Feds Want to Equipe Gliders With Transponders and Radios
Old April 27th 08, 11:45 PM posted to rec.aviation.piloting,rec.aviation.soaring
Larry Dighera
Default Feds Want to Equipe Gliders With Transponders and Radios
On Sun, 27 Apr 2008 15:03:33 -0700 (PDT), WingFlaps
wrote in
On Apr 28, 9:32*am, Larry Dighera wrote:
On Sun, 27 Apr 2008 12:34:55 -0700 (PDT), WingFlaps
wrote in
A radar reflector like they use on weather balloon ought be
sufficient. It is just a piece of foil with a large cross section.
That's a constructive suggestion. *
How large must such a radar reflector be? *
It's a retroreflector, I have one in the form of a tube about 3 inches
in diameter and 2 feet long. The corner cubes are inside that. I have
no idea how effective it is compared to a classic reflector which
occupies *a cube about 1 foot across and retroreflects the radar
equally in all directions.
Interesting. *Thanks for the information. *
How do you think it might affect a sailplane's L/D?
Well, if the sailplane skin is transparent to radar a big reflector
could be mounted inside, they don't weigh much. On the other hand a
cylinder type reflector could be made quite aerodynamic and even
incorporated into (say) the wing tips?
Cheers
That sounds like a very simple, inexpensive and effective solution to
the issue. Best of all, the pilot can't turn it off. :-)
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Piloting 155 May 10th 08 02:45 PM
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Soaring 12 May 1st 08 03:42 PM
Gliders, transponders, and MOAs Greg Arnold Soaring 2 May 26th 06 05:13 PM
Transponders and Radios - USA Ray Lovinggood Soaring 1 February 27th 04 06:10 PM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 2nd 03 11:27 PM
