Marine Radar in a plane?
Old August 11th 03, 04:55 PM
Jay Honeck
Default Marine Radar in a plane?
Yesterday, as we were once again flying blindly toward unknown weather, Mary
and I lamented the fact that we'll never have radar on board our Pathfinder.
Too expensive to contemplate. Ditto with the "live uplink" stuff that's
just coming on the market.
So, I thought, why not adapt a marine radar unit to aircraft use? Checking
around on-line, it looks like you can get a pretty basic marine radar set up
for less than $2000 -- a tiny percentage of what "aviation" radar would
cost.
Anyone tried this in a home-built plane? What's the range of those units?
Installation?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 11th 03, 05:37 PM
JerryK
I thought marine radar was tuned for seeing objects not weather? Things
like radar bouys and other ATONs, and ships in the fog.
Also, I have to say after having radar for 4 years I find radar useful, but
not critical. You still want to keep 20 miles or so from any storm, and
most of the GA sized units can only accurately depict weather at 40 miles.
Much further and the beam is too big.
"Jay Honeck" wrote in message
news:Y7OZa.121718$uu5.17371@sccrnsc04...
Mary
Pathfinder.
Checking
up
cost.
Installation?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old August 11th 03, 07:24 PM
Ross Oliver
cost.
I have always heard that a lightning detector such as StrikeFinder
or Stormscope works just as well as radar for thunderstorm avoidance,
and is more compact and less expensive than full-blown weather radar.
Eastern Avionics website lists several models for $3-6000 plus
install.
Ross Oliver
Old August 11th 03, 09:14 PM
Bob Gardner
Radar reflects energy from something more or less solid...like a cloud full
of water. Sferics devices detect electrical discharges. They are two
different systems performing two different functions by measuring different
parameters. The ideal is to have both. If you have only one, you must
understand its limitations. A sferics device will not keep you from flying
into an ice-filled cloud, and radar will not detect clouds that do not
contain droplets of a certain diameter relative to wavelength.
Belt and suspenders.
Bob Gardner
"Ross Oliver" wrote in message
Mary
Pathfinder.
Checking
up
cost.
install.
Ross Oliver
Old August 11th 03, 10:17 PM
Peter Duniho
Granted, I know very little about marine radar, but just given the
application, I'd suspect that it would not have characteristics suitable for
aviation. For one, all of the marine radar installations I've seen use a
rotating antenna, which would be hard to find a place to mount on a plane.
Beyond that, I don't know what the range of a cheap marine radar is, but
I'll bet it's significantly shorter than an aviation unit. Also, my
understanding is that marine radar is designed to optimize imaging of other
watercraft and coastlines, not weather.
Far be it from me to dissuade someone from trying. But I sure wouldn't hold
my breath waiting to see if they were successful.
I'd rather have both radar and lightning detection, but I agree that the
lightning detection gives you much more utility for the money.
Pete
Old August 12th 03, 04:06 AM
Richard Kaplan
Mary
Pathfinder.
Strikefinder or Stormscope would be far more useful than radar in a
single-engine plane.
My RDR-160 radar was the worst investment I ever made in my plane. CBAV is
far more useful, and certainly the newer portable and panel-mount datalink
systems seem to have the potential to beat CBAV.
Saying my radar has a range of 160 miles is a cruel joke; its range is
really only 40-50 miles, and even then it only works that far out if there
is a strong storm around. No piston airplane has the speed or altitude
capability to pentrate a line of thunderstorms and thus any piston plane can
get boxed in if a hole closes in from behind while trying to use radar to
find "holes" in storms.
Richard Kaplan, CFII
www.flyimc.com
Old August 12th 03, 10:15 AM
pac plyer
I bet your Radar does have a 160 mile range. What altitude were you
at? Because of the curvature of the earth that set's going to
attenuate badly down low. You probably can't use the 160 range
effectively till you get up much higher like over 10,000AGL. Even
jets have to step the range down as they get lower. Bob's right:
using the set correctly is quite an art. Many copilots I've flown
with can't do it right. For some reason, radar training is kind of a
lost art.
Best Regards,
pacplyer
Old August 12th 03, 10:28 AM
B2431
lost art.
Best Regards,
pacplyer
You mean you can't just turn it up until the crew chief smokes then back off a
little when doing ground checks?
When I worked on C-130s we'd occassionally get called out because the guy
couldn't see the sweep. We'd simply reach over his shoulder and turn up the
intensity.
Dan, U. S. Air Force, retired
Old August 12th 03, 06:30 PM
JerryK
The RDR-160 has a 160 mile setting but the beam is huge at anything over 40
miles. At 40 miles it is something like 40,000 feet tall. So anything in
the range is going to get hit and might return. So if you try to use tilt
for identifying anything much beyond 40 miles (next settings are 80, 120 and
160) you are painting with a very big brush, and with limited power
(compared to big iron). The joys of 10 or 12 inch antennas.
With that said it is still nice to know what is out there are 40 miles or
so. I just wish it painted a better picture further out.
"pac plyer" wrote in message
om...
is
datalink
there
can
to
lost art.
Best Regards,
pacplyer
Old August 12th 03, 09:54 PM
Nick Funk
I am not an expert! But I have several friends, both of which are
ex-military pilots. One owns a C310 with radar and stormscope and the
other friend has a C210 with radar and stormscope.
Both agree that given a choice they would rather have the stormscope
over radar any day. They reason they said is that the stormscope
displays lightning and electrical disturbance and that is exact where
the worst convective air is. Radar only shows where water is. Simply put
convective air kills and rain doesn't.
cost.
Installation?
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 9th 04 04:47 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 09:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 07:27 AM
