#11
On Jun 8, 8:27*am, Uncle Fuzzy wrote:
On Jun 8, 6:36*am, bildan wrote: A couple of years ago I got hammered in a wave rotor while flying a G102. *No matter how tight the shoulder straps, my head kept banging into the canopy. *This is a big enough problem that some glider owners are re-locating the shoulder strap anchors lower. I think modifying the seat belt/shoulder harness is a primary structure issue requiring 337 field modification paperwork in most countries. *There's got to be a better way. This issue came up again recently which led me to some "out-of-the- box" thinking which is the reason for this thread. What if one had inverted "U" shaped, detachable shoulder pad(s) that snapped or Velcro'd to the shoulder straps or maybe the parachute harness? *They would come in various sizes to fit different pilots. In effect, these would raise the pilots shoulders with pads instead of lowering the strap attachment points. * The pads would press down on the pilots shoulders as the straps were tightened preventing canopy head banging. *These pads would be 'personal gear' and not require a 337. Do these things already exist? *Discussion? I have the same issue with my Speed Astir. *No matter how tight the lap and shoulder belts are, my head bashes the canopy with every strong bump. *In 2006, I bashed the canpy OFF the glider. *That was exciting. *I've also considered rigid foam pads atop my shoulders. *If you try it, please post up how well it works. Thanks If you make them tall enough they'll touch the canopy before your head does. Even shorter ones might restrict your ability to look left and right by the time you get them tall enough to meaningfully change the strap angle. I would think given the forces involved there'd be some risk that they'd rotate out of position or flop over sideways - depending on how tall they need to be - or the u-pad would need to have a skeleton of some kind that is quite stiff. Also, having the seatback adjusted aft helps the angle of the straps on many ships - just remember to adjust the rudder pedals back too. I try to strap in with my head low enough that the lap belt is sufficient to keep me clear - taller pilots in shorter gliders don't have the same option. 9B |
On Jun 8, 11:32*am, Andy wrote:
On Jun 8, 8:27*am, Uncle Fuzzy wrote: On Jun 8, 6:36*am, bildan wrote: A couple of years ago I got hammered in a wave rotor while flying a G102. *No matter how tight the shoulder straps, my head kept banging into the canopy. *This is a big enough problem that some glider owners are re-locating the shoulder strap anchors lower. I think modifying the seat belt/shoulder harness is a primary structure issue requiring 337 field modification paperwork in most countries. *There's got to be a better way. This issue came up again recently which led me to some "out-of-the- box" thinking which is the reason for this thread. What if one had inverted "U" shaped, detachable shoulder pad(s) that snapped or Velcro'd to the shoulder straps or maybe the parachute harness? *They would come in various sizes to fit different pilots. In effect, these would raise the pilots shoulders with pads instead of lowering the strap attachment points. * The pads would press down on the pilots shoulders as the straps were tightened preventing canopy head banging. *These pads would be 'personal gear' and not require a 337. Do these things already exist? *Discussion? I have the same issue with my Speed Astir. *No matter how tight the lap and shoulder belts are, my head bashes the canopy with every strong bump. *In 2006, I bashed the canpy OFF the glider. *That was exciting. *I've also considered rigid foam pads atop my shoulders. *If you try it, please post up how well it works. Thanks If you make them tall enough they'll touch the canopy before your head does. Even shorter ones might restrict your ability to look left and right by the time you get them tall enough to meaningfully change the strap angle. I would think given the forces involved there'd be some risk that they'd rotate out of position or flop over sideways - depending on how tall they need to be - or the u-pad would need to have a skeleton of some kind that is quite stiff. Also, having the seatback adjusted aft helps the angle of the straps on many ships - *just remember to adjust the rudder pedals back too. I try to strap in with my head low enough that the lap belt is sufficient to keep me clear - taller pilots in shorter gliders don't have the same option. 9B I think they only have to be higher than the strap attach points to produce considerable downforce. |
On Jun 8, 9:36*am, bildan wrote:
A couple of years ago I got hammered in a wave rotor while flying a G102. *No matter how tight the shoulder straps, my head kept banging into the canopy. *This is a big enough problem that some glider owners are re-locating the shoulder strap anchors lower. I think modifying the seat belt/shoulder harness is a primary structure issue requiring 337 field modification paperwork in most countries. *There's got to be a better way. This issue came up again recently which led me to some "out-of-the- box" thinking which is the reason for this thread. What if one had inverted "U" shaped, detachable shoulder pad(s) that snapped or Velcro'd to the shoulder straps or maybe the parachute harness? *They would come in various sizes to fit different pilots. In effect, these would raise the pilots shoulders with pads instead of lowering the strap attachment points. * The pads would press down on the pilots shoulders as the straps were tightened preventing canopy head banging. *These pads would be 'personal gear' and not require a 337. Do these things already exist? *Discussion? As others have pointed out, there's a whole body of research on pilot/ driver restraint systems. The shoulder straps are clearly intended to handle longitudinal loads (deceleration), NOT vertical. I can't lay my hands on it right now, but somewhere or another I found research indicating the risk of severe spinal damage with excess downforce provided through the shoulders. The only right way to accomplish what you want is to focus on the lap belts or crotch straps. There are dozens of threads on this topic over the last 10 years. One for example: http://groups.google.com/group/rec.a...e611e1a0d817a9 FWIW, I have used both 5 and 6 (and, I guess 7) point harnesses in my gliders for the last 15 years. Since we do extensive ridge running, I can say that I "wouldn't fly without it" (5 or 6 point harness). Cheers, P3 |
On Jun 8, 1:03*pm, bildan wrote:
Keep in mind that cockpit/belt 'fit' differs widely with pilot physique. *4-point belts which works great for one pilot may be problematic for another. *5/6 point belts work great for me and I like them. *Unfortunately, they aren't fitted (or available) for all gliders. *Even if they are available, it would involve a form 337 to install them. *There are really no absolutes. The shoulder pad idea is just to gain yet another option for smaller pilots. I took a look at my parachute and it already has thin shoulder pads on the harness. *Unfortunately, they are rounded on top which makes the shoulder belts tend to slide off. *I think I'll ask my rigger if something could be done about that. Running a crotch strap from the lap belt attachment points works very well for me in a G102. No modifications to the structure was required. Just added some webbing. I didn't even have to do any permanant modifications to the lap belts. This might work for other gliders, i don't know. Todd 3S |
On Jun 8, 1:32*pm, Andy wrote:
I try to strap in with my head low enough that the lap belt is sufficient to keep me clear - taller pilots in shorter gliders don't have the same option. 9B This is my basic problem. I only have about 1 inch of clearance between my head and the canopy. I can only get enough shoulder strap tension with a crotch strap of some kind. Todd 3S |
On Jun 8, 11:28*am, bildan wrote:
On Jun 8, 11:32*am, Andy wrote: On Jun 8, 8:27*am, Uncle Fuzzy wrote: On Jun 8, 6:36*am, bildan wrote: A couple of years ago I got hammered in a wave rotor while flying a G102. *No matter how tight the shoulder straps, my head kept banging into the canopy. *This is a big enough problem that some glider owners are re-locating the shoulder strap anchors lower. I think modifying the seat belt/shoulder harness is a primary structure issue requiring 337 field modification paperwork in most countries. *There's got to be a better way. This issue came up again recently which led me to some "out-of-the- box" thinking which is the reason for this thread. What if one had inverted "U" shaped, detachable shoulder pad(s) that snapped or Velcro'd to the shoulder straps or maybe the parachute harness? *They would come in various sizes to fit different pilots. In effect, these would raise the pilots shoulders with pads instead of lowering the strap attachment points. * The pads would press down on the pilots shoulders as the straps were tightened preventing canopy head banging. *These pads would be 'personal gear' and not require a 337. Do these things already exist? *Discussion? I have the same issue with my Speed Astir. *No matter how tight the lap and shoulder belts are, my head bashes the canopy with every strong bump. *In 2006, I bashed the canpy OFF the glider. *That was exciting. *I've also considered rigid foam pads atop my shoulders. *If you try it, please post up how well it works. Thanks If you make them tall enough they'll touch the canopy before your head does. Even shorter ones might restrict your ability to look left and right by the time you get them tall enough to meaningfully change the strap angle. I would think given the forces involved there'd be some risk that they'd rotate out of position or flop over sideways - depending on how tall they need to be - or the u-pad would need to have a skeleton of some kind that is quite stiff. Also, having the seatback adjusted aft helps the angle of the straps on many ships - *just remember to adjust the rudder pedals back too. I try to strap in with my head low enough that the lap belt is sufficient to keep me clear - taller pilots in shorter gliders don't have the same option. 9B I think they only have to be higher than the strap attach points to produce considerable downforce. If some is good, more is better. Simple geometry would tell me the effectiveness of shoulder straps in restraining your vertical motion is not linear with the angle of the straps. A fraction of a degree off horizontal won't help much at all given even a small amount of stretch in the webbing, slop in the harness and the limits of being able to cinch the whole thing down. I expect you'd need a decent angle to make a difference. My shoulder straps sit slightly below shoulder height - and about 4-5 inches behind the seat back. My experience is that cinching them down tighter mostly plasters me more tightly against the seat back, but doesn't help on the vertical axis nearly as much. Of course that's what they are designed to do. 9B |
I have been fooling around with helper belts for a couple of
seasons ... The following scheme works pretty well ... I tested at the recent Region 2 contest ... My wife sewed a couple of loops in 2 " webbing ... the loops are slipped over the shoulder at the buckle ... the free end passes through a 2" D-Ring which is secured at at the lap belt attachment point ... i.e. you remove the lap belt and then re-attach with the D- Ring included in the loop that circles the the side attachment 'bar'. The free end of the helper webbing then pass up into the same spring loaded buckle holding the shoulder straps ... and yep, this works fine ... no slipping on either belt ... and both are easy to adjust ... While this worked ok, finding the D-ring next to your thigh while you were sitting in the ship was a pain ... so the next approach simply attached the D-Ring to the free end of the lap belt using a 2" slider ... I don't have a photo, but this worked great ... as you bounced on the ridge, the tension on the shoulder straps kept the laps pulled tight ... the hold down pressure is quite good and I actually had to loosen the rig from the pre-takeoff tension as I had it cinched down tight anticipating it would loosen up ... it never did. So, is it as good as a five-point ... well, you do have two extra belts to mess with ... and the 5-belt system is rock solid ... but it is darn close ... plus it is portable/reversible ... and there is no restricting already limited crotch real estate. BTW, when you release the buckle ... the loops pull through the D- rings ... so you can get out gracefully ... or jump ... I have a bunch of extra 2" webbing (maroon and blue), D-rings and sliders ... you can have these for cost + postage (~$10) .... the webbing has to have the loops sewn ... i.e. I'm not sure I could impose on my wife ... Also, looking at other options, I think you could probably just loop the belts through your crotch and then up to the shoulder buckle to create an anti-submarine system ... I have not really explored this as I was just looking for additional hold-down force ... KK http://sailplane-racing.org/Belts/KKRidgeRope.jpg |
I like this version. Mine is essentially the same thing, but run
under the legs for a pair of crotch straps. I am going to try your version and see how it compares. Todd 3S On Jun 8, 10:29*pm, KiloKilo wrote: Also, looking at other options, I think you could probably just loop the belts through your crotch and then up to the shoulder buckle to create an anti-submarine system ... I have not really explored this as I was just looking for additional hold-down force ... *KK http://sailplane-racing.org/Belts/KKRidgeRope.jpg |
On Jun 9, 7:58*am, wrote:
I like this version. *Mine is essentially the same thing, but run under the legs for a pair of crotch straps. *I am going to try your version and see how it compares. Todd 3S On Jun 8, 10:29*pm, KiloKilo wrote: Also, looking at other options, I think you could probably just loop the belts through your crotch and then up to the shoulder buckle to create an anti-submarine system ... I have not really explored this as I was just looking for additional hold-down force ... *KK http://sailplane-racing.org/Belts/KKRidgeRope.jpg Todd, yeah, I think a bunch of us have been trying similar solutions for this over the years ... I think QV (Richard Kellerman) mentioned that Eric Mann showed up at a R2 contest one year .... and was wearing enough carabiners and straps to make a Sherpa jealous ... ;-) The 2" d-ring seems to work well ... we found it just had to be out in the open if you want the belt loop to slip through easily ... And as mentioned (and not pictured) .... hooking the d-ring to to the free end of the lap belt strap did just that ... plus it kept the tension on the lap belts ... very tight ... KK |
| Thread Tools | |
| Display Modes | |
| Strap-on headlamps and their ilk | Casey Wilson | Piloting | 12 | January 27th 07 08:10 PM |
| strap on jet plane???? | Tony | Piloting | 3 | January 1st 07 08:38 PM |
| Strap on Wings | mikeytag | Piloting | 3 | June 8th 06 07:53 AM |
| Surplus Shoulder harness? | Michael Horowitz | Home Built | 2 | May 19th 05 01:37 AM |
| ? for the NG-Flag shoulder patches | Pechs1 | Naval Aviation | 28 | December 3rd 04 08:15 PM |
