It is still nice to have QFE set for your
competition finish and I will re-set especially if control is giving it as you call 5 minutes. I don't get this at all. What is the advantage? Aerobatics and local winch ops have the common feature that one doesn't expect to be sharing airspace with other users. In this case, it doesn't matter to others what you use for an altimeter setting. When sharing airspace with others -- which is most of recreational and virtually all of competition soaring -- it's stupid not to have everyone on a common standard. This is just as true when local soaring around a public use airport as it is for cross country. -Evan Ludeman / T8 |
On Sat, 28 Jan 2012 21:25:13 -0800, guy wrote:
The one situation where setting the altimeter to "zero' before flight makes sense is flying a purely aerobatic flight. You will never be towed high enough to bust airspace rules. You must be totally focused on how high you are above the ground and to make sure you do not bust the 1,500 floor for aerobatic flight. With so much going on in the cockpit, setting the altimeter to zero makes the scan of the panel very simple. Its also quite comforting if you're a flat-land flier and visiting a hill- top site for a spot of ridge soaring. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
WestJet B-737 With The Sun Setting | Canuck[_10_] | Aviation Photos | 0 | September 4th 10 05:07 PM |
Altimeter Setting | Rolf | Soaring | 82 | August 11th 10 06:15 PM |
WTB: used 57mm Altimeter OR swap for 80mm Altimeter | joesimmers | Soaring | 0 | November 3rd 09 11:59 AM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
Setting QNH | BTIZ | Piloting | 31 | March 12th 04 04:29 PM |
