and Vampires over Europe! Fascinating "what-if" stuff with a good
grounding in reality...
I hate furries.
Old July 28th 03, 06:53 AM
machf
On Mon, 28 Jul 2003 02:17:11 GMT, "Bill Silvey"
website?
Yep.
Which, when comparing the Me 262 to other jets which saw further development
after the war was over (I won't mention names, but you know which I'm refering
to) should be accepted as valid...
'-_____|(
Old July 29th 03, 02:03 AM
The Enlightenment
"Bill Silvey" wrote in message . com...
. com...
had the capacity. The only photos I've ever seen have it hauling
snip
Fascinating.
Along the same lines, have any of you ever visited the Luft'46 website?
Yes,
I like luft46. It seems to be mirrored in multiple languages now
including chinese and russian. A mecca for model builders in
particular with some beautifull art.
You won't find anything on it regarding such aircraft as the Me 262 or
Arado 234 unfortunately.
Luft46 is nowhere near complete yet. There are for instance ranges of
Blohm and Voss aircraft that were all steel not included. (they were
suprisiingly light)
It's possible to conjecture on a number of situations where
overlord/D-day may have been delayed such that some of the luft 46
aircraft came into being.
On a technical level I can think of abandoning their magnetron work in
1940 (they had stable magnetrons that were limited to about 80W ie
only enough power for about 1km detection range) and far worse than
that disbanding those high frequency experts into the army becuase
they though that their excellent freya/worzburg radars were adaquete.
When they rediscovered the British magnetrons they couldn't even
analyse them properly till they got these personal back together
again.
After detecting submarine conning towers in 1935 using their radars
the Germans failed to develop submarines which emphasised submerged
performance and endurance soon enough. Type XXI u-boats could have
changed the course of the war if they had of been available 12-14
months earlier.
The Jet engines were delayed by a year by the need to develop low
nickel and chrom alloy usage engines. (Essentialy the Jumo 004A to
Jumo 004B was a conversion of materials). The important Heinkel HeS
011 engine was however meant to not require any strategic materials at
all. Ernest Heinkel wasted much of the engineering talent available
to him by dispersing it in all sorts of parrallel developments such as
ducted fans that distracted development of jet engines.
Even in the case of the the atomic bomb, which would have rendered
many of these developments mute, might have fallen into German hands
early enoough to provide a crude deterent to the threat of an allied
bomb. The Germans tested graphite as a moderator but found that it
was poor. This was due to contaminated graphite however. This meant
they set of on a tangent of extracting heavy water as their moderator
which delayed their progress.
At they end of the day, despite some flawed procurement structures and
excessive secreacy they however lacked the resources in both people
and material of the allies to engineer all of these things and in the
end that wins out in most cases.
Old July 31st 03, 02:55 AM
steve gallacci
The HeS011 would have likely not have panned out in any case and other
more promising designs, like the 006, ran afoul of bureaucratic and
personal bias. Probably the greatest self-inflicted handicap the Nazis
had was its clumsy centralized socialist bureaucracy which was further
compromised by being thoroughly corrupt.
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
