#11
Bill Daniels wrote:
Robert Mudd is dead on. I would add that there is considerable safety and operational value in standardization. On any airfield today, Tost is the dominant ringset/release system. If a second system is used, it adds ring switching to the rope handling chore. There is always a temptation to use a Tost ringset on a Schweizer which WILL occasionally jam the release. Standardizing on Tost is expensive but safer and more convenient. Well, good luck getting Schweizer gliders banned from airfields unless they have a Tost conversion. But I agree that not having to hassle with switching rings on the end of the tow rope would be best. Btw, The three Schreder gliders that I have flown accepted either the Tost ring or the Schweizer ring without problems. Regards, -Doug |
I would like to shed some more light on the Schreder Hook.
The Schreder hook in fact has the same features as the Toast hook. Back pressure will release the ring, this back pressure can easily be metered by changing a simple hardware store spring. Ring size is not critical, nothing gets twisted or jammed to prevent release An other feature, due to the rotating point of the hook being near to where the line of force is located when the glider is high above the tow plane. The release load become less as the glider climbs above the two plane, as well the hook can be shaped that will allow an automatic released if a certain angle is reached and it would still function for all normal towing conditions. As Doug Hoffman already mentioned the hook installation needs only a small opening, when the hook rotates and retracts, a cover automatically swings into place and makes it rather slick looking arrangement. Udo On Nov 24, 10:09 am, Doug Hoffman no.spam wrote: wrote: Long time readers of this news group will remeber posting from me on the subject of Tost tow hooks verses all the others. My opinion is tilll the same, nothing compairs to a Tost tow hook either on the glider or on the tow plane, for safety and reliability. Hi Robert, Actually I did do a search of the message archives before posting and didn't see anything about problems with a Schreder tow hook. Yes, I saw your comments, but they were directed at the Schweizer hook. As mentioned in other replys to this subject the other tow hooks have have an increase in the force needed to actuate the release that is portional to the tension on the tow line. Interesting. I have flown several different Schreder gliders and never had a problem with that. This is not good. None of the other tow hooks have a schedule of maintaince, none of the others lock over center and hold the tow ring in a position for easy and clean release of the tow rope. The Schweizer and Schreader style hooks just can not compaire to a Tost. What are the failure modes of the Schreder nose hook (not the Schweizer or Applebay hook)? How does the failure rate of the Schreder hook compare to the Tost hook? I think there are quite a few Schreder pilots out there now who would be keenly interested in knowing about this. One reason you do not see these other tow releases retrofitted to a lot of other gliders is that except for the Schweizer gliders, they are not legal to use in Type Certificated gliders. For a Type Certificated glider that was originally fitted with a Tost hook, to have the other sype hook installed would require a fair ammount of paperwork. A knowlegable FAA inspector would not accept only a form 337 for this change. Of course. Sorry if you thought I meant otherwise. Regards, -Doug |
Robert has a good point: Everyone willing to more for a sailplane than
for a house should demand the very best in accessories and options. Wandering off-topic, the other day I was flipping through a book called "Graphic War," which shows and describes the technical drawings used in the technical manuals of WWII aircraft. I was probably geeking out from the tech writer perspective, but some of the stories behind the documentation are as interesting as the stories behind the aircraft themselves. Okay, maybe not, but I'd argue the case. Anyhow, one of the drawings was a cutaway of the tailwheel and swivel of the Junkers JU52. While the text described it only in terms of its advantages over the tailskid, the drawing showed, in addition to the tailwheel, a tow hitch mechanism with geometry identical to that of a scaled-up Tost E85, right down to the actuation sector and the mirrored torsion spring that holds the release knuckle down. |
| Thread Tools | |
| Display Modes | |
| Aircraft Spruce Rant | Doug Palmer | Home Built | 29 | January 7th 19 04:40 PM |
| Aircraft Spruce came through for me | Rob Turk | Home Built | 3 | June 26th 07 06:01 PM |
| Aircraft Spruce only keeps records for 2 years?? | Rob Turk | Home Built | 7 | June 21st 07 09:07 PM |
| What Others Are Saying About Aircraft Spruce | jls | Home Built | 29 | February 19th 05 12:29 AM |
| Aircraft Spruce and Jim Irwin | Larry Smith | Owning | 23 | October 13th 03 11:59 PM |
