Flight review required?
Old April 16th 16, 03:09 AM posted to rec.aviation.soaring
N97MT
Default Flight review required?
Playing devil's advocate, there is a reasoning behind a Flight Review requirement.
For example, if you do the add-on category for Glider, you are not required to pass another knowledge test if you hold Airplane or Helicopter category ratings. Further, there are portions of the practical test which are skipped: Knowledge of Certificates and Documents, Cockpit Management, Airport Operations (except Traffic Patterns), and Navigation (including Airspace) to name a few.
That, plus as was mentioned, an add-on solo endorsement could last forever.
So, if you have not flown in quit a while, and the rules are changing all the time, the only way the FAA can be sure that you are up to snuff on rules and procedures is if you have had a recent Flight Review.
What would work better is if only the ground portion of the Flight Review would be required for the add-on situation because the above missed bits are covered in that part.
The whole Flight Review bit is weird anyway because a strictly CFI-G, who has no knowledge multi-engine Airplanes, could sign you off in your Glider Flight Review, and you could then immediately legally climb into a King Air and fly away, even though you have not touched one in 50 years. Of course we assume here you are already rated in both category and class of the respective aircraft (Glider and AMEL).
Yes, common sense missing all around. Wait...I think Bob Newhart is calling me...
Old April 19th 16, 08:58 PM posted to rec.aviation.soaring
Bob Pasker
This has always been true.
The flight review is a review for your *certificate*, not of your ratings:
61.56(a)(2) A review of those maneuvers and procedures that, at the discretion of the person giving the review, are necessary for the pilot to demonstrate the safe exercise of the privileges of the pilot certificate.
BTW, I am one of those people who solo'd gliders with a Commercial certificate and no flight review before passing the checkride.
--bob
Old April 16th 16, 04:54 AM posted to rec.aviation.soaring
Glider RN
Bill T says the FAA does not trust the instructors judgement. Have no idea, but the instructor can sign off a certificated pilot without a glider rating to act as PIC per FAA AC 61.31(d).
Agree with most of N97MT's comments. I would claim a devils advocate option on the statements about the glider applicant having a flight review to climb in his King AIr. The CFIG endorsing per AC61.31(d) is authorizing PIC operation of a glider only if that is what he fills in. It is not a flight review. The CFIG can restrict the time of the endorsement as has been recommended by the SSA for quite some time. This endorsement is not a flight review. It just lets the applicant go fly the glider legally.
The example cited becomes more of a concern to the FSDO Inspector or DPE if they issue a glider rating for his certificate. The new rating counts as a flight review and so he can go drag out the King Air and be legal if not smart.
However this is not much different than the issue a CFI faces if a pilot with a glider rating and a MEL rating on his certificate comes in for a flight review in a glider. The CFI may not even be rated for Airplanes, but the flight review in the glider opens the gate for the glider and the King AIr. This has never made sense.
Old April 16th 16, 06:01 AM posted to rec.aviation.soaring
Bill T
RN, I agree, the CFIG under 61.31 is only endorsing a rated pilot to fly a glider as PIC in solo operations, not provide a flight review for that pilot to go fly his king air. But the FAA is telling us that an airplane qualified rated pilot must have a flight review in airplane before we can use 61.31 for his glider PIC solo operation toward a rating. The FAA is not trusting that with our endorsement under 61.31 we would have reviewed all current regulations, airspace requirements, and glider flight skills for his PIC glider only flights.
Burt, we hope that the SAA and Safety Foundation can quickly resolve this. I have a "student" under 61.31 that is now grounded based on the legal interpretation in that letter until he can get an airplane flight review. He has no medical and has not flown powered airplanes for 17 hrs. He was back into flying with his son's interest in learning to fly and both were quickly advancing toward dual check rides this spring.
BillT.
Old April 16th 16, 08:43 PM posted to rec.aviation.soaring
Robert Ballou
Well, sort of. Now that this pilot has his glider add on and therefore re-started his flight review 2 year cycle, he now has to comply with 61.57(a). It clearly states, "The required [3] takeoffs and landings were performed in an aircraft of the same category, class, and type . . . ." This hypothetical King Air and glider are different categories (see Part 1, "catagory (1), examples"). Three landings in a glider does not make one current in airplanes or vice versa for that matter. Okay, so there is one more hurdle to overcome but still it is not a roadblock. My advice is for everyone to keep the keys to their King Air well hidden!
Old April 17th 16, 12:21 AM posted to rec.aviation.soaring
Bill T
Robert, with a new completed glider rating, he can go do those King Air landings (and takeoffs) solo before carrying passengers.
No more instruction required according to the FARs.
BillT
Old April 19th 16, 09:02 PM posted to rec.aviation.soaring
Bob Pasker
61.57(a) is clearly ONLY for carrying passengers.
with a flight review in gliders, you can solo that King Air 350 all you want. you can even do 3 touch and goes, fill it with passengers, and take them on a nice jaunt.
--bob
Well, sort of. Now that this pilot has his glider add on and therefore re-started his flight review 2 year cycle, he now has to comply with 61.57(a).. It clearly states, "The required [3] takeoffs and landings were performed in an aircraft of the same category, class, and type . . . ." This hypothetical King Air and glider are different categories (see Part 1, "catagory (1), examples"). Three landings in a glider does not make one current in airplanes or vice versa for that matter.
Old April 22nd 16, 02:05 AM posted to rec.aviation.soaring
Terry said "Most training gliders fit in light sport.". The 2-33 certainly does, but the Blanik L-23 or the Ask 21 does not due to Vne - or am I missing something?
Old April 22nd 16, 02:54 AM posted to rec.aviation.soaring
Bruce Hoult
Light Sport Aircraft have a 120 knot limit on speed in level flight. NOT a limit on Vne (that I can see).
Gliders can't do level flight at all.
Old April 22nd 16, 04:42 AM posted to rec.aviation.soaring
Jim Lewis[_2_]
It is kind of a curious circumstance with the ASK-21. The POH specifies a max all-up weight of 1320 lbs - on the button for the max weight of a light sport aircraft, but the Vne is specified as 151 kts.. - more than a little faster than the 120 kts. Vne the FAA (14 CFR 1.1) limits a light sport aircraft to.
Flight line trailer ideas required mas Soaring 2 September 1st 15 10:59 AM
Organizational Skills Required During Instrument Flight [email protected] Instrument Flight Rules 71 February 23rd 07 05:28 AM
Flight over water...required equipment? ET Piloting 14 March 27th 06 11:47 PM
Horsepower required for level flight question... BllFs6 Home Built 17 March 30th 04 12:18 AM
Is there a FAA Manual for Heli flight examiners? gps required? Eric D Rotorcraft 2 October 29th 03 11:34 AM
