#21
Peter Skelton wrote:
:On Fri, 24 Oct 2003 19:04:01 GMT, "Gord Beaman"
::Sure it will, but it's from the lubrication of the water reducing :the friction between the wheels and the rail, not hydroplaning. : :There is a difference between lubrication and hydroplaning? :Aren't they different aspects of the same thing? Actually, this is true. Hydroplaning is actually a lubrication phenomenon. We don't generally consider it 'hydroplaning' when it is a braking phenomenon, though. At least I don't think we do. :-) -- "It's always different. It's always complex. But at some point, somebody has to draw the line. And that somebody is always me.... I am the law." -- Buffy, The Vampire Slayer |
Fred J. McCall wrote:
Peter Skelton wrote: :On Fri, 24 Oct 2003 19:04:01 GMT, "Gord Beaman"
::Sure it will, but it's from the lubrication of the water reducing :the friction between the wheels and the rail, not hydroplaning. : :There is a difference between lubrication and hydroplaning? :Aren't they different aspects of the same thing? Actually, this is true. Hydroplaning is actually a lubrication phenomenon. We don't generally consider it 'hydroplaning' when it is a braking phenomenon, though. At least I don't think we do. :-) I don't either...you need speed to get the conditions that constitute hydroplaning. You aren't required to be above any particular speed to cause 'sliding' with a lubricant like grease so I don't think that it's the same thing at all. -- -Gord. |
In article , "GordBeaman" says...
Sure it will, but it's from the lubrication of the water reducing the friction between the wheels and the rail, not hydroplaning. Well, as long as you don't have the wrong kind of leaves..... Cheers, dba |
"Gord Beaman" ) wrote:
:Fred J. McCall wrote: : :Peter Skelton wrote: : ::On Fri, 24 Oct 2003 19:04:01 GMT, "Gord Beaman" :
::::Sure it will, but it's from the lubrication of the water reducing ::the friction between the wheels and the rail, not hydroplaning. :: ::There is a difference between lubrication and hydroplaning? ::Aren't they different aspects of the same thing? : :Actually, this is true. Hydroplaning is actually a lubrication :phenomenon. We don't generally consider it 'hydroplaning' when it is :a braking phenomenon, though. : :At least I don't think we do. :-) : :I don't either...you need speed to get the conditions that :constitute hydroplaning. You aren't required to be above any articular speed to cause 'sliding' with a lubricant like grease:so I don't think that it's the same thing at all. Although actually it is probably easier to 'grease-o-plane' than it is to hydroplane, given the viscosity of the stuff. As I understand it (which is at a pretty basic level - apparently this is an immensely complex subject when you start looking at the mechanisms) we refer to hydroplaning (non-boat type) when a vehicle which has freely rolling contact with another surface is going sufficiently fast that it essentially 'traps' a thin layer of water (or whatever) between the surface of its wheels/tires and the surface it is rolling across by essentially exceeding the speed with which the lubricant can flow out from under the wheels. Poorly stated, but what it amounts to is that the lubricant doesn't have the chance to flow out from under the wheels/tires before the vehicle has moved on to the next bit of surface. I used to think this was a surface tension sort of effect when I was young, but apparently it is not. For tired vehicles, other than sheer speed the biggest determinant is inflation pressure of the tires. Lower inflation pressures for the same weight vehicle allow a larger surface area of the tire to come in contact with the surface being traveled across. This means the lubricant fluid (water, in the case we normally think of) must essentially flow out from under a larger surface area for the tire to make contact with the pavement. This is why tread patterns CAN help, if they provide channels for the water to flow out from under the road contact surfaces. Large decreases in vehicle weight can also make this much worse, as they lower the pressure forcing the lubricant out from between the tire and the roadway. The preceding is why commercial airline pilots are taught that hydroplaning is a function of aircraft speed, tire inflation pressure, and gross vehicle weight (because the difference between loaded weight and unloaded weight can be an appreciable percentage of the weight of the vehicle). [So now everyone can tell me how I'm wrong. :-)] |
On Sat, 25 Oct 2003 02:12:12 GMT, "Gord Beaman"
) wrote: Peter Skelton wrote: On Fri, 24 Oct 2003 19:04:01 GMT, "Gord Beaman" ) wrote: "Duke of URL" macbenahATkdsiDOTnet wrote: "charles krin" wrote in message m On Fri, 03 Oct 2003 17:56:05 GMT, "Gord Beaman" ) wrote: "Brian Sharrock" wrote: Now, go and check your tire pressures before the next rain shower. Yep that's right...we used to use "nine times the sq root of the tire pressure" for the onset of hydroplaning, which is about right...you ever think about where a steel wheel rolling on a flat steel surface will hydroplane?... ![]() follow ups trimmed... I doubt that the rail road rolling stock has much problem with hydroplaning... It actually is a serious consideration when the rails are underwater, as happens frequently out here in the Plains when we get heavy rain. Engineers have to be aware that it's going to take longer than usual to come to a stop. Sure it will, but it's from the lubrication of the water reducing the friction between the wheels and the rail, not hydroplaning. There is a difference between lubrication and hydroplaning? Aren't they different aspects of the same thing? Peter Skelton I see that quite a number answered this so I'll just give my gut reaction to your suggestion Peter. I feel that it isn't hydroplaning because speed isn't required to start the process. The wheel will 'slide' on the rail just as easily no matter how slowly it's being moved, therefore it's not the 'pressure' of the wedge of fluid 'lifting the wheel' but the molecules of the lubricant that's filling the dips and valleys between the two surfaces that's reducing the friction. That is not correct. Speed is a factor. Peter Skelton |
On Fri, 24 Oct 2003 12:08:54 -0500, "Duke of URL"
macbenahATkdsiDOTnet wrote: "charles krin" wrote in message On Fri, 03 Oct 2003 17:56:05 GMT, "Gord Beaman" ) wrote: "Brian Sharrock" wrote: Now, go and check your tire pressures before the next rain shower. Yep that's right...we used to use "nine times the sq root of the tire pressure" for the onset of hydroplaning, which is about right...you ever think about where a steel wheel rolling on a flat steel surface will hydroplane?... ![]() follow ups trimmed... I doubt that the rail road rolling stock has much problem with hydroplaning... It actually is a serious consideration when the rails are underwater, as happens frequently out here in the Plains when we get heavy rain. Engineers have to be aware that it's going to take longer than usual to come to a stop. I agree, but I doubt that this is a result of traditional hydroplaning...but rather as a lesser level of 'lubrication' between the rail and wheel... ck -- The Ten Commandments display was removed from the Alabama Supreme Court building, But here was a good reason for the move.* You can't post "Thou Shalt Not Steal" in a building full of lawyers and politicians without creating a hostile work environment. Edna H. on alt.books.m-lackey, 20030930 |
On Sat, 25 Oct 2003 02:12:12 GMT, "Gord Beaman" ) wrote: Peter Skelton wrote: On Fri, 24 Oct 2003 19:04:01 GMT, "Gord Beaman" ) wrote: "Duke of URL" macbenahATkdsiDOTnet wrote: "charles krin" wrote in message om On Fri, 03 Oct 2003 17:56:05 GMT, "Gord Beaman" ) wrote: "Brian Sharrock" wrote: Now, go and check your tire pressures before the next rain shower. Yep that's right...we used to use "nine times the sq root of the tire pressure" for the onset of hydroplaning, which is about right...you ever think about where a steel wheel rolling on a flat steel surface will hydroplane?... ![]() follow ups trimmed... I doubt that the rail road rolling stock has much problem with hydroplaning... It actually is a serious consideration when the rails are underwater, as happens frequently out here in the Plains when we get heavy rain. Engineers have to be aware that it's going to take longer than usual to come to a stop. Sure it will, but it's from the lubrication of the water reducing the friction between the wheels and the rail, not hydroplaning. There is a difference between lubrication and hydroplaning? Aren't they different aspects of the same thing? Peter Skelton I see that quite a number answered this so I'll just give my gut reaction to your suggestion Peter. I feel that it isn't hydroplaning because speed isn't required to start the process. The wheel will 'slide' on the rail just as easily no matter how slowly it's being moved, therefore it's not the 'pressure' of the wedge of fluid 'lifting the wheel' but the molecules of the lubricant that's filling the dips and valleys between the two surfaces that's reducing the friction. That is not correct. Speed is a factor. Peter Skelton Speed is a factor in what?...hydroplaning?, of course it is, in the case of a wheel losing traction because of the action of a lubricant?, no it isn't. -- -Gord. |
The preceding is why commercial airline pilots are taught that hydroplaning is a function of aircraft speed, tire inflation pressure, and gross vehicle weight (because the difference between loaded weight and unloaded weight can be an appreciable percentage of the weight of the vehicle). [So now everyone can tell me how I'm wrong. :-)] Well, I believe you 'are' wrong in only one little area here. The Canadian Armed Forces taught that the only thing that had a bearing on hydroplaning speed was the tire pressure when there was sufficient water depth available. Aircraft weight has no bearing because weight governs the tire pressure and size. The magic figure is "Nine times the square root of the tire pressure". Both the USAF and the RCAF believe that and that's plenty good enough for me sir. If you ever convince them both that they're wrong then please have them send me letters of abject apology. Hell, I'll even accept a mousey little 'oops'. ![]() -- -Gord. |
#29
On Sat, 25 Oct 2003 22:48:27 GMT, "Gord Beaman"
) wrote: Peter Skelton wrote: On Sat, 25 Oct 2003 02:12:12 GMT, "Gord Beaman" ) wrote: Peter Skelton wrote: On Fri, 24 Oct 2003 19:04:01 GMT, "Gord Beaman" ) wrote: "Duke of URL" macbenahATkdsiDOTnet wrote: "charles krin" wrote in message news:rkaipvsmq6dtiqib9018j1isgelcffr0m3@4ax. com On Fri, 03 Oct 2003 17:56:05 GMT, "Gord Beaman" ) wrote: "Brian Sharrock" wrote: Now, go and check your tire pressures before the next rain shower. Yep that's right...we used to use "nine times the sq root of the tire pressure" for the onset of hydroplaning, which is about right...you ever think about where a steel wheel rolling on a flat steel surface will hydroplane?... ![]() follow ups trimmed... I doubt that the rail road rolling stock has much problem with hydroplaning... It actually is a serious consideration when the rails are underwater, as happens frequently out here in the Plains when we get heavy rain. Engineers have to be aware that it's going to take longer than usual to come to a stop. Sure it will, but it's from the lubrication of the water reducing the friction between the wheels and the rail, not hydroplaning. There is a difference between lubrication and hydroplaning? Aren't they different aspects of the same thing? Peter Skelton I see that quite a number answered this so I'll just give my gut reaction to your suggestion Peter. I feel that it isn't hydroplaning because speed isn't required to start the process. The wheel will 'slide' on the rail just as easily no matter how slowly it's being moved, therefore it's not the 'pressure' of the wedge of fluid 'lifting the wheel' but the molecules of the lubricant that's filling the dips and valleys between the two surfaces that's reducing the friction. That is not correct. Speed is a factor. Peter Skelton Speed is a factor in what?...hydroplaning?, of course it is, in the case of a wheel losing traction because of the action of a lubricant?, no it isn't. Speed is a factor in the ease of slippage of a rail car wheel on a wet track. Peter Skelton |
#30
:Fred J. McCall wrote: : : :The preceding is why commercial airline pilots are taught that :hydroplaning is a function of aircraft speed, tire inflation pressure, :and gross vehicle weight (because the difference between loaded weight :and unloaded weight can be an appreciable percentage of the weight of :the vehicle). : :[So now everyone can tell me how I'm wrong. :-)] : :Well, I believe you 'are' wrong in only one little area here. The :Canadian Armed Forces taught that the only thing that had a :bearing on hydroplaning speed was the tire pressure when there :was sufficient water depth available. : :Aircraft weight has no bearing because weight governs the tire ressure and size. The magic figure is "Nine times the square:root of the tire pressure". Both the USAF and the RCAF believe :that and that's plenty good enough for me sir. Yes, that probably is good enough for you. It is not, however, the actual truth, but rather a useful rule of thumb that holds pretty closely for most circumstances. The airlines disagree. So do the folks who study this sort of thing, whose simulation tools tend to go down to all the very small effects. Even the bias of the tire belting and how the cords are constructed has an effect. :If you ever convince them both that they're wrong then please :have them send me letters of abject apology. : :Hell, I'll even accept a mousey little 'oops'. I'd suggest they need to take it up with commercial airlines, which disagree with them and include weight in their gross approximation, since the typical aircraft that they operate can change weight quite drastically in the normal course of operations. -- "The reasonable man adapts himself to the world; the unreasonable man persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man." --George Bernard Shaw |
| Thread Tools | |
| Display Modes | |
