The earth pulls down on the plane...
Old December 8th 09, 08:35 PM posted to rec.aviation.homebuilt
Alan Baker
Default The earth pulls down on the plane...
....and the plane pulls up on the earth.
The air pushes up on the plane and the plane pushes down on the air;
essentially transferring the earth's continuous flow of downward
momentum acting on the plane to a much greater mass of air.
That air keeps that downward momentum, diffusing it through more and
more volume...
....until it eventually transfers it back to the Earth; countering the
aircraft's upward pull on it.
I'm willing to send that to any Ph.D. in Aeronautics that anyone cares
to name and post the answer back here.
Anyone game?
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old December 10th 09, 04:23 AM posted to rec.aviation.homebuilt
Beryl[_3_]
more volume...
Anyone game?
LOL
Old December 10th 09, 08:37 AM posted to rec.aviation.homebuilt
Beryl[_3_]
more volume...
Anyone game?
Send that to Scott Eberhardt.
http://home.comcast.net/~clipper-108/Professional.html
To email me:
Copy/Paste Send
Next, don't miss "A slightly more technical paper, which targets physics
students and teachers, titled The Newtonian Description of Lift of a
Wing, is also available online (in PDF format)" at the bottom of the
webpage. You'll notice his email address at the top of that paper, the
same as on the webpage.
As the paper says, the amount of air below that is pushed is negligible.
See "the wrong-Newtonian description of lift" on page 3.
See the "virtual scoop" in Figure 5. Air from overhead is pulled down by
the plane. The plane must, in turn, be pulled up. You imagined a plane
at the top of an air column, pushing down. It's more like a plane at the
bottom of a suction bubble, pulling down. Oh, you like differential
pressure, you don't like air to pull? Too bad, he talks about air
pulling on page 5.
Nothing is said about downwash continuing to the surface. The paper does
say that if a plane flies over a large scale, the weight of the airplane
would be measured. Excited?
Well, an acoustically levitated scale would register its own weight too.
Or turn that upside down, and the scale sees the earth's weight
acoustically levitated above the scale. Same thing, and no upwash or
downwash in sight, just a standing pressure wave with a scale caught at
a node between positive and negative.
Almost sort of like a wing between a strong little suction bubble and a
big weak pressure bubble. Is the wing almost sort of caught in a
standing wave? I don't know.
Old December 10th 09, 07:54 PM posted to rec.aviation.homebuilt
Alan Baker
more volume...
Anyone game?
OK, I will.
To email me:
Copy/Paste Send
Thanks, I've got it covered.
pulling on page 5.
You certainly don't.
Alan Baker
Old December 10th 09, 07:58 PM posted to rec.aviation.homebuilt
Alan Baker
more volume...
Anyone game?
To email me:
Copy/Paste Send
pulling on page 5.
Oh, you should check out what he says in his book:
"The wing develops lift by transferring momentum to the air. Momentum is
mass times velocity. In straight and level flight, the momentum is
transferred toward the earth. This momentum eventually strikes the
earth."
http://books.google.com/books?id=wmu...ntcover&dq=und
erstanding+flight+anderson&cd=1#v=onepage&q=downwa sh&f=false
Page 11.
Alan Baker
Old December 10th 09, 08:31 PM posted to rec.aviation.homebuilt
Beryl[_3_]
more volume...
Anyone game?
To email me:
Copy/Paste Send
pulling on page 5.
earth."
Page 11.
Er, right. His book "which targets the general public", rather than the
more technical paper "which targets physics students and teachers."
Old December 11th 09, 07:42 PM posted to rec.aviation.homebuilt
Alan Baker
more volume...
Anyone game?
To email me:
Copy/Paste Send
pulling on page 5.
earth."
Page 11.
You think he rights things into his book which aren't true? You think
that simply because he makes the language more plain he's included
falsehoods?
Really?
He never says *once* in his "more technical paper" that "The plane must,
in turn, be pulled up." That is you.
He does say in his "more technical paper":
"Lift requires power
When a plane passes overhead the formally still air gains a downward
velocity."
Read that over and over until you get it:
"When a plane passes overhead the formally still air gains a downward
velocity."
He also says right at the top of this "more techical paper":
"This material can be found in more detail in Understanding Flight 1st
and 2nd editions by David Anderson and Scott Eberhardt, McGraw-Hill,
2001, and 2009"
IOW, the author of the "more technical paper" declares the book the more
detailed explanation.
Alan Baker
Old December 11th 09, 08:44 PM posted to rec.aviation.homebuilt
Beryl[_3_]
more volume...
Anyone game?
To email me:
Copy/Paste Send
pulling on page 5.
earth."
Page 11.
falsehoods?
Really?
I think so.
Correct. He never said the next sentence "You imagined a plane at the
top of an air column, pushing down" either.
velocity."
velocity."
He actually says that? Still air always seems very casual to me.
2001, and 2009"
Not on the pdf I downloaded.
http://home.comcast.net/~clipper-108/Lift_AAPT.pdf
Maybe you're looking at something else.
I don't see any such notion on his webpage either.
Old December 11th 09, 01:24 AM posted to rec.aviation.homebuilt
Jim Logajan
is mass times velocity. In straight and level flight, the momentum is
earth."
The momentum is transferred toward the earth at essentially the speed of
sound and appears as a rise in static pressure.
.... OR ...
_Your_ contention has *always* been that it is transferred much slower.
In fact you contend that the speed of that transfer decreases at some
unknown rate. By inference, it seems you also appear to contend that the
transfer eventually happens due to a rise in dynamic pressure, not static
pressure.
You appear to continue to treat the problem as a "rocket" problem, which
yields non-physical aspects like holes and voids in the atmosphere above
the aircraft. (Because you've already claimed no air moves upward *until*
the downwash reaches the earth's surface.)
So please help me understand your view of the situation by considering
the following hypothetical case and answering as many of the questions I
ask as you can:
Imagine a toy helicopter in a large room (or even a vertically oriented
denser-than-water submarine in a box fully filled with water):
========================== -- Top
B -- | --------- | -- B
| (===0 |
... ... (Height of room/box could be large or
| | small, relative to blade width.)
========================== -- Bottom
(Width of room/box could be large or
Given a downwash through the blades (depicted by "---------" in the
figure above) of the copter/submarine sufficient to hold the
copter/submarine stationary, can you describe to me roughly how you see
the flow of fluid above the helicopter occuring such that no fluid flows
upward anywhere *through* the plane "B" made by the blades *before* the
first bit of downwash created by the *blades* has reached the bottom of
the room/box?
That is - if the copter/submarine begins moving 1 kg/s of fluid down, do
you see a void immediately forming above the blades?
If not, which direction is the fluid flowing from so as to keep a void
from forming? If so, what keeps fluid from filling that void?
If a void above the blades is avoided by sideways fluid flow, does
that mean you see voids forming along the walls above the blades?
If you see voids forming anywhere, what keeps fluid from filling
them?
Are voids consistent with the assumption of incompressible flow?
Old December 11th 09, 12:23 AM posted to rec.aviation.homebuilt
Jim Logajan
earth."
.... OR ...
pressure.
ask as you can:
| (===0 |
the room/box?
them?
Remember that brown pairs are best suited to tan, greens, beige,brown and other earth tones that are darker in color. Tan colored shoes matchwell with lighter tan, white, beige, blue and other earth tones that arelighter. Black shoes look good when m [email protected] Piloting 0 April 25th 08 09:31 PM
BREAKING NEWS: Simulated FAA pulls MXSMANIC'S simulated license Jim Macklin Piloting 19 November 27th 06 01:55 PM
BREAKING NEWS: Simulated FAA pulls MXSMANIC'S simulated license Peter Dohm Piloting 0 November 26th 06 12:12 PM
BREAKING NEWS: Simulated FAA pulls MXSMANIC'S simulated license M Piloting 1 November 24th 06 10:48 PM
FAA pulls funding for LAAS landing systems JJ Instrument Flight Rules 24 March 7th 04 03:11 PM
