On Mar 18, 7:00*am, Darryl Ramm wrote:
It is my impression that many piltos with built in loggers like the Cambridge 302 do not understand that the flight recorder is using cockpit ambient pressure and not the static line-in on the rear of the instrument (only used for airspeed calculations). This is a requirement to prevent the pilot being able to connect to the static line and tamperer with logged pressure altitude. I'm aware of that but I see now that what I wrote may be ambiguous. Perhaps this would have been better: "loggers (which cannot have an external static connection) will read lower than an altimeter which has an external static connection. " Andy |
Perhaps the simple answer is to mount your colibri on the panel and use the
logged altitude reading as your reference for starts, airspace, and finishes. You do however need to know the difference in feet +/- between real QNH/QFE and QNE (1013.2). I write this on a sticky. Jim At 14:31 18 March 2009, Andy wrote: On Mar 18, 7:00=A0am, Darryl Ramm wrote: It is my impression that many piltos with built in loggers like the Cambridge 302 do not understand that the flight recorder is using cockpit ambient pressure and not the static line-in on the rear of the instrument (only used for airspeed calculations). This is a requirement to prevent the pilot being able to connect to the static line and tamperer with logged pressure altitude. I'm aware of that but I see now that what I wrote may be ambiguous. Perhaps this would have been better: "loggers (which cannot have an external static connection) will read lower than an altimeter which has an external static connection. " Andy |
On Mar 18, 7:31*am, Andy wrote:
On Mar 18, 7:00*am, Darryl Ramm wrote: It is my impression that many piltos with built in loggers like the Cambridge 302 do not understand that the flight recorder is using cockpit ambient pressure and not the static line-in on the rear of the instrument (only used for airspeed calculations). This is a requirement to prevent the pilot being able to connect to the static line and tamperer with logged pressure altitude. I'm aware of that but I see now that what I wrote may be ambiguous. Perhaps this would have been better: "loggers (which cannot have an external static connection) will read lower than an altimeter which has an external static connection. " Andy Andy, I had the sense you did know this. My comment was really to the overall thread. The near universal situation will be IGC logger with ambient cockpit pressure (an IGC requirement) and an altimeter with ships' static (a type certification/airworthiness requirement for many (all?) gliders). In which case the warnings from the CD make perfect sense. A Cambridge 302 or other IGC flight recorder that displays pressure altitude or a PDA with pressure altitude being displayed from a logger is the thing to look at if close. But looking for traffic better be more important. Doing a comparison between an altimeter and Cambridge 302 pressure altitude display at different speeds would be interesting and something I want to do for other reasons (but related to ambient cockpit pressure induced altitude errors). Hopefully most pilots will understand many gliders will have three static sources, the fuselage static lines (for altimeter and ASI), static from a multi-function probe (usually for flight computers/ direct reading/digital varios) and ambient cockpit static (used by IGC fight recorders). Pretty nice redundancy and isolation provided by all that. Darryl |
Last Day Seniors USA 2009 #711 reporting | [email protected] | Soaring | 0 | March 15th 09 02:12 AM |
Day 2 Seniors USA 2009 711 reporting. | [email protected] | Soaring | 4 | March 13th 09 01:10 AM |
Seniors USA 2009 #711 reporting. | [email protected] | Soaring | 1 | March 9th 09 02:03 AM |
# 2 Day 05 Seniors USA # 711 reporting | [email protected] | Soaring | 2 | March 11th 05 07:36 PM |
Rules for 1000k with start/finish at midpoint. | Andrew Warbrick | Soaring | 2 | August 10th 04 05:04 AM |
