Portable/back up transceiver
Old July 27th 09, 08:54 PM posted to rec.aviation.piloting
Default Portable/back up transceiver
"jan olieslagers" wrote in message
Of course NiMH have better capacity, but Murphy says they'll be full
anytime anyway, except when you need them.
That's why I don't particularly like rechargeables of any type for emergency
use. A good fresh set of non-rechargeable alkalines will give you about 5
years of shelf life depending on how they are stored and lithium batteries
will last a bit longer. The manufacturers sometimes spec 10 years or more
on lithiums, but you're getting down to 50-70% of capacity at that point
which is not exactly what I'd like to be thinking about in IMC. Most of the
portable transceivers have battery pack options that allow you to use
alkaline or lithium batteries along with rechargeables. It's very nice to
have both packs so you can swap them around when you're using the
transceiver for non-emergency uses.
Old July 28th 09, 02:32 AM posted to rec.aviation.piloting
bobengr
Enough about batteries. Want portable/back up comm recommendations -
Icom, Sporty's etc? Have portable GPS, so Nav is not that important.
Old July 28th 09, 02:49 AM posted to rec.aviation.piloting
Dave[_22_]
On Jul 27, 9:32*pm, bobengr wrote:
Enough about batteries. *Want portable/back up comm recommendations -
Icom, Sporty's etc? *Have portable GPS, so Nav is not that important.
You can't go wrong with Icom. I have had an A2 for over 20 years, and
have had no trouble (other than batteries). Don't waste your money on
an optional
Nav function.
Regarding batteries, I use alkalines exclusively. Rechargeables need
to be cycled regularly (run down then charged up) to be dependable.
The batteries
in a backup tranceiver tend to see only very occasional use (with long
periods of neglect in between). Alkalines have an excellent shelf
life. The only
downside is that they have a higher internal resistance, and don't put
out current as well as the others. That translates into "use low power
on transmit
unless absolutely necessary to use high power".
Dave
Old July 28th 09, 06:14 PM posted to rec.aviation.piloting
Ross
bobengr wrote:
Looking to buy a protable/backup transceiver. Any recommendations?
If you get one, you better buy the headset adapter. Otherwise they are
almost worthless in the cabin, due to noise. I found that out and
quickly bought the adapter. I also have a ICOM and liked. Makes a nice
scanner also. Mine did not have the nav function.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old July 28th 09, 06:16 PM posted to rec.aviation.piloting
Ross
jan olieslagers wrote:
Steve Hix schreef:
In article
I've got an Icom IC-A6 that's pretty nice.
Same here. Don't know where you are but here in Continental Europe it's
often worth a train ticket to England to buy it there. Typically 400 €
vs. 200 GBP.
Mind you a true back-up must cover all radio-failures, meaning it should
not be powered from the aircraft power bus. But making sure the
batteries are fully charged is one more point on the already too long
pre-flight checklist.
I would not use rechargeable batteries, rather Alkaline batteries instead.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old July 30th 09, 03:16 PM posted to rec.aviation.piloting
RST Engineering - JIm
"Clark" wrote in message
Just a data point - I've been using the long-life hybride rechargeables
for
about a year now and find they give good service.
I don't use the older nickle metal hydride rechargeables at all anymore.
What is a "hybride" (sic) battery?
What color is a nickle? (Green, look it up. It is a woodpecker.)
Old August 1st 09, 11:19 PM posted to rec.aviation.piloting
"bobengr" wrote in message
I had a Vertex that failed completely after about 5 years. I now have the
Icom A4 and I like it just fine. It's no longer being made, but you can
still find them for sale new. It's been replaced by the A14. I think it
might have a slightly lower power output than most, but it wasn't enough
that I could notice any difference compared to my old Vertex. None of them
work very well unless you're reasonably close to the ATC radio anyway,
although if you have an externally mounted antenna you can increase your
range somewhat. All of them are limited by power output, so most are going
to have virtually the same range.
Old August 2nd 09, 02:48 PM posted to rec.aviation.piloting
Given the fact that a 1 watt transmitter on one end and a 1 microvolt
receiver on the other end have a maximum theoretical range of 1800 miles,
how in the world can you say that a 4 watt transmitter is "limited by power
output"?
The limitation is always by line of sight or antenna configuration.
"Mike" nospam @ aol.com wrote in message
.. I think it
them work very well unless you're reasonably close to the ATC radio
anyway, although if you have an externally mounted antenna you can
increase your range somewhat. All of them are limited by power output, so
most are going to have virtually the same range.
Old August 3rd 09, 01:41 AM posted to rec.aviation.piloting
"RST Engineering - JIm" wrote in message
power output"?
Since all transceivers of this type are limited by the FCC in regards to how
much power they can output(and most of them develop the max power allowed at
about 1.5w nominal) and since all of them come with essentially identical
omnidirectional antennas, I can pretty much assume they will all have very
similar ranges, since obviously the transmitter is going to be the limiting
factor seeing as how the other end is putting out roughly 7db more power.
So you can use the opportunity to mentally masturbate your "engineering"
knowledge and talk about theoretical true parabolic reflectors and receiver
sensitivities that don't even approach practical applications, but you're
not really contributing much to the OP's question.
Old August 3rd 09, 02:21 AM posted to rec.aviation.piloting
Peter Dohm
power output"?
how much power they can output(and most of them develop the max power
allowed at about 1.5w nominal) and since all of them come with essentially
identical omnidirectional antennas, I can pretty much assume they will all
have very similar ranges, since obviously the transmitter is going to be
the limiting factor seeing as how the other end is putting out roughly 7db
more power.
receiver sensitivities that don't even approach practical applications,
but you're not really contributing much to the OP's question.
I don't always agree with Jim; but he is absolutely right on this one.
When I worked as an avionics technicial, most of the problems that I saw
were ultimately wiring issues of the coaxial cables (frequently broken at
the antenna connector) and only occasionally degraded sensitivity of the
receiver. That was long ago, and more modern receivers should suffer far
less degradation.
The most entertaining case was a Bellanca on which one of the two comm
transceivers would successfully receive the tower frequency about 6 miles
from the airport and transmit just a little further. It turned out that
there was an in-line coax connector which had become disconnected and the
radio signals both transmitted and received were only through the braiding
of the coax cable!
Peter
Blue Angels back in Pensacola - practice session - Diamond heading back to the hangar Pensacola Beachcomber Aviation Photos 0 March 23rd 08 04:28 PM
Did VHF transceiver need TSO certificate? [email protected] Home Built 13 March 31st 07 06:27 PM
FS: Val Com 760 TSO Transceiver aieo Aviation Marketplace 8 January 25th 07 04:38 PM
FA: 760ch transceiver EOC Aviation Marketplace 0 July 27th 05 08:23 PM
Transceiver BoDEAN Products 0 April 7th 04 06:08 AM
