#21
On Jan 21, 1:15*pm, Bertie the Bunyip wrote:
Nope, not in this case. if they didn;t fly the airplane, the holes in the bottom of the airplane would have been the least of their problems, since they would have made significantly larger holes. Bertie ....at last, the magic words. "Fly the airplane". Good on ya, Bertie. |
ah wrote in news:4973fef3$0$57681
: Bertie the Bunyip wrote: wrote in : On Sun, 18 Jan 2009 21:49:45 +0000 (UTC), Bertie the Bunyip wrote: Actually they can in most arplanes. The 'bus has one that will do the whole lot in one go, though. Some old Brit airplanes had the same thing. you know,in case "Gerry snuck up on us over la Manch after a jolly good thrashing of Dresden" Thank you for your answer. There is only one thing: The ditch switch on flight 1549 was not activated as reported by the NTSB interview. You don' tknow that. The crew didn't have time You don' tknow that either. to flick the switch. So, Captain C.B. Sullenberger III is after all just a human being. The plane floated anyway. For a while at least. What about the in-flight tea reserves? Let's not get into the nightmare scenario Bertie |
cavedweller wrote in news:6a07dabb-6fb7-4cdb-9057-
: On Jan 21, 1:15*pm, Bertie the Bunyip wrote: Nope, not in this case. if they didn;t fly the airplane, the holes in the bottom of the airplane would have been the least of their problems, since they would have made significantly larger holes. Bertie ...at last, the magic words. "Fly the airplane". Good on ya, Bertie. ell, it's obvious, even if you're only flying a hang glider... Isn't it? Bertie |
On Jan 21, 12:18*pm, Bertie the Bunyip wrote:
wrote : On Jan 20, 3:51*pm, wrote: On Tue, 20 Jan 2009 09:28:27 -0800 (PST), wrote: Where on the checklist is the instruction to flip this switch? The manual states: At 2000 ft CABIN PRESS MODE SEL.............................Check AUTO ENG 1 & 2 BLEED, APU BLEED.......................OFF P/B DITCHING.....................................ON P/A............................................."TOU CHDOWN IN ONE MINUTE" Aim for an impact with an 11° body angle and minimum ROD. Poster However if you're also working an inflight engine unstart which takes precedence? *Clarification: two engine unstart w/inflight emergency. Quite a bit different from a situation that begins at cruise altitude or with only *one* emergency rather than a sequence of events. *As a PAX I would rather know that the crew are concentrating on landing the aircraft (ditching) as gently as possible. That silly switch won't do a thing to save the buoyancy if the fuselage is fractured by a rough ditching...a point one everyone seems to miss. Exactly. I would hazard (grin) a guess that the final review will show them to have maintained situational awareness with the concomitant priority management. I'd agree, it;'s hard to argue wiht success. Like many accidents of this sort, these gusy will have rewritten the book. Bertie With all my arguments against worrying about the dip, er, 'ditch' switch I wonder of what benefit it would truly be in any condition other dead level calm? Ditching at see would (I would think) most often occur in conditions that would tear up the aircraft sufficiently to make 'the Switch' totally useless. In this particular case it appears, from reading an article early on, that one or more pax may have partially opened a rear door and allowed water ingress and this, more than anything, contributed to the tail down sinking. It all comes down to basic necessities. I've had two high speed parachute malfunctions and my first reaction was "what do I do to get a chute open right f'ing now?" I didn't worry until after that occurred as to wear I would land or what I would have for dinner. You really have to experience something to realize the difference a 'real' emergency will make in your focus. Failure to maintain that focus results in the 'oh ****' moments. |
On Jan 21, 12:09*pm, Bertie the Bunyip wrote:
Flydive wrote : wrote: Low priority compared to flying the plane, deadstick, in a congested urban environment. Or would you rather he spend time looking for a button on the panel? Well it takes 3 seconds to flip the switch, you should know where is located. one pilot is flying the aircraft, the other one is assisting and going through the checklist. Yep, and the checklists can lead you into a workd of trouble. There wasn't time. In this case, a relight checklist was really all they should have been interested in. Bertie I'll bet they had it open to 'foie gras' - goose liver ala Turbine. |
"Bertie the Bunyip" wrote in message ... cavedweller wrote in news:6a07dabb-6fb7-4cdb-9057- : On Jan 21, 1:15 pm, Bertie the Bunyip wrote: Nope, not in this case. if they didn;t fly the airplane, the holes in the bottom of the airplane would have been the least of their problems, since they would have made significantly larger holes. Bertie ...at last, the magic words. "Fly the airplane". Good on ya, Bertie. ell, it's obvious, even if you're only flying a hang glider... Isn't it? Bertie the only thing obvious here is you're a dumb ass wanna be. |
#30
| Thread Tools | |
| Display Modes | |
