On Sat, 1 Jan 2005 16:04:42 -0800, "Peter Duniho"
How many mid-air collisions of commercial airliners not equipped have there been? Before the mandate, of course (I assume after the mandate there haven't been any commercial airliners not equipped, right?). Pete Don't know the numbers for sure, but it used to be a fairly frequent occurrence for airliners to hit small aircraft. Of course the press always got it the other way around. That's why we have to have transponders is certain airspace in small aircraft. The TCAS will see our Mode C. Seems like everything that ends up being mandated is because something happened. If memory serves it was a Connie and DC-6 in the 50's that ran in to each other over the Grand Canyon that caused the ATC system as we know it. AA in Cali Columbia is why we have EGPWS. ValuJet is why airliners have to have fire suppression in the baggage hold etc. All commercial airliners are required to have TCAS II with Mode S transponders; Commuters (up to 30 seats, I think) TCAS I Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
On Sat, 01 Jan 2005 19:34:03 -0600, Don Hammer wrote in
:: ... it used to be a fairly frequent occurrence for airliners to hit small aircraft. Of course the press always got it the other way around. That's why we have to have transponders is certain airspace in small aircraft. Here's the MAC that lead to mandatory TCAS: http://www.ntsb.gov/NTSB/brief.asp?e...13X34444&key=2 |
Don Hammer wrote:
Also, since TCAS has been mandated, there has been only one mid-air with equipped aircraft and it was because one crew ignored the warning. (UPS and Aeroflot in Switzerland) DHL and Bashkirian Airlines, actually. |
On Sun, 02 Jan 2005 00:18:38 GMT, James Robinson
wrotD: DHL and Bashkirian Airlines, actually Right you are - gray matter isn't what it used to be. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Don Hammer wrote:
On 1 Jan 2005 15:17:49 -0800, "george" wrotD: Also, since TCAS has been mandated, there has been only one mid-air with equipped aircraft and it was because one crew ignored the warning. (UPS and Aeroflot in Switzerland) ????? You mean the TCAS only gives a warning, with the pilots having a say on whether or not to take action?? I was under the impression that the TCAS sytems talk to each other and take automatic action to avoid a collision!! To leave it to the pilots doesn't appear to be too much of an advantage, with a relative speed of two planes being about 1000 mph towards each other. Also, given the small reaction time, there's also a chance, howsoever small, that the pilots could both take action that'll precipitate a collision instead of avoiding one; both diving, for example. If it isn't automatic, I think the TCAS should be. For sure. Ramapriya |
EBME, eye ball measuring equipment is the most important instrument you have
in the cockpit. ALL THE OTHER AIDS ARE ONLY AIDS! Hope this helps, Peter |
![]() "Ramapriya" wrote in message oups.com... Don Hammer wrote: On 1 Jan 2005 15:17:49 -0800, "george" wrotD: Also, since TCAS has been mandated, there has been only one mid-air with equipped aircraft and it was because one crew ignored the warning. (UPS and Aeroflot in Switzerland) ????? You mean the TCAS only gives a warning, with the pilots having a say on whether or not to take action?? I was under the impression that the TCAS sytems talk to each other and take automatic action to avoid a collision!! To leave it to the pilots doesn't appear to be too much of an advantage, with a relative speed of two planes being about 1000 mph towards each other. Also, given the small reaction time, there's also a chance, howsoever small, that the pilots could both take action that'll precipitate a collision instead of avoiding one; both diving, for example. If it isn't automatic, I think the TCAS should be. For sure. Ramapriya TCAS alerts and instructions are what the pilot is supposed to follow. If ATC and the TCAS conflict then the pilot is required to follow TCAS. In the case over Germany the Russian obeyed ATC when they should have followed the TCAS. The DHL plane obeyed TCAS but still ended up wrecked because the Russian plane had not taken the action it was supposed to follow. As with all accidents measures taken earlier could have eliminated the need for conflict resolution. There was only one controller on duty that night covering a couple of sectors and he missed the problem as it was building up. when he tried to raise the Russian plane he had difficulty and so it all went on. In the end the controller was murdered by, its claimed, avenging parents of the 86 kids killed on the Russian plane. Every regulation brought in is written in someone's blood. |
Chris wrote:
TCAS alerts and instructions are what the pilot is supposed to follow. If ATC and the TCAS conflict then the pilot is required to follow TCAS. Of interest, here was the Russian view of the priorities at the time: http://www.aeronautics.ru/news/news002/news053.htm I believe they have since changed their instructions to encourage the pilots to follow TCAS recommendations. |
In article .com,
"Ramapriya" wrote: To leave it to the pilots doesn't appear to be too much of an advantage, with a relative speed of two planes being about 1000 mph towards each other. Also, given the small reaction time, there's also a chance, howsoever small, that the pilots could both take action that'll precipitate a collision instead of avoiding one; both diving, for example. 1) Reaction times are less of an issue with TCAS because normally the system will advise the crew of traffic (called a traffic advisory or TA) when the conflicting aircraft is (iirc) 40 seconds out. This allows the crew to begin scanning for the potential conflict. 2) If the two aircraft involved in a potential conflict are both TCAS II equipped, the systems will coordinate. That is, generally the higher aircraft will get a "Resolution Advisory" or RA to climb (or possibly not descend) while the lower aircraft will get a descent (or possibly not climb). If it isn't automatic, I think the TCAS should be. For sure. you have far more faith in automation than I. btw - since TCAS can only see transponder-equipped aircraft, it wouldn't be real smart to make the system automatic beause you wouldn't want the system to fly the aircraft into conflict with a non-transponder aircraft. -- Bob Noel looking for a sig the lawyers will like |
Bob Noel wrote:
-- Bob Noel looking for a sig the lawyers will like ok, how about "A good lawyer knows the law, a great lawyer knows the judge" ![]() |
Anti collision lights mods for Arrow 1968?? | Frode Berg | Piloting | 3 | May 20th 04 05:42 AM |
Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 05:16 AM |
New anti collision system for aircrafts, helicopters and gliders | Thierry | Owning | 10 | February 14th 04 08:36 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
"China blamed in '01 air collision" | Mike Yared | Military Aviation | 2 | September 14th 03 06:08 PM |
