Master Switch
Old October 16th 13, 03:26 PM posted to rec.aviation.soaring
Dan Marotta
Default Master Switch
A while back I was looking at LiFePO4 batteries to solve my electrical
problems and I may still order them as my SLA batteries are getting old and
hold less of a charge.
I did, however, get behind my panel last week and changed out my master
switch for one more substantial in current capability and have experienced a
major improvement in function of my equipment. The switch that was
installed when I bought the glider was adequate for the CAI302 and the
MicroAir 760 but, after installing a Trig transponder, a Dell Steak and a
Zaon MRX, all operated from the same bus, the current capacity of the master
switch was the limiting factor. After two flights with the new master
switch installed it would appear that the problem is solved.
Old October 16th 13, 06:53 PM posted to rec.aviation.soaring
Soartech
Dan, Just for interest what were the symptoms you were experiencing?
Dean
Old October 16th 13, 10:34 PM posted to rec.aviation.soaring
Dan Marotta
Dean, the radio was cutting out. Initially, other pilots would mention
scratchy and broken transmissions, later the green "Receive" light on my
radio would illuminate but no audio would be forthcoming, finally, the radio
would not function. I'd also see a large voltage drop when keying the
transmitter - sometimes over 1 volt. Switching to a fresh battery would not
solve the problem. I expect switching batteries under load caused pitting
and/or carboning of the switch, making it a high resistance junction.
"Soartech" wrote in message
Dean
Old October 17th 13, 01:37 AM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Ilec is dead set against using a master switch. The SB-7 manual has 22 cautions on the electrical installation page and the first 5 cautions are why it is a bad idea to use a master switch at all.
"MAIN SWITCHES in the electrical system can be a source of serious trouble, in particular where there are radio sets connected to them. When turning on the main switch with the radio on, heavy negative going pulses may be generated on the bus line during the typical 1-ms-bouncing periods of the main switch. They can destroy instruments, if not at once, then in the long run.. We have measured pulses of more than 10 amps".
Ilec goes on and on about what a bad idea a master switch is in a glider. What is the Master Switch really for? To shut off everything in case of an electrical problem.......can you say, smoke in the cockpit? If you do use a master switch (I don't), remember to ALWAYS turn it on FIRST and off LAST to insure these potential 10 amp pulses can't get in your delicate instruments.
Hope this helps,
JJ
Old October 17th 13, 03:10 PM posted to rec.aviation.soaring
Dan Marotta
Thanks, JJ. I have always turned the master switch on first and off last
and used the individual switches on the radios and instruments. I guess
it's that switching thing midway through the flight.
A large capacitor would be one way to mitigate that but I'm thinking more of
a "make before break" setup using multiple switches, i.e., turn on the
second battery before turning off the first.
Or I could simply divide my equipment across two (or three) busses and then
rely on the load division to allow the batteries to last an entire flight.
"JJ Sinclair" wrote in message
and
a
master
run. We have measured pulses of more than 10 amps".
Hope this helps,
JJ
Old October 23rd 13, 06:24 PM posted to rec.aviation.soaring
kirk.stant
Dan, that's how I've had my LS6 setup for over 13 years and it has worked just fine so far.
2 separate busses, one for each battery, with load divided as equally and logically as possible (split varios and loggers, for example).
In addition, the master switch for each buss can also select either battery, so if one battery fails (forgot to charge it?) the essential instruments can be powered by the remaining battery.
Probably WAY over-engineered, but it was fun to wire up and has worked as designed so far (ugly to look at, though - bit of a spaghetti factory behind that small LS6 panel that I want to clean up some day...).
Kirk
66
Old October 23rd 13, 07:33 PM posted to rec.aviation.soaring
JS
How about this, diagram below.
Each battery should have its own fuse.
Switches are drawn as -o\-
Vertical line is the Master bus.
Optional PV charge controller charges the active battery, whether avionics are on or off.
I'd suggest locking switches like Alcoswitch MTL106D available from Mouser for $12.60.
Bat 1 -----o\-----|
Bat 2 -----o\-----|
Bat 3 -----o\-----|
|-----o\----- Avionics
PV Charger -------|
Old October 23rd 13, 07:34 PM posted to rec.aviation.soaring
JS
Sorry, the line looked vertical before shipping.
Old October 24th 13, 02:04 AM posted to rec.aviation.soaring
Dan Marotta
Those switches look like what I used as my new master switch, except mine is
DPDT. I could use one to power two separate busses from two separate
batteries.
"JS" wrote in message
are on or off.
for $12.60.
Bat 1 -----o\-----|
Bat 2 -----o\-----|
Bat 3 -----o\-----|
PV Charger -------|
Old October 24th 13, 06:55 AM posted to rec.aviation.soaring
Alan[_6_]
In article JS writes:
Bat 1 -----o\-----|
Bat 2 -----o\-----|
Bat 3 -----o\-----|
PV Charger -------|
I would seriously recommend against this.
If you only turn on the avionic load switch, with no batteries in
the circuit, the avionics will see the full open circuit output of
the solar panel.
Many "12 volt" panels deliver in the vicinity of 21.6 volts open
circuit -- even if not that high, they can easily be enough to damage
electronics.
Charge should be applied through a charge controller, so the panel
doesn't overcharge and cook the battery, and should be applied in
such a way that it cannot be applied directly to the load alone.
Alan
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (1/3) Glen in Orlando[_3_] Aviation Photos 2 July 8th 12 10:23 PM
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (3/3) Glen in Orlando[_3_] Aviation Photos 0 July 1st 12 01:14 AM
C-133A CARGO MASTER (USAF MUSEUM, DAYTON, OH) - "C-133A Cargo Master.jpg" yEnc (2/3) Glen in Orlando[_3_] Aviation Photos 0 July 1st 12 01:14 AM
Source for PA28-180 split master switch Mike Noel Owning 3 October 5th 05 02:29 AM
Master Switch Lakeview Bill Piloting 23 July 20th 05 01:46 AM
