![]() Sure, it kept the stuff out of the bearings. But the oil pump is upstream of the filter, and all that metal garbage went through it and chewed it up. "Fixing up" the engine is spending money on an engine that will fail again very shortly, if it generates any oil pressure at all. Nothing less than complete teardown is necessary here. Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. |
"O. Sami Saydjari" wrote: Sure, it kept the stuff out of the bearings. But the oil pump is upstream of the filter, and all that metal garbage went through it and chewed it up. "Fixing up" the engine is spending money on an engine that will fail again very shortly, if it generates any oil pressure at all. Nothing less than complete teardown is necessary here. Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. I can only offer my own experience. My club had an Archer which showed metal in the oil filter. The engine had about 1300 SMOH, and this was the third run on the engine. We tried pulling cylinders and opening the oil pump trying to find the problem and ended up just throwing a lot of good money after bad. In the end, we racked up a lot of shop bills and still had to get a new engine. IHMO, the aviation gods have smiled upon you. They made the engine last long enough to get you safely on the ground so you could write that $21k check. The alternative could have been much worse. |
![]() IHMO, the aviation gods have smiled upon you. They made the engine last long enough to get you safely on the ground so you could write that $21k check. The alternative could have been much worse. I definitely agree. |
Ouch. I paid 20K and change for a Penn Yann O-540 rebuild to new limits
with everything new except the case and crank last summer. Yours is a 4 banger, right? I guess the turbo adds a bunch to it? "O. Sami Saydjari" wrote: Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
6 cylinders.
Ray Andraka wrote: Ouch. I paid 20K and change for a Penn Yann O-540 rebuild to new limits with everything new except the case and crank last summer. Yours is a 4 banger, right? I guess the turbo adds a bunch to it? "O. Sami Saydjari" wrote: Yes, seems reasonable, painful as that conclusion is. Price tag: $21K (plus labor). Gulp. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
On Thu, 08 Apr 2004 08:41:44 -0500, "O. Sami Saydjari"
wrote: Well, it happended. I have owned the plane (Piper Turbo Arrow III) for 3 months and the engine failed during climb out on Tuesday. Altitude was 4400 feet. Luckily, the engine did not entirely quit and I made it to an airport within 10 miles. Glad to hear you made it safely. You are based in Wisconsin, right? Where was the failure? Northern Wisconsin can be an unforgiving area for an off-airport landing (miles and miles of dense forests). (2) Now I am faced with having to have the engine overhauled. Growl! The engine has brand new cylinders on it (well, they have about 100 hours on them) put on by the previous owner. So, I think we want to do a custom overall of this particular engine. Does that make sense? It is too early to tell what you need to do. With that amount of metal - I would tear the engine down and inspect the crank/bearings, etc. You may be able to reuse the cylinders. -Nathan |
![]() Glad to hear you made it safely. You are based in Wisconsin, right? Right. Central Wisconsin. Where was the failure? Northern Wisconsin can be an unforgiving area for an off-airport landing (miles and miles of dense forests). I was on a business trip in Washington D.C., so I was out of a small airport called Tipton Field (FME). I ended up landing at Gaithersburg. |
Tipton (FME) is small? That's a pretty big field. Suburban (W18) which is
about 3 miles away is a small airport (2300'x25' with trees at both ends and a significant slope to the runway). Tipton, also has more of a big airport feel with the staff, not nearly as friendly. "O. Sami Saydjari" wrote: Glad to hear you made it safely. You are based in Wisconsin, right? Right. Central Wisconsin. Where was the failure? Northern Wisconsin can be an unforgiving area for an off-airport landing (miles and miles of dense forests). I was on a business trip in Washington D.C., so I was out of a small airport called Tipton Field (FME). I ended up landing at Gaithersburg. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Good point. I just meant that it was not a BWI or a tower controller
airport, for example. I should have beem more specific. -Sami Ray Andraka wrote: Tipton (FME) is small? That's a pretty big field. Suburban (W18) which is about 3 miles away is a small airport (2300'x25' with trees at both ends and a significant slope to the runway). Tipton, also has more of a big airport feel with the staff, not nearly as friendly. "O. Sami Saydjari" wrote: Glad to hear you made it safely. You are based in Wisconsin, right? Right. Central Wisconsin. Where was the failure? Northern Wisconsin can be an unforgiving area for an off-airport landing (miles and miles of dense forests). I was on a business trip in Washington D.C., so I was out of a small airport called Tipton Field (FME). I ended up landing at Gaithersburg. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
p3/95 | [email protected] | Military Aviation | 1 | September 27th 04 12:27 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
In Flight Failure | Charles Talleyrand | Military Aviation | 1 | August 4th 03 05:25 AM |
