#31
Subject: B-17s at Low Level
From: "M. H. Greaves" Date: 3/14/04 3:40 AM Pacific "and i hope you didnt bring any bombs back"!! Nope never did. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
#32
Not that it applies to the B-17, but I would think that unless hydraulic
flaps were preloaded (spring or other or were heavy) to extend without hydraulic pressure, the airflow would keep them retracted until airspeed decreased or even until the a/c got on the ground. As for the gear, unless it was kept in the retracted position by hydraulic pressure alone, as on many modern light aircraft, the mechanical uplocks would keep the gear up. Also, depending on gear door operation, the airflow could very well keep the doors closed, or at least partially closed, until airspeed decreased. Lack of pressure could also just allow the doors to stay closed & the gear stay up regardless, depending upon how they're actuated. |
#33
Dale writes: In article , "Gord Beaman" ) wrote: Dale, with some time on them I'm sure that you'd agree that when limping home on two engines having your flaps or gear down would very likely ruin your chances of ever getting home, right?. At the weights I flew the airplane it performed fairly well on two engines, even so why stack the deck against yourself by adding drag. G On a hot day, or high field elevation having the gear/flaps out could certainly make a difference in the outcome. There was a bunch of discarded ammo and .50s from the continent to England for a reason. G And Ball Turrets, as well. If you're hedgehopping across Belgium, it's a fiar bet that if you could, you'd jettison the Ball Turret. That would leave off something arounf 1500#. IIRC, the procedure was to pull the traversing motor (that drives the pinion that engafges the traversing ring gear that's on the edge of the fuselage hole for the turret, and undo the retainer that holds the spindle for the turret yoke to the fuselage bracket. Takes about 5 minutes with a wrench, hammer, and chisel. The end result would be no turret, the fuselage mounting bracket in place, and teh ring gear at the turret opening. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
#34
My question is, would a B-17 have its landing flaps deployed at all at this
lower speed and altitude if it was not landing, just hedge-hopping home? And if so, how much? no, the flaps on the -17 were mostly drag devices, and did not help generate lift. Matt Gunsch, A&P,IA,Private Pilot Riding member of the 2003 world champion drill team Arizona Precision Motorcycle Drill Team GWRRA,NRA,GOA |
#35
Unless of course the hydraulic system has been shot out in which case both
flaps and landing gear would be down. As I vaguely remember it that hydraulic sytem in a B-17 worked off one engine.I don't remember which one. But I might be wrong about that, You are, the only hydraulics on a -17 are cowl flaps and brakes, everything else is electric. Boeing was even thinking ahead, all the gear and bombay motors were the same. Matt Gunsch, A&P,IA,Private Pilot Riding member of the 2003 world champion drill team Arizona Precision Motorcycle Drill Team GWRRA,NRA,GOA |
#37
#38
#39
Dale wrote:
In article , (N329DF) wrote: no, the flaps on the -17 were mostly drag devices, and did not help generate lift. Well, they help a little. Book shortfield procedure calls for 10-20 degrees of flap. Flaps do allow you to liftoff a little sooner/slower. Of course, most a/c use some flaps for takeoff but it would have only a detrimental effect (I'm pretty sure) at cruise...I know two pilots who will swear on their mothers' grave to this.... Cruising along on a 'boring holes' exercise (quite boring indeed) a couple pilots and I were discussing the possibilities of this...my position was that even a couple degrees of flap would be detrimental, one of the pilots was 'certain' that it would help, the other was undecided. We had quite a discussion going and ended up with a substantial bet between I and the sure guy, to be paid in beer at the next squadron bash. (all that one can drink - woohoo) We were at 'range power', an airspeed that produces maximum range at the particular weight. we had been there for long enough that our airspeed was stable, co-jo inched down a couple degrees of flap (very slowly and carefully) I waited a few seconds then carefully inched the cowl flaps open quite a few degrees. Airspeed slowly decreased...co-jo inched the flaps back up and I followed by inching the cowl flaps closed. We did this several times till he was convinced. (the pilots cannot see the cowl flap position gauges nor the switches which are behind them on the F/E's panel on the Argus. I never did tell them different. Fun. -- -Gord. |
#40
"Gord Beaman" ) wrote: Airspeed slowly decreased...co-jo inched the flaps back up and I followed by inching the cowl flaps closed. We did this several times till he was convinced. (the pilots cannot see the cowl flap position gauges nor the switches which are behind them on the F/E's panel on the Argus. I never did tell them different. Fun. You're a baaaad boy!! G -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Horsepower required for level flight question... | BllFs6 | Home Built | 17 | March 30th 04 12:18 AM |
Q for Jim Weir or others: solid state fuel level probes? | Charlie England | Home Built | 11 | March 12th 04 12:35 AM |
Heads up: threat level going to orange | richard riley | Home Built | 6 | December 23rd 03 10:49 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
