Plane wings
Old February 17th 06, 01:38 PM posted to rec.aviation.piloting
Default Plane wings
I have heard talk about that under stress testing of airplanes (eg. big
Boing machines), they bend the wings so much that they touch each
otherover the airplane?
Has anybody seen such photos, or is this just a lie?
Old February 17th 06, 01:51 PM posted to rec.aviation.piloting
Default Plane wings
Not quite that far, but there is an article with a picture
at
http://hsc.csu.edu.au/engineering_st...corrosion.html
James H. Macklin
ATP,CFI,A&P
some support
airplanes (eg. big
touch each
Old February 17th 06, 09:15 PM
Vic7 Vic7 is offline
Member
First recorded activity by AviationBanter: Jun 2005
Not a lie that they perform this test, although as previously pointed out, the spar fails long before the wing-tips meet. I remember seeing a PBS/History/Discover channel program about the initial production of the B777. They had impressive footage of the destructive load testing of the wings. IIRC they failed at a 40-something degree deflection.
I've have also seen footage on the web site of one of the German sailplane manufacturers (A. Schleicher, Schempp-Hirth, or Glaser Dirks, perhaps) of the destructive test of a new wing design with a carbon fiber spar. That was very impressive and violent.
V7
Old February 17th 06, 11:46 PM posted to rec.aviation.piloting
Default Plane wings
Vic7 wrote in
V7
I've seen these tests as well. Something to keep in mind though is
that these are static loads. That is, the loads are applied slowly
until the wing fails. Dynamic loads are another matter entirely.
If the wing fails a static load at 40 degrees, it'd probably still
break if it was deflected to a lesser degree quickly, like within
seconds.
Brian
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html
Sed quis custodiet ipsos Custodes?
Old February 18th 06, 12:29 AM posted to rec.aviation.piloting
Default Plane wings
"Vic7" wrote in message
Testing to Destruction
of the DG-1000 Wing
Camera-inside: normal: 4,88 MB
http://www.dg-download.de/Videos/bruchversuch-i-s.mpg
high-speed: 23,5 MB http://www.dg-download.de/Videos/bruchversuch-i.mpg
Camera-outside: high-speed 26,3 MB
http://www.dg-download.de/Videos/bruchversuch-a.mpg
Geoff
Spell checking is left as an excercise for the reader.
Old February 18th 06, 02:33 PM posted to rec.aviation.piloting
Default Plane wings
What is the point of that extreme testing?
of the DG-1000 Wing
Geoff
Old February 18th 06, 02:49 PM posted to rec.aviation.piloting
Default Plane wings
To confirm the design calculaions and assumptions before placing human
life at risk.
Matt
Old February 18th 06, 05:12 PM posted to rec.aviation.piloting
Default Plane wings
life at risk.
Is it even possible to operate an airframe in a way that will produce
wing-bending of that degree? If so, I believe human life will have
already been in risk long before. It's unrealistic and I believe the
value of "accelerated testing" was debunked about 30 years ago.
Old February 22nd 06, 01:05 AM posted to rec.aviation.piloting
Default Plane wings
I saw that footage too, it was amazing to watch. They were simultaneously
pulling both wingtips upwards with the rest of the fuselage anchored to
the floor. The tips were being pulled pretty slowly, perhaps a centimeter
or two per second, the motion was barely visible. The hangar was very
quiet as the wings bent more and more, then all of a sudden, the wings
snapped very violently and suddenly. Amazing to see.
Kevin.
Old February 17th 06, 06:10 PM posted to rec.aviation.piloting
Default Plane wings
You can see it fail during stress testing of the 777 in the video
http://www.amazon.com/exec/obidos/tg...80642?v=glance
The wing tips certainly aren't close to touching each other but its
still amazing to watch. When it breaks, it makes some noise.
-Robert
Purchase a Info on Purchasing a Plane and Leasing Back to a School pjbphd Piloting 3 August 30th 04 02:10 AM
WINGS: When do the clocks start ticking? Andrew Gideon Piloting 6 February 3rd 04 03:01 PM
WWII warplanes vs combat sim realism [email protected] Military Aviation 37 November 27th 03 05:24 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
