Hi All,
I am a student for my private license, and during my last ground school session, I was having discussion about how glass cockpits might be made cheaper by using commoditized components. For example, some GPS units cost $1000's US, but a friend of mine help found a company that made the most advanced GPS receivers around, and those devices, including package, barely cost $400. Simpler receives are a lot cheaper, some as low as $50US (http://electronics.pricegrabber.com/gps- receivers/p/2003/form_keyword=usb+gps/rd=1) I'm not sure what the differences are in receivers, but I would imagine that a "good" GPS unit could be had for say, $500, in which case, that, coupled with a conventional PC and software, should be able to do anything that the fancier (Garmin, etc) units can do. Most importantly, that one PC could work for many instruments simultaneously, and cost difference should be huge . [Yes, I know, reliability, FAA certification...yada...] What shocked me was the purported cost of instruments compared to what they could cost. A USB pressure sensor should not cost more than $500, in my opinion. I guessed that the VSI might cost a few hundred dollars US as a conservative estimate. My instructor and another student stated that the cost is more like in the $1000's for a typical instrument. Is this true? It's not that I doubt my instructor or my fellow student. I just want to get an idea of how much these various devices cost. For a base reference, I would consider the standard instruments found in Cessna 172. All comments welcome, -Le Chaud Lapin- |
On Tue, 18 Sep 2007 21:31:38 -0700, Le Chaud Lapin
wrote in .com: Yes, I know, reliability, FAA certification...yada... As a potential pilot, what instruments would you trust your life, the lives over those whom you fly, and the lives of your passengers with, FAA certified or commodity instruments? Certainly, you can install any instruments you choose in your aircraft licensed in the Experimental category. |
On Sep 19, 5:07 am, Larry Dighera wrote:
On Tue, 18 Sep 2007 21:31:38 -0700, Le Chaud Lapin wrote in .com: Yes, I know, reliability, FAA certification...yada... As a potential pilot, what instruments would you trust your life, the lives over those whom you fly, and the lives of your passengers with, FAA certified or commodity instruments? Certainly, you can install any instruments you choose in your aircraft licensed in the Experimental category. Oh don't get me wrong. I do think that FAA certification is both necessary and useful. The reason I wrote "yada" is that it seems that, everytime I propose any kind of improvement to the control system of an airplane (or car), my colleagues quickly imply that the existing components cost so much because certification costs are so high. I don't believe this. I think that certification costs are essentially what they are, a relatively fixed cost compared to the profit that would be generated based on the improvement. -Le Chaud Lapin- |
Larry,
As a potential pilot, what instruments would you trust your life, the lives over those whom you fly, and the lives of your passengers with, FAA certified or commodity instruments? What's that old saying the Air Force? Never forget the plane was built by the lowest bidder. -- Thomas Borchert (EDDH) |
In article .com,
Le Chaud Lapin wrote: Hi All, I am a student for my private license, and during my last ground school session, I was having discussion about how glass cockpits might be made cheaper by using commoditized components. [snip]] and cost difference should be huge . [Yes, I know, reliability, FAA certification...yada...] You say you know about reliability, etc. But do you really know what it takes to do the safety analysis? What are the failure modes of these components? How will failures and errors be detected and handled? How will component changes be handled? How much will it cost to repeat the appropriate analyses when various vendors roll part numbers? How will you determine that the part hasn't changed when the vendor didn't change the part number? (Don't laugh, I've seen an LRU no longer work in a particular aircraft when a chipset vendor changed a production process which ever so slightly changed functionality but the vendor didn't change the part number). And do you have any concept of what it would take to put a commodity OS like windows into a safety-critical application? -- Bob Noel (goodness, please trim replies!!!) |
On Sep 19, 5:31 am, Bob Noel
wrote: In article .com, Le Chaud Lapin wrote: Hi All, [snip]] and cost difference should be huge . [Yes, I know, reliability, FAA certification...yada...] You say you know about reliability, etc. But do you really know what it takes to do the safety analysis? Nope. I just know that it will be a fixed cost. My guess is that it would be under $100,000,000. If so, then those costs would be recuperated. What are the failure modes of these components? Same as for most pieces of software and hardware. ![]() How will failures and errors be detected and handled? Self-checking, pre-flight, and during flight, redundancy, etc. How will component changes be handled? With more professionalism than the free pop-up blockers, for example. The first time a plane crashes due to a company's gross oversight (read, bad engineering), they would get license revoked by FAA. Also, the components would still have to be checked. How much will it cost to repeat the appropriate analyses when various vendors roll part numbers? Dunno...I think this is the crux of the issue. The existing older components are well understood and familiar. 5,000 lines of C code is not as familiar. How will you determine that the part hasn't changed when the vendor didn't change the part number? Abstraction barrier. The component would have to comform to specification. After that, they can changes as they wish. (Don't laugh, I've seen an LRU no longer work in a particular aircraft when a chipset vendor changed a production process which ever so slightly changed functionality but the vendor didn't change the part number). And do you have any concept of what it would take to put a commodity OS like windows into a safety-critical application? From a technical point of view, I guess, yes. From a "How much must I pay the FAA and fight political fall-out" point of view, no. -Le Chaud Lapin- |
Nope. I just know that it will be a fixed cost. My guess is that it would be under $100,000,000. If so, then those costs would be recuperated. 100 Million USD? Really, you think it would be that high? But let's say you are right. If every single aircraft registered in the US added your widget that would be amortized to about $500/plane. While I fully agree that anything sold to go into an aircraft costs more than it should at least some of that cost is there for a reason. I'll bet if you call Intel's OEM sales unit and ask for a price on 500 INTEL Core 2 Duo E6300 which is selling for around $155.00 anywhere on the web and told them that you were going to put it in a certified aviation application the price would jump significantly if they would sell it to you at all. Here's a question and answer from Blue Mountain Avionics' website. They make a EIS for experimental aircraft. Keep inmind what they are talking about is for something that will go in an experimental aircraft. They are just talking about GPS IFR approach certification. Q: Is EFIS/One certified for GPS approaches? On the advice of our most trusted avionics dealer and partner, we have decided not to pursue it. For what it will cost to do TSO C129A testing and certification, we'd have to raise the price of the EFIS by more than the cost of a high-volume certified unit. We think it's a better deal to have a reasonably priced glass cockpit, and the interconnect available for those who want to fly GPS approaches. If you have a certified GPS, you can plug it in to drive the flight director and autopilot in approach mode. |
On Sep 19, 9:52 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
wrote: 100 Million USD? Really, you think it would be that high? No, I just picked a number that I was pretty sure it would not exceed. ![]() But let's say you are right. If every single aircraft registered in the US added your widget that would be amortized to about $500/plane. While I fully agree that anything sold to go into an aircraft costs more than it should at least some of that cost is there for a reason. I think the "more" part is *significant*. See below: I'll bet if you call Intel's OEM sales unit and ask for a price on 500 INTEL Core 2 Duo E6300 which is selling for around $155.00 anywhere on the web and told them that you were going to put it in a certified aviation application the price would jump significantly if they would sell it to you at all. Well, something has to be certified. After all, the people who make glass cockpits have to get CPU's and SRAM from somewhere. Here's a question and answer from Blue Mountain Avionics' website. They make a EIS for experimental aircraft. Keep inmind what they are talking about is for something that will go in an experimental aircraft. They are just talking about GPS IFR approach certification. Q: Is EFIS/One certified for GPS approaches? On the advice of our most trusted avionics dealer and partner, we have decided not to pursue it. For what it will cost to do TSO C129A testing and certification, we'd have to raise the price of the EFIS by more than the cost of a high-volume certified unit. We think it's a better deal to have a reasonably priced glass cockpit, and the interconnect available for those who want to fly GPS approaches. If you have a certified GPS, you can plug it in to drive the flight director and autopilot in approach mode. I guess it's true that if you are selling devices in low-volume, certification is not worth the cost. This illuminates the real problem, which is that the approach to building aircraft monitor and control systems is not the same as for building computers. One of the reasons that computers are so cheap is that the almost demand interchangeability. IBM and other large companies, for a long time, have been able to lock in customers with proprietary hardware, but the PC market will not tolerate this. While I am not saying that companies like Garmin are deliberately trying to lock in customers, it does not appear to me that they are making any effort to commoditize their systems either. I think there is enormous opportunity for a company to break away from this mindset and start down the path of total commoditization and interchangeability. Simple, cheap, robust USB-base monitors and controls will go a long way. Let's take an example: Jim Stewart noted in a response to my OP, noting that... "A Lowrance 2000c gives you terrain, airspace, VFR chart, airports and frequencies in a very nice little package for about 700 USD on discount." Here it is: http://www.lowrance.com/Products/Aviation/AM2000C.asp He's right, it's cheaper than $1800, but...$700? When I look at that device, I see nothing more than a PDA, a database, and some software. Continuing with this example, let's suppose I take my $700 instead and buy a standard basic PC from Dell. The Inspiron 531S is selling for $529US: http://configure.us.dell.com/dellsto...=DDCWGC2&s=dhs. Note that it comes with 17inch, LCD color monitor, $160GB hard drive, "in-flight movie viewing system" (DVD drive and Windows Media Player). I would want two of these machines in my airplane, so let's say cost is $1058. Now I look at the link that Jim Stewart gave: http://www.dynonavionics.com First, let me point out that my goal is not to criticize Dynon. [One should commend them for trying to bring the price down.] However, looking at the EFIS-D100 (http://www.dynonavionics.com/docs/ D100_intro.html), which costs $2400, one reads: "Dynon's EFIS-D100 is the most affordable large screen Electronic Flight Information System on the market today. Based on the best- selling EFIS-D10A, the 7" wide-screen display features large, easy to read text and graphics and is capable of displaying multiple pages side by side in a split-screen format. The instrument integrates multiple flight instruments, including airspeed, altitude, gyro- stabilized magnetic compass, turn rate, slip/skid ball, bank angle, and vertical speed. Other useful functions include a clock/timer, g- meter, voltmeter and density altitude/true airspeed calculator." When I see this device, I see 1. My two Dell computers with 17" monitors 2. More software 3. USB-based devices everywhere. I don't see why some sensors like pressure sensor should not cost $50US or less. For instance, the clock-timer.....we need not discuss what value such a thing has in a PC. It's essentially 0$. G-meter...at worst case, that's a USB-base accelerometer. Voltmeter...again..$10 would be a conservative cost for USB-based device. Attitude indication, same thing. Also, since I'd be using PC with 160GB hard disks each, there would be plenty of space for maps of entire planet. So let's say that each USB-gadget costs $50 in quantity on average, and there are 12 of them, so that's $1200 if I double-up each device for redundancy. My total system cost, including two computers, and 24 USB-based gadgets without software, would be $2258, less than the one device for $2400. One could throw in a software-radio, and get access to the entire suite of aviation radio communications. The massive 320 GB of hard-disk space would make things like logging trip data, including weather information, almost trivial. So a different approach might be to stop making finished systems and instead focus on components. Manufacturers would make controls in sensors in wide variety, all conforming to USB standard. A (cheap) commodity PC would be able to control everything. And (licensed) software developers could do their part. -Le Chaud Lapin- |
So a different approach might be to stop making finished systems and instead focus on components. Manufacturers would make controls in sensors in wide variety, all conforming to USB standard. A (cheap) commodity PC would be able to control everything. And (licensed) software developers could do their part. -Le Chaud Lapin- That is where your problem is. It all has to be certified as a unit not as individual components. Like it or not it isn't going to change with anything short of an armed revolution. Let me give you an example of FAA thinking. I'm building and airplane, you can see it at www.peoamerica.net/N601WR. When I'm done because I'm using a non certified prop and engine combination I have to test fly it for 40 hours for phase one testing. If I was using an engine and prop combination that had ever been paired up in a certified aircraft I would only need to phase one test for 25 hours. Now here's the kicker. Just because that certified engine and prop were mounted and flown in an experimental they can never be considered certified again. Another good example is the IFR GPS certification requirement even in an experimental. I can install every single piece of electronics in my plane and if one of those pieces happen to be a Nav/Com with Glide Slope I can fly it IFR. For that matter I could even build the Nav/Com myself and the FAA wouldn't care. (yes the FCC would but that is beside the point) But for a GPS to be used IFR it has to meet the TSO requirements. That Dynon unit you mentioned is what is going in my plane but even it can't go into a certified aircraft without a metric butt load of paperwork. I think deep down you know what the reasons for the cost are but if you don't I'll tell you. Volume: There really isn't that big a market. Certification: Those Dell laptops would never pass the vibration tests alone. LIABILITY |
![]() "Le Chaud Lapin" wrote When I see this device, I see 1. My two Dell computers with 17" monitors You are dreaming, and talking out of your but, while doing so. Your Dells are not bright enough to be direct sunlight readable, which an airplane display must be. Your Dell does not have hard drives capable of operating above 12,000 feet. (or perhaps much lower) Oh, and that software you mentioned is expensive. How about overhead to make all of this stuff, for a market of perhaps 2% of your Dells. Same with the designing of the software. How about profit for the investors? They will need some, spreading the cost over not too many units. I wish the stuff were not so expensive. Wishing will not make it so. -- Jim in NC |
Cockpit instruments | T L Jones | Restoration | 0 | November 19th 03 08:40 PM |
