#11
On Jul 5, 9:21*pm, "COLIN LAMB" wrote:
One problem with a transmit every minute, rather than 10 minutes, would be that it would shorten battery life considerably. *I am guessing it would approximate 10% of the present battery life. *The 300 hours of transmit quoted would be reduced to 30 hours. Also, with transmissions every minute, the processing through the satellite might be overloaded with present equipment, which would require more money to correct - hence higher user fees. The external antenna would reduce reliability considerably, and may not gain much. *The exposure to a satellite from a sailplane would be very high, so the most reliable and simplest antenna should work well. Colin Lamb If they respin the packaging in future it would be pretty easy to fit 4 x Lithium AA cells inside the current packaging volume that only holds 2 x Lithium AA cells. I suspect the largest reasons things are as they are are likely not techncial - it seems like marketing decisions targeted at an intended user base of hikers etc. A large issue with external power is maintaining a well sealed packaging and SPOT wanted to claim good specs/complaince for water resistance/sealing and how many hikers carry around 12 volt power? I also suspect no external power and also the need to reset tracking every 24 hours was in part, or in large, to prevent cannibalization of exiting parts of the asset tracking market that Globalstar (who own SPOT) services. ... but folks don't put of buying a SPOT now if you want one, just becasue something better might be coming some time in the future. Darryl |
On Jul 5, 10:21*pm, "COLIN LAMB" wrote:
One problem with a transmit every minute, rather than 10 minutes, would be that it would shorten battery life considerably. *I am guessing it would approximate 10% of the present battery life. *The 300 hours of transmit quoted would be reduced to 30 hours. See other SPOT threads, but as I understand it, the SPOT does transmit once a minute already. It is a "blind" transmission, so there's no acknowledgment from the satellite. So in live tracking, it transmits the same message 10 times, then updates the coordinates, and repeats. An OK is also transmitted repeatedly, that's why both LEDs will flash for 15-20 minutes after pressing OK. Again, this is all part of the design, which is targeted at the hiking market. An aviation unit might also include an altitude. -Tom |
On Jul 6, 7:25*am, 5Z wrote:
On Jul 5, 10:21*pm, "COLIN LAMB" wrote: One problem with a transmit every minute, rather than 10 minutes, would be that it would shorten battery life considerably. *I am guessing it would approximate 10% of the present battery life. *The 300 hours of transmit quoted would be reduced to 30 hours. See other SPOT threads, but as I understand it, the SPOT does transmit once a minute already. *It is a "blind" transmission, so there's no acknowledgment from the satellite. *So in live tracking, it transmits the same message 10 times, then updates the coordinates, and repeats. An OK is also transmitted repeatedly, that's why both LEDs will flash for 15-20 minutes after pressing OK. Again, this is all part of the design, which is targeted at the hiking market. *An aviation unit might also include an altitude. -Tom I don't think SPOT retransmits SPOTcast (tracking) locations, , it relies on just sending a new location every 10 minutes. Delays people see in web site updates for SPOTcasting may be elsewhere in the system.The SPOT unit retransmits OK and help messages, I believe 3 times over a 20 minute period. I beleive the most retransmission that SPOT does is every five minutes continuously in 911 mode. Darryl |
BTW some info on SPOT vs ELT/PLB is well discussed by Doug Ritter of
Equipped to Survive see http://www.equipped.org/blog/?p=82 and http://www.equipped.org/blog/?p=83 Doug Ritter did some great work previously with problems with PLBs, design issues and holes in the standards, you can fish around his blog and find out more about that. Darryl |
LPV versus LNAV/VNAV versus LNAV+V | Wyatt Emmerich[_2_] | Instrument Flight Rules | 6 | December 17th 07 01:38 AM |
AOPA Expo, meeting JayB, getting stuck in Lancaster on the way home,fulfilling the commercial certificate long solo x-c...long | Jack Allison | Piloting | 6 | November 19th 06 02:31 AM |
"zero" versus "oscar" versus "sierra" | Ron Garret | Piloting | 30 | December 20th 04 08:49 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
