On Mon, 25 Apr 2005 05:36:29 -0700, "Jim Burns"
wrote: Hey TC... 200 Series Bendix shower of sparks type. Jim Visual inspection of points every 100 hrs/12 months whichever came first with point replacement based on condition noted. Doesn't take a rocket scientist to pop the contact cover screws and notice that the points are worn/gap out of limits (too big if the contacts are eroded, too small if the plastic cam follower is worn). 1000 hr/5 year internal lubrication following the TCM/Bendix recommended procedures. Overhaul/replacement at normal TBO interval for the engine they were mounted to. As others have mentioned, if the 500 hr impulse coupling check was mandated, the impulse mag/mags were pulled for coupling inspection, internal timing check/point replacement (again determined by point/follower condition). Lycoming SI 1291 (as I recall) addresses more frequent inspection of the distributor block on magnetos used primarily at high altitudes. I don't have a copy of it handy, and do not remember the hourly requirements. TC |
I guess I have followed the practice mentioned by others... if they are
Bendix, check the points & clean out at 500 hours while doing the impulse coupling check. Follow SB599X The old slicks with the plastic cam needed attention every couple hundred hours. Newer ones seem to last like the bendixs. So I find points with a little wear at 500 hrs, but OK; at 1000 hours, usually replace them and they are good to go till tbo. On the slicks, the dust from arcing in the towers will often short out the distributor caps. So it's a good idea to clean the distributor caps while they are out. Sure there are two. What do you do when you fail a mag check in Bum---- Nebraska on a Sunday? Bill Hale A&P |
One trick I have used to minimize the electrical stress on a magneto
and the related ignition harness is to make sure the plugs are gapped to the minimum permissible gap. This minimizes the chance of encountering a random failure from high voltage. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Dream Airplane poll | Bob Babcock | Home Built | 39 | December 24th 04 02:20 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
News server problems on just this group | Chris W | Home Built | 9 | August 9th 03 02:32 AM |
