Hi All,
There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. You can read from the link below. Please note that about 80% of the post are mostly ad hominem attacks and should be ignored. There are some small bits of real discussion. http://groups.google.com/group/rec.a...11fa289cd7864a I am an electrical engineer with experience in analag design and software, with math and physics background that you would expect of an electrical engineer. There are many points made in the discussion, but I would like to focus on one in particular for the sake of progress. There are people in the pilot's group, who think that lift on a wing is analyzed as such: 1. There is air on outside of top of wing that is pushing down, but reduced because of aerodynamics. 2. The *inside* of the wing contains air pushing up against the underside of top of wing . 3. Let us ignore that the same air inside the wing pushes down on the overside of bottom part of wing. 3. The difference in pressure against the underside of the top wing on the inside of wing and top of wing on outside, is what gives plane lift. Note that they ignore the pressure inside the wing that pushes downward on the wing. I am trying to convince them that, if there is air on the inside of the wing, it pushes against all sides of the inside of the wing, including both top underside and bottom overside, and thereby nullifying any effect it would have on the wing. Lift is caused by a difference in pressure between the underside of the bottom of the wing, and the overside of the top of the wing. I count 8-9 people in the group who are utterly convinced that I am inept at physics, mathematics, etc. Note that some of these people have been flying aircraft for years, even decades, while I am still a student pilot. Comments from anyone who knows physics welcome. -Le Chaud Lapin- |
Le Chaud Lapin wrote in
ps.com: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. No, there isn't. There are people who know perfectly well how it works trying to tell a ccouple of k00ks who think they know Bertie |
On Oct 9, 4:08 pm, Le Chaud Lapin wrote:
Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. I'm no expert, but I heard enough in similar arguments here to convince me that the angle-of-attack people are right and the shape of the wing has more to do with controlling turbulence. There are people in the pilot's group, who think that lift on a wing is analyzed as such: 1. There is air on outside of top of wing that is pushing down, but reduced because of aerodynamics. 2. The *inside* of the wing contains air pushing up against the underside of top of wing . Er... that's a new one. OK, I haven't heard this argument then. 3. Let us ignore that the same air inside the wing pushes down on the overside of bottom part of wing. 4. The difference in pressure against the underside of the top wing on the inside of wing and top of wing on outside, is what gives plane lift. You can consider that last just a definition of lift. You won't get lift unless the upward forces are stronger than then downward forces. Note that they ignore the pressure inside the wing that pushes downward on the wing. A wing doesn't need to be hollow to fly. I am trying to convince them that, if there is air on the inside of the wing, it pushes against all sides of the inside of the wing, including both top underside and bottom overside, and thereby nullifying any effect it would have on the wing. Lift is caused by a difference in pressure between the underside of the bottom of the wing, and the overside of the top of the wing. I count 8-9 people in the group who are utterly convinced that I am inept at physics, mathematics, etc. Note that some of these people have been flying aircraft for years, even decades, while I am still a student pilot. Comments from anyone who knows physics welcome. As I said, I lean toward the angle-of-attack arguments now. Take a flat rectangle, tilt it into the wind. The wind blows against the front which is also the bottom, not the back/top. So the forces are on the bottom. Why does that translate into lift? I forget the exact arguments but from first principles if the effect is to change the direction of the incoming air molecules, then by conservation of momentum that translates into equal and opposite change of momentum of the surface, i.e. pressure with an upward component. - Randy |
Randy Poe wrote in
oups.com: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. I'm no expert, but I heard enough in similar arguments here to convince me that the angle-of-attack people are right and the shape of the wing has more to do with controlling turbulence. There are people in the pilot's group, who think that lift on a wing is analyzed as such: 1. There is air on outside of top of wing that is pushing down, but reduced because of aerodynamics. 2. The *inside* of the wing contains air pushing up against the underside of top of wing . Er... that's a new one. OK, I haven't heard this argument then. 3. Let us ignore that the same air inside the wing pushes down on the overside of bottom part of wing. 4. The difference in pressure against the underside of the top wing on the inside of wing and top of wing on outside, is what gives plane lift. You can consider that last just a definition of lift. You won't get lift unless the upward forces are stronger than then downward forces. Note that they ignore the pressure inside the wing that pushes downward on the wing. A wing doesn't need to be hollow to fly. I am trying to convince them that, if there is air on the inside of the wing, it pushes against all sides of the inside of the wing, including both top underside and bottom overside, and thereby nullifying any effect it would have on the wing. Lift is caused by a difference in pressure between the underside of the bottom of the wing, and the overside of the top of the wing. I count 8-9 people in the group who are utterly convinced that I am inept at physics, mathematics, etc. Note that some of these people have been flying aircraft for years, even decades, while I am still a student pilot. Comments from anyone who knows physics welcome. As I said, I lean toward the angle-of-attack arguments now. Take a flat rectangle, tilt it into the wind. The wind blows against the front which is also the bottom, not the back/top. So the forces are on the bottom. Why does that translate into lift? I forget the exact arguments but from first principles if the effect is to change the direction of the incoming air molecules, then by conservation of momentum that translates into equal and opposite change of momentum of the surface, i.e. pressure with an upward component. - Randy Well, thanks be to god that that';s been authoritatively setttled. Bertie |
On Oct 9, 4:25 pm, Bertie the Bunyip wrote:
Randy Poe wrote groups.com: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. I'm no expert, but I heard enough in similar arguments here to convince me that the angle-of-attack people are right and the shape of the wing has more to do with controlling turbulence. [snip] Well, thanks be to god that that';s been authoritatively setttled. "Authoritatively"? Can you read? Can you read the part where I said "I'm no expert" and where I said that I was convinced by other people? - Randy |
Randy Poe wrote in
ps.com: On Oct 9, 4:25 pm, Bertie the Bunyip wrote: Randy Poe wrote groups.com: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. I'm no expert, but I heard enough in similar arguments here to convince me that the angle-of-attack people are right and the shape of the wing has more to do with controlling turbulence. [snip] Well, thanks be to god that that';s been authoritatively setttled. "Authoritatively"? Can you read? Can you read the part where I said "I'm no expert" and where I said that I was convinced by other people? Oow, you ned a sarcasm detector. I can put one up on Ebay for you if you like. Bertie |
On Oct 9, 3:22 pm, Randy Poe wrote:
On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. I'm no expert, but I heard enough in similar arguments here to convince me that the angle-of-attack people are right and the shape of the wing has more to do with controlling turbulence. There are people in the pilot's group, who think that lift on a wing is analyzed as such: 1. There is air on outside of top of wing that is pushing down, but reduced because of aerodynamics. 2. The *inside* of the wing contains air pushing up against the underside of top of wing . Er... that's a new one. OK, I haven't heard this argument then. 3. Let us ignore that the same air inside the wing pushes down on the overside of bottom part of wing. 4. The difference in pressure against the underside of the top wing on the inside of wing and top of wing on outside, is what gives plane lift. You can consider that last just a definition of lift. You won't get lift unless the upward forces are stronger than then downward forces. Note that they ignore the pressure inside the wing that pushes downward on the wing. A wing doesn't need to be hollow to fly. I am trying to convince them that, if there is air on the inside of the wing, it pushes against all sides of the inside of the wing, including both top underside and bottom overside, and thereby nullifying any effect it would have on the wing. Lift is caused by a difference in pressure between the underside of the bottom of the wing, and the overside of the top of the wing. Thanks Randy, But before we talk about what causes lift on the plane, we should clear up the basic physics 1st. Note that what I have described above has nothing to do with airplanes really. If you read carefully, the premise of what they are saying is that, if you have, for example, a sealed jar with air in it, you are permitted to consider the air on the _inside_ of the jar, pushing up on the lid as contributing to a force to lift the jar off the ground, but you are not allowed to consider the air on the _inside_ of the jar, pushing down on the jar un the upper surface of the bottom of the jar. -Le Chaud Lapin- |
ups.com: On Oct 9, 3:22 pm, Randy Poe wrote: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. I'm no expert, but I heard enough in similar arguments here to convince me that the angle-of-attack people are right and the shape of the wing has more to do with controlling turbulence. There are people in the pilot's group, who think that lift on a wing is analyzed as such: 1. There is air on outside of top of wing that is pushing down, but reduced because of aerodynamics. 2. The *inside* of the wing contains air pushing up against the underside of top of wing . Er... that's a new one. OK, I haven't heard this argument then. 3. Let us ignore that the same air inside the wing pushes down on the overside of bottom part of wing. 4. The difference in pressure against the underside of the top wing on the inside of wing and top of wing on outside, is what gives plane lift. You can consider that last just a definition of lift. You won't get lift unless the upward forces are stronger than then downward forces. Note that they ignore the pressure inside the wing that pushes downward on the wing. A wing doesn't need to be hollow to fly. I am trying to convince them that, if there is air on the inside of the wing, it pushes against all sides of the inside of the wing, including both top underside and bottom overside, and thereby nullifying any effect it would have on the wing. Lift is caused by a difference in pressure between the underside of the bottom of the wing, and the overside of the top of the wing. Thanks Randy, But before we talk about what causes lift on the plane, we should clear up the basic physics 1st. Note that what I have described above has nothing to do with airplanes really. If you read carefully, the premise of what they are saying is that, if you have, for example, a sealed jar with air in it, you are permitted to consider the air on the _inside_ of the jar, pushing up on the lid as contributing to a force to lift the jar off the ground, but you are not allowed to consider the air on the _inside_ of the jar, pushing down on the jar un the upper surface of the bottom of the jar. Oh for ****'s sake. You push on something it moves, right? Everone already knows that, Stephen hawkings. While you're trying to agitate in a physics froup why don;'t you ask them how it's physically possible to get your head that far up your own ass. Bertie |
Le Chaud Lapin writes:
If you read carefully, the premise of what they are saying is that, if you have, for example, a sealed jar with air in it, you are permitted to consider the air on the _inside_ of the jar, pushing up on the lid as contributing to a force to lift the jar off the ground, but you are not allowed to consider the air on the _inside_ of the jar, pushing down on the jar un the upper surface of the bottom of the jar. The atmosphere is not a sealed jar. The source of air pressure in the atmosphere is gravity, not confinement and kinetic energy. |
Mxsmanic wrote in
: Le Chaud Lapin writes: If you read carefully, the premise of what they are saying is that, if you have, for example, a sealed jar with air in it, you are permitted to consider the air on the _inside_ of the jar, pushing up on the lid as contributing to a force to lift the jar off the ground, but you are not allowed to consider the air on the _inside_ of the jar, pushing down on the jar un the upper surface of the bottom of the jar. The atmosphere is not a sealed jar. The source of air pressure in the atmosphere is gravity, not confinement and kinetic energy. You are an idiot. Bertie |
| Thread Tools | |
| Display Modes | |
| Pilot's Assistant V1.6.7 released | AirToob | Simulators | 2 | July 7th 07 11:43 AM |
| A GA pilot's worst nightmare? | Kingfish | Piloting | 49 | February 1st 07 03:51 PM |
| Pilot's Political Orientation | Chicken Bone | Piloting | 533 | June 29th 04 01:47 AM |
| Update on pilot's condition? | Stewart Kissel | Soaring | 11 | April 13th 04 10:25 PM |
| Pilot's Funeral/Memorial | TEW | Piloting | 6 | March 17th 04 04:12 AM |
