Hey,
Some of you may have heard of Air Canada 143 [http://www.youtube.com/ watch?v=dfJIpA2gv1g] which ran out of fuel in mid air and had to make an emergency descent at velocities way above the normal limits. The pilot's makeshift technique was to engage a sideslip to decelerate the aircraft (which by then had no flaps, and only minimal hydraulics). Now I thought that sideslips (and crabs--whatever the difference between the two is...) were only to be used to handle crosswinds. I didn't read anywhere that they could be used to bleed excessive speed, although it makes sense from an aerodynamics perspective. Anyone out there used sideslips for anything other than crosswind approaches? PS: I have read about many cases of jetliners that had to make emergency descents at abnormally high speeds, but the AC143 seems the only one to have used the sideslip. |
On Mon, 22 Sep 2008 06:10:03 -0700 (PDT), Amine
wrote: Hey, Some of you may have heard of Air Canada 143 [http://www.youtube.com/ watch?v=dfJIpA2gv1g] which ran out of fuel in mid air and had to make an emergency descent at velocities way above the normal limits. The pilot's makeshift technique was to engage a sideslip to decelerate the aircraft (which by then had no flaps, and only minimal hydraulics). Now I thought that sideslips (and crabs--whatever the difference between the two is...) were only to be used to handle crosswinds. I didn't read anywhere that they could be used to bleed excessive speed, although it makes sense from an aerodynamics perspective. Anyone out there used sideslips for anything other than crosswind approaches? PS: I have read about many cases of jetliners that had to make emergency descents at abnormally high speeds, but the AC143 seems the only one to have used the sideslip. all the time to increase the descent angle. not because of bad piloting mind you. I was given clearance to land at Parafield once when I came over to refuel. the clearance was absurd since I was above short base at 1500ft still approaching the circuit but a clearance to land it was and it was convenient. I side slipped off nearly 1500ft and made it bang on the numbers. not bang as in splat but 'bang on' as in precisely at the position (australian idiom) Sideslips are a very useful tool because they allow you to substantially increase the drag, which makes you descent like a plumbers toolbag, but doesnt change the forward speed. so you have no increased risk of stalling as you wash off the height. The Gimli glider pilot used the technique for all the right reasons. Stealth Pilot |
Stealth Pilot wrote
Sideslips are a very useful tool because they allow you to substantially increase the drag, which makes you descent like a plumbers toolbag, but doesnt change the forward speed. so you have no increased risk of stalling as you wash off the height. What you have described is the "forward slip". Although control usage is the same in both, a "side slip" is used to correct for a crosswind, and a "forward slip" is used to descend more rapidly on final without having the airspeed increase. If one is not landing, I suppose that it would just be a "slip". Airliners normally do not use either because of the increased discomfort caused the passengers....both being uncoordinated flight. Amine wrote: PS: I have read about many cases of jetliners that had to make emergency descents at abnormally high speeds, but the AC143 seems the only one to have used the sideslip. AC 143 was constrained by "touchdown speed" runway length. An "emergency descent" has no such constraint and therefore is able to use the aircraft's maximum certificated speed for the descent...far in excess of what would be possible in an approach/landing situation. In an engine failure situation, keep it as high as possible for as long as possible to insure that the field can be reached, and then slip as much as required to lose the excess altitude without gaining airspeed. Bob Moore Flight Instructor ASE-IA ATP B-707 B-727 PanAm (retired) |
Robert Moore schrieb:
What you have described is the "forward slip". Although control usage is the same in both, a "side slip" is used to correct for a crosswind, and a "forward slip" is used to descend more rapidly A slip is a slip is a slip. I always wondered why so many flight instructors celebrate the art of making simple things seem complicated. I finally came to the conlusion that it's to look more impressive to the female students. |
Stefan wrote
A slip is a slip is a slip. I always wondered why so many flight instructors celebrate the art of making simple things seem complicated. I finally came to the conlusion that it's to look more impressive to the female students. From The FAA H-8083-3a, Airplane Flying Handbook INTENTIONAL SLIPS A slip occurs when the bank angle of an airplane is too steep for the existing rate of turn. Unintentional slips are most often the result of uncoordinated rudder/aileron application. Intentional slips, however, are used to dissipate altitude without increasing airspeed, and/or to adjust airplane ground track during a crosswind. Intentional slips are especially useful in forced landings, and in situations where obstacles must be cleared during approaches to confined areas. A slip can also be used as an emergency means of rapidly A slip is a combination of forward movement and sideward (with respect to the longitudinal axis of the airplane) movement, the lateral axis being inclined and the sideward movement being toward the low end of this axis (low wing). An airplane in a slip is in fact flying sideways. This results in a change in the direction the relative wind strikes the airplane. Slips are characterized by a marked increase in drag and corresponding decrease in airplane climb, cruise, and glide performance. It is the increase in drag, however, that makes it possible for an airplane in a slip to descend rapidly without an increase in airspeed. A“sideslip” is entered by lowering a wing and applying just enough opposite rudder to prevent a turn. In a sideslip, the airplane’s longitudinal axis remains parallel to the original flightpath, but the airplane no longer flies straight ahead. Instead the horizontal component of wing lift forces the airplane also to move somewhat sideways toward the low wing. [Figure 8-12] The amount of slip, and therefore the rate of sideward movement, is determined by the bank angle. The steeper the bank—the greater the degree of slip. As bank angle is increased, however, additional opposite rudder is required to prevent turning. A “forward slip” is one in which the airplane’s direction of motion continues the same as before the slip was begun. Assuming the airplane is originally in straight flight, the wing on the side toward which the slip is to be made should be lowered by use of the ailerons. Simultaneously, the airplane’s nose must be yawed in the opposite direction by applying opposite rudder so that the airplane’s longitudinal axis is at an angle to its original flightpath. [Figure 8-13] The degree to which the nose is yawed in the opposite direction from the bank should be such that the original ground track is maintained. In a forward slip, the amount of slip, and therefore the sink rate, is determined by the bank angle. The steeper the bank— the steeper the descent. Rgds Bob Moore |
A slip is a slip is a slip. From The FAA H-8083-3a, Airplane Flying Handbook Ok, so in the USA there exist several different brands of slips. In the rest of the world however, a slip is a slip is a slip. Which is how airplanes see it, too, I suppose. |
Stefan wrote in news:1fb3$48d7ad48$54487392$9846
@news.hispeed.ch: Robert Moore schrieb: What you have described is the "forward slip". Although control usage is the same in both, a "side slip" is used to correct for a crosswind, and a "forward slip" is used to descend more rapidly A slip is a slip is a slip. No it isn't. Bertie |
![]() "Bertie the Bunyip" wrote in message ... | Stefan wrote in news:1fb3$48d7ad48$54487392$9846 | @news.hispeed.ch: | | Robert Moore schrieb: | | What you have described is the "forward slip". Although control usage | is the same in both, a "side slip" is used to correct for a crosswind, | and a "forward slip" is used to descend more rapidly | | A slip is a slip is a slip. | | | No it isn't. | | | Bertie Then how is it different, dumb ass. |
![]() "Bertie the Bunyip" wrote in message ... | Stefan wrote in news:1fb3$48d7ad48$54487392$9846 | @news.hispeed.ch: | | Robert Moore schrieb: | | What you have described is the "forward slip". Although control usage | is the same in both, a "side slip" is used to correct for a crosswind, | and a "forward slip" is used to descend more rapidly | | A slip is a slip is a slip. | | | No it isn't. | | | Bertie Yes it is. |
![]() "Stefan" wrote in message .. . | Robert Moore schrieb: | | What you have described is the "forward slip". Although control usage | is the same in both, a "side slip" is used to correct for a crosswind, | and a "forward slip" is used to descend more rapidly | | A slip is a slip is a slip. | | I always wondered why so many flight instructors celebrate the art of | making simple things seem complicated. I finally came to the conlusion | that it's to look more impressive to the female students. Cuz they have their heads up their asses, just like Bertie Buttlick. |
Slips and skids | William Hung[_2_] | Piloting | 25 | March 17th 08 02:27 AM |
slips to landing in PTS | BB | Soaring | 6 | April 17th 07 05:58 AM |
Slips and spins in FSX? | Chris Wells | Simulators | 0 | December 14th 06 08:24 PM |
A reluctance to take the controls | Jay Honeck | Piloting | 161 | December 1st 06 08:27 PM |
About forward slips | Mxsmanic | Piloting | 77 | November 2nd 06 11:35 PM |
