On Aug 23, 1:51*pm, " wrote:
http://www.youtube.com/watch?v=dxkiT8gWIQo Had never done an emergency descent with banking as a tool. *It was suggested to me to try this with a 90 degree bank. Very interesting experience as it really works and works quickly! *I tried 2 without banking and 2 with banking of which the video contains one of each. Video contains both outside and instrumentation views but the instrumentation view unfortunately wasn't as good as I hoped. *Camera power saving feature shut the camera off and I lost my zoom setting. Comments here or on the video most appreciated on helping me improve the technique as this was my first time doing this You were conducting aerobatic flight. Breaking the law is one thing but are you certified for aerobatics? What about your aircraft? This could get you killed. Let me remind you that aerobatics are maneuvers outside those required for "normal" flight FAR 91.303. To get down quickly you should slip, or use full flaps, The risk of overspeed is very high, you have to increase drag to dump energy... Cheers |
atlieb,
Whether your technique is effective or not is one question. Whether what you did was safe is another. I'm assuming from your initial posts that this technique has not been demonstrated to you by a flight instructor, and is not approved in the Pilot's Operating Handbook or similar. If this is the case, then congratulations! You have now embarked on a career as an amateur experimental test-pilot, stepping boldly into the unknown etc. Without knowing a whole lot more about you, your aircraft and the exact circumstances of your flight, no-one here is in a position to judge whether what you did was "safe" or not. But I kind of suspect that you may not have considered all the intricacies of your new profession in flight test. So, if I may, I'd like to ask a few questions about how you undertook this experiment: What is the maximum normal acceleration for your aircraft? What was the maximum normal acceleration you experienced? What is the corner speed for your aircraft? What was your calibrated airspeed in relation to corner speed? What is Va for your aircraft? If you were above Va, what is the limiting aileron deflection? What is the limiting sideslip angle for your aircraft? What sideslip angle did you achieve? On the instrumentation video it looks like your rate of descent was off the clock. So with high ROD and large angle-of-bank, how much vertical airspace did you calculate that you would require to recover? What height did you enter the manoeuvre? What height did you commence recovery? What height did you recover at? How much normal acceleration did you use in the recovery? High normal acceleration equals increase stall speed. What do you think your stall speed was during this manoeuvre? And what are the accelerated stall characteristics for this aircraft? Remember that whilst this is a theory test, it is not an open-book exam... Especially as you have already conducted the practical! It may be that you considered all of the above, found satisfactory answers to those questions, and conducted your flight with all risks as low as is reasonably possible. I still think your life expectancy would be better without part-time experimentation, but well done on your testing philosophy. But, if some of the questions make you stop and think, or you can't see the relevance, or (worse still) you can't understand the question, then amateur test-piloting is not for you and I would strongly advise that you stay safely within the bounds of the aircraft envelope. Good luck, either way. Last edited by Gauntlet : August 23rd 09 at 03:00 PM. Reason: Addressed it to the wrong user - sorry Flap 50! |
On Aug 23, 8:03*am, Gauntlet
wrote: *What height did you enter the manoeuvre? *What height did you commence recovery? *What height did you recover at? I can't answer the book questions, only the streetwise questions. Altimeter hands clearly show that I started the banked descent at 6000. I approached VNE very quickly and recovered at 4500 clearly seen in the video. In the beginning of the video, I also alerted ATC that I would work between 4000 and 6000 and told them that I would be making rapid altitude changes so they could expect that. 325 is my airport elevation so I had plenty of altitude. Gmeter in my plane showed a maximum 2 G value on recovery, and there was no negative G recorded I only banked, no pulling or pushing in the yoke and held the bank angle until the nose started to drop. Video also shows my recovery was not abrupt as I let the plane fly out on it's own. I had a self imposed floor of 4000 and as you can see in the video, VNE came up before the floor, so I let the plane level on it's own without any power adjustment. I did do two emergency descents without bank to get a feel of what was needed for nose down attitude without pushing on the yoke excessively. Beech Sundowner is my plane and commercial maneuvers are permitted. I have a little over 950 hours in my plane I did check out all I could before doing this maneuver.(see response to Robert Moore) and didn't do this "blindly" as the intent of my own lesson was to learn how to descend quickly should an imminent head on be in my future. I do feel I did all I could research wise to ensure safety, and as you can see, the outcome does speak for itself. I posted the video for entertainment, educational value on how I fly, we all know it's not designed for instructional value nor is this the intent of any of my videos. Truth be known, I felt just as safe doing this as doing a power on / power off stall. Nose dropped just the same. Only difference I felt was the speed was higher, G forces were non existent and I had to be on top of my game for energy management.. |
"Flaps_50!" wrote
You were conducting aerobatic flight. TRUE Breaking the law is one thing IN WHAT RESPECT but are you certified for aerobatics? PILOTS DON'T HAVE TO BE CERTIFIED FOR AEROBATICS in the USofA What about your aircraft? When properly equipped, the B23 and C23 are approved for limited aerobatics. (Wikipedia) This could get you killed. Normal takeoffs and landings kill a lot of pilots. Let me remind you that aerobatics are maneuvers outside those required for "normal" flight FAR 91.303. LET ME REMIND YOU.... that the Sundowner is approved for Spins. Google "Beechcraft Sundowner Spins" and you will find a reference to "The Light Airplane Pilot's Guide to Stall/Spin Awareness By Rich Stowell". I would suggest that you read the paragraphs on the following web page. http://books.google.com/books?id=i8r...A304&lpg=PA304 &dq=Spins+in+sundowner&source=bl&ots=u0xxM-hDbY&sig=r8g_VtQN_AjTS8Cql- tWtg0geRo&hl=en&ei=KD2RSo_BKoH8tge9p6TPBA&sa=X&oi= book_result&ct=result& resnum=10#v=onepage&q=&f=false Jeeze...damn amateurs....... Bob Moore ATP B-727, B-707, L-188 USN S-2F , P-2V , P-3B Flight Instructor ASE-I PanAm (retired) |
On Aug 23, 8:17*am, Robert Moore wrote:
"Flaps_50!" wrote You were conducting aerobatic flight. TRUE Robert, I am under the impression what I did was a commercial maneuver. This is done for emergency descents for commercial jet jockeys and of course Lears wouldn't be doing acro flight.. See http://discussions.flightaware.com/v...?p=87546#87546 where I raised this question before undertaking the exercise. Thoughts? |
"BeechSundowner" wrote in message
... On Aug 23, 8:17 am, Robert Moore wrote: "Flaps_50!" wrote You were conducting aerobatic flight. TRUE Robert, I am under the impression what I did was a commercial maneuver. This is done for emergency descents for commercial jet jockeys and of course Lears wouldn't be doing acro flight.. See http://discussions.flightaware.com/v...?p=87546#87546 where I raised this question before undertaking the exercise. Thoughts? First of all, I really doubt that anyone other than the NetKops on UseNet care whether you were conducting acrobatic flight. Personally, the only reason I can think of for an emergency descent in a non-pressurized light single is a fire; and in that case I might not stop at 90 degrees. Besides, in an actual emergency, "ya gotta do what ya gotta do" and being prepared under non-emergency conditions is usually more than half the battle! As to commercial jets, each type may require a type rating and each type rating may include a recommended procedure. There is an article on flying corporate and commercial turbine powered aircraft in each issue of AOPA Pilot, and one of the issues about a year ago did include a simulated emergency descent. In the aircraft type involved, it was easily possible for an attendant or passenger to be standing in the cabin at the time that an emergency might develope; so IIRC the proceedure used in the article was to roll about 30 degrees and push over sufficiently to feel a little light in the seat (about 1/2G) while retarding the thrust levers to flight idle. The article covered the procedure trained by a particular operator of a particular aircraft type. Peter |
On Aug 23, 10:02*am, "Peter Dohm" wrote:
*Besides, in an actual emergency, "ya gotta do what ya gotta do" and being prepared under non-emergency conditions is usually more than half the battle! Exactly why I went out Peter, and it's not like I didn't try to do the research before doing this maneuver in the first place. The intent of this lesson wasn't to learn or fly acro but to better myself in see and avoid situations. Last time I did this was 2001 when I was in VFR training in a Cessna so why not bring myself up to speed in "currency" in my own plane? As you can see, this from the Flight Aware thread I provided, came up because of the Hudson River mid air and discussions ensued on evasive maneuvers, thus me wanting to expand on my own envelope on avoiding a mid air collision. I know I may be comparing apples and oranges when comparing jets to pistons but the concept of minimal G for the bank lead me to believe what was posted in the thread I brought here as it being a non acrobatic maneuver. I now have expanded my avoidance in two directions rather then one. Right and down rather then just down. |
On Aug 24, 2:16*am, BeechSundowner wrote:
On Aug 23, 8:17*am, Robert Moore wrote: "Flaps_50!" wrote You were conducting aerobatic flight. TRUE Robert, I am under the impression what I did was a commercial maneuver. *This is done for emergency descents for commercial jet jockeys and of course Lears wouldn't be doing acro flight.. You can do aerobatics in controlled airspace without a waver from the director? Cheers |
On Aug 31, 5:46*am, "Flaps_50!" wrote:
You can do aerobatics in controlled airspace without a waver from the director? What in the world are you talking about? I was in an area where sudden changes of flight is expected (practice area) I advised ATC in the very beginning I would be making rapid altitude changes in the practice area which I seriously doubt most other pilots would have thought of doing. Your thoughts of wake turbulence is even further out of wack as in my area, they don't send commercial traffic through the practice area nor was anybody above me in the practice area.. Oh yeah, what defines aerobatics in your head? Please provide references as I am below. I called my local FSDO regarding my video. Aerobatics is NOT defined by a number for pitch and roll. 91.303 Aerobatics are defined by ABRUPT changes in pitch and roll, The word ABRUPT is subjective just like reckless and carelessness. Unusual attitude in .303 is subjective and again not defined by a degree of pitch or bank. Practicing emergency maneuvers, commercial maneuvers or practicing unusual attitudes (for IMC work or even stalls - think greater then 30 degree pitch) are NOT considered aerobatic per my FSDO. Don't believe me, call your local FSDO equivelant. 30 degree pitch 60 bank refers to parachute requirements ONLY and parachutes are ONLY required if I am carrying passengers (instructors and crew are not considered passengers). 91.307 I confirmed this with the FSDO so again if you don't believe me, call your local FSDO. |
On Aug 23, 9:17*am, Robert Moore wrote:
"Flaps_50!" wrote You were conducting aerobatic flight. TRUE Breaking the law is one thing IN WHAT RESPECT but are you certified for aerobatics? PILOTS DON'T HAVE TO BE CERTIFIED FOR AEROBATICS in the USofA What about your aircraft? When properly equipped, the B23 and C23 are approved for limited aerobatics. (Wikipedia) This could get you killed. Normal takeoffs and landings kill a lot of pilots. Let me remind you that aerobatics are maneuvers outside those required for "normal" flight FAR 91.303. LET ME REMIND YOU.... that the Sundowner is approved for Spins. Google "Beechcraft Sundowner Spins" and you will find a reference to "The Light Airplane Pilot's Guide to Stall/Spin Awareness By Rich Stowell". I would suggest that you read the paragraphs on the following web page.http://books.google.com/books?id=i8r...A304&lpg=PA304 &dq=Spins+in+sundowner&source=bl&ots=u0xxM-hDbY&sig=r8g_VtQN_AjTS8Cql- tWtg0geRo&hl=en&ei=KD2RSo_BKoH8tge9p6TPBA&sa=X&oi= book_result&ct=result& resnum=10#v=onepage&q=&f=false Jeeze...damn amateurs....... Bob Moore ATP B-727, B-707, L-188 USN S-2F , P-2V , P-3B Flight Instructor ASE-I PanAm (retired) I'm wondering why the 60 degree bank 30 degree pitch requirement of a 'chute for all occupants doesn't apply? |
Light gun work with ATC COMS - Video | [email protected] | Instrument Flight Rules | 25 | July 19th 09 12:07 AM |
Light gun work with ATC COMS - Video | [email protected] | Piloting | 5 | July 15th 09 03:20 AM |
Pop up IFR clearance with ATC COMS - Video | [email protected] | Piloting | 0 | November 15th 08 05:05 PM |
Pop up IFR clearance with ATC COMS - Video | A Lieberma[_2_] | Owning | 0 | November 15th 08 05:04 PM |
Pop up IFR clearance with ATC COMS - Video | [email protected] | Instrument Flight Rules | 0 | November 15th 08 05:04 PM |
