Nebo-U new russian antistealth radar
Old January 13th 04, 02:22 AM
George Ruch
(Peter Stickney) wrote:
George Ruch writes:
(B2431) wrote:
The article on the F-117 kill (
http://www.aeronautics.ru/f117down.htm)
indicates that the kill was from two SA-6 missiles.
I've got to make a correction, here. The F-117 kill was made by an
SA-3 site.
I should have figured that. An SA-6 kill would have needed a lot of luck,
esp. once the guidance beam came on.
But... The inbound tracking was reportedly accomplished by a 1950's vintage
Soviet radar operating in the 165 - 190 cm range (158 - 181 MHZ). Useful
for ground-based early warning, but pretty much useless for fire control
purposes.
Which, BTW, is the normal EW/Air Search radar of the SA-3. Really old
missiles, like the SA-2 and SA-3 have, oddly enough, an advantage when
engaging stealth aircraft.
[much good info snipped]
I remember that setup from my old EW days. Add a decent LLTV/IR
combination and a decent crew and you'd have a very dangerous package.
Stealth doesn't mean that it disappears, it menas that the detection
ranges are much shorter.
True. I worked F-111s and F-15s when I was in. Barn doors compared to the
117.
| George Ruch |
| "Is there life in Clovis after Clovis Man?" |
Old January 14th 04, 04:17 AM
Peter Stickney
George Ruch writes:
George Ruch writes:
SA-3 site.
purposes.
Yery dangerous indeed. There are times when the unsophisticated
system is more effective than the new Gee-Whiz stuff. Of course,
system performance of something like an SA-3, SA-2, or Nike-Herc
depends a lot more on crew quality, (and quantity, it takes a lot of
people to run them), and they can get saturated a lot mroe easily.
But it can also take advantage of the pattern recognition wired into
the human brain. In the period leading up to Viet Nam, the Navy put a
lot of effort into deception jammers. (Repeaters & Track Breakers &
such). They consumed less power, and could be made smaller, so you
could fit 'em internally, and not sanitize a pylon carrying a pod. (A
big issue with the F-8 and early A-4s, 'casue they didn't have a lot
of pylons to begin with. And they worked pretty good against our best
systems. The only problem is, that when they were put up against the
the SA-2's Fan Song radars, after a while, they weren't quite as
effective. The manual operators were, with practice, often able to
pick out the true targets from the false ones. The Air Force went in
more for noise jammers, and these tended to work better in that
environment. If you fill the radar's screens with solid noise,
there's nothing to pick out.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old January 15th 04, 10:12 PM
Denyav
:New fighters will have "stealth
:features" but do not meet the military's own definition of 'stealth'.
F35 will probably be the last manned US aircraft employing "passive" stealth
for the survival.
Yeah. You only can't see them up until right after they kill you.
Some 'stealth feature'.
Yeah right,with 600 mile range stand off air-air misilles maybe.
Old January 15th 04, 10:16 PM
Denyav
Obviously, no aircraft is completely invisible to radar, but
when you get down to the RCS of a bird, that is stealth.
Frontal RCS of f22 is even smaller than insects,but that is stealth only for
good old backscatterers.period.
Old January 15th 04, 10:26 PM
Keith Willshaw
"Denyav" wrote in message
stealth
for the survival.
Mainly because its apt to be the last US manned fighter.
Keith
Old January 15th 04, 10:32 PM
Denyav
haphazardly with AA while trying to find the F-117s. The first night of the
first Iraq war, all the F117's came back from their missions without so much
as a scratch.
Lots of of them did not even get to their assigned targets during the first
night of DS I to start with.
If Jammers had not spoofed guided launches aganist some them,world would not
have to wait till balkan for first f117 stratches,thats second.
Iraq,like,Afghanistan,Panama,Zambia,Somalia etc is a backward third world
country,and thats the third point.
RUSSIAN WAR PLANES IN ASIA James Military Aviation 2 October 1st 03 11:25 PM
Vietnam era F-4s Q Ed Rasimus Military Aviation 87 September 27th 03 03:59 PM
[AU] Light plane sparked terror alert David Bromage Military Aviation 41 September 11th 03 05:37 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
