Ham radio in aircraft
Old January 10th 08, 12:02 AM posted to rec.aviation.owning
Jim Stewart
Default Ham radio in aircraft
Jay Maynard wrote:
As my .signature attests, I'm also a ham radio operator. I'd like to be able
to use a 2 meter/440 MHz dual-band radio in the aircraft. While, ideally,
that radio would be an Icom IC-2820H, like the one in my car, practically
speaking it'll be a handheld. An external antenna would seem to be a useful
thing, with the cable brought forward to some convenient spot so I can hook
the radio up to it.
What are other hams doing in their aircraft?
I'm going to be trying APRS in my plane,
but that's at least a couple months off.
Old January 10th 08, 01:43 AM posted to rec.aviation.owning
Doug Vetter
On Wed, 09 Jan 2008 16:02:32 -0800, Jim Stewart wrote:
I'm going to be trying APRS in my plane, but that's at least a couple
months off.
Funny you should mention that, as I'm building an APRS tracker for
airborne use right now. Hope to have it online in a couple weeks. Will
be totally self contained, and based on an old Kenwood KT-78A HT, a N1VG
OpenTracker, Garmin 18 GPS, Maldol AX75 1/2 wave 2M vertical and an AGM
battery. Should be fun to plot the data using Google Earth.
-Doug (N2WOL)
Doug Vetter, ATP/CFI
http://www.dvatp.com
Old January 10th 08, 02:48 AM posted to rec.aviation.owning
David Lesher
Years ago I helped put a Drake 2mtr rig in a friend's 172. He had another
stainless rod antenna in place and I trimmed it to 146 Mhz.
Big issue was the Drake lacked sidetone so it was hard to know how you
were sounding over the engine noise.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old January 13th 08, 10:09 AM posted to rec.aviation.owning
Roger (K8RI)
On Thu, 10 Jan 2008 02:48:44 +0000 (UTC), David Lesher
You and Jim both want side tone. I'm quite happy without it. :-))
Actually I don't even want it except for CW. A couple of quick
reports to start and unless something goes wrong it should be fine.
The only side tone I ever use in both stations (shop and Den) Legal
limit 1.8 through 440), both cars (144/440 @ 50 watts) an the Deb
(144/440 @ 5W) is for CW operation. I just hang the HT on the door
strap under the window and let the rubber duck stick up into the
window. I wear a tiny ear bud and throat mike with a PTT on my shirt
pocket. From 5,000 I get reliable 50 to 75 miles with 5 watts and the
rubber duck ant.
Stations and antennas are shown on my home page.
Roger (K8RI)
WWW.rogerhalstead.com
Old January 10th 08, 02:49 AM posted to rec.aviation.owning
months off.
Hook to a com antenna. Climb to about 5000 feet over IN. You can
kerchunk
about 2 dozen reapeaters on about any frequency you choose. Repeaters
therefore aren't too useful.
Regular 2 way fm communications works better.
Bill Hale K0QA
airborne use right now. *Hope to have it online in a couple weeks. *Will
OpenTracker, Garmin 18 GPS, *Maldol AX75 1/2 wave 2M vertical and an AGM
battery. *Should be fun to plot the data using Google Earth.
-Doug (N2WOL)
Old January 10th 08, 07:32 PM posted to rec.aviation.owning
Jim Stewart
months off.
Please give us an update when it's working.
Old January 10th 08, 01:07 AM posted to rec.aviation.owning
NW_Pilot
I put a Icom 706MKIIG With SGC 239 Tuner in aircraft all the time...
"Jay Maynard" wrote in message
able
useful
hook
the radio up to it.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
http://www.hercules-390.org (Yes, that's me!)
Buy Hercules stuff at http://www.cafepress.com/hercules-390
Old January 10th 08, 01:16 AM posted to rec.aviation.owning
NW_Pilot
Some Photos of a Temp 172 Temp Antenna Install... Use Quality Wire When
Making an Antenna.
http://www.aircraftdelivery.net/me/HF1ANT.JPG
http://www.aircraftdelivery.net/me/HF2ANT.JPG
http://www.aircraftdelivery.net/me/HF3ANT.JPG
http://www.aircraftdelivery.net/me/HF4ANT.JPG
able
useful
hook
the radio up to it.
VHF Aircraft band 2-way radio yooper Soaring 0 July 22nd 05 07:15 PM
FA: Pre-WWII Aircraft Radio Equipment. David Stinson Military Aviation 0 July 1st 04 07:20 PM
FA: Pre-WWII Aircraft Radio Equipment. David Stinson Restoration 0 July 1st 04 07:18 PM
AirCraft Radio Communications [email protected] Rotorcraft 0 November 13th 03 12:48 AM
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO Ron Restoration 0 October 26th 03 12:02 AM
