Low test numbers on Standard Cirrus, what could it be?
Old October 24th 12, 09:00 AM posted to rec.aviation.soaring
Roel Baardman
Default Low test numbers on Standard Cirrus, what could it be?
How do you plan to take the wind out of the equation?
I have performed succesful tests with wind and thermals (in Condor
though, not real life) where by alternating the direction you fly in
and then averaging, you get pretty okay results.
The only huge flaw I can think of in this setup is the assumption that
the wind field is the same for the entire altitude-range.
Roel
Old October 25th 12, 04:11 AM posted to rec.aviation.soaring
akiley
Yes, I realized after I wrote the post that calculating LD can't be done without speed, distance and altitude lost. You can figure out feet per minute sink, but then there is the airmass wild card.
The original test with the Cirrus was flown in a straight line at the following IAS. 70, 60, 50, 40. Then I turned the opposite direction and flew the same speed sets. Might be better to fly one speed, do an immediate 180 and fly the same speed. Probably for longer that the 45 seconds per speed that I used.
Also realize that TAS has to be computed, ASI calibrated, winds and airmass.. ... Aaron
Old October 25th 12, 02:45 PM posted to rec.aviation.soaring
I think it was George Moffatt who suggested that a glider designer who claimed a 45:1 L/D should be towed to one mile altitude and released....45 miles OFFSHORE!
Old October 26th 12, 02:38 AM posted to rec.aviation.soaring
akiley
That's a good one. They would probably make it to shore, fly to California City, then north to Minden and land back in California city all before sunset.
Standard Cirrus Walt Connelly Soaring 23 March 20th 11 03:14 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Standard Cirrus Group Jim Hendrix Soaring 0 May 21st 08 03:15 PM
Standard Cirrus Don Burns Soaring 0 January 10th 07 05:24 AM
F/S - Standard Cirrus 75 Bob Soaring 0 October 4th 04 12:23 AM
