#41
... On Tue, 3 Nov 2009 06:55:10 -0800 (PST), wrote: On Nov 2, 11:08 pm, wrote: Define "substantial" and a fuse or breaker WILL disconnect it if something goes wrong. And if that fuse or breaker is in the cockpit, you still have a live feed to it even if it trips. If it's next to the battery somewhere else, you can't shut it off, reset it or replace it in flight. Dan NEVER attempt to replace a fuse in flight. Assume it blew for a reason. Concentrate on flying the plane, not fixing it, until you are on the ground. The ASSumption was the fuse is at the battery. Anywhere else it is USELESS for protecting the wire. Generally true, especially for a main electrical circuit, and there is an excellent argument for always placing a fuse as near as practical to the power source and sized to protect the wire. I would also replace the fuse at each annual--since "everything" corrodes in the climate where I live--as a way to assure that any failure of the fuse is indeed for a reason; because the 2 or 3 year replacement cycle, that a reasonable person would expect, would only assure that the replacement will be forgotten and that corrosion will cause the fuse to heat and fail. (When I was growing up, we leared to keep our spare household fuses in tightly sealed glass jars so that they would remain serviceable when needed.) There are a couple of exceptions to the "do not replace" and "do not reset" rules--the classics being the need to retract the flaps in order to "go around" or, on some airplanes, to lower the wheels. Peter |
#42
On Tue, 3 Nov 2009 16:01:25 -0500, "Peter Dohm"
wrote: wrote in message .. . On Tue, 3 Nov 2009 06:55:10 -0800 (PST), wrote: On Nov 2, 11:08 pm, wrote: Define "substantial" and a fuse or breaker WILL disconnect it if something goes wrong. And if that fuse or breaker is in the cockpit, you still have a live feed to it even if it trips. If it's next to the battery somewhere else, you can't shut it off, reset it or replace it in flight. Dan NEVER attempt to replace a fuse in flight. Assume it blew for a reason. Concentrate on flying the plane, not fixing it, until you are on the ground. The ASSumption was the fuse is at the battery. Anywhere else it is USELESS for protecting the wire. Generally true, especially for a main electrical circuit, and there is an excellent argument for always placing a fuse as near as practical to the power source and sized to protect the wire. I would also replace the fuse at each annual--since "everything" corrodes in the climate where I live--as a way to assure that any failure of the fuse is indeed for a reason; because the 2 or 3 year replacement cycle, that a reasonable person would expect, would only assure that the replacement will be forgotten and that corrosion will cause the fuse to heat and fail. (When I was growing up, we leared to keep our spare household fuses in tightly sealed glass jars so that they would remain serviceable when needed.) There are a couple of exceptions to the "do not replace" and "do not reset" rules--the classics being the need to retract the flaps in order to "go around" or, on some airplanes, to lower the wheels. Peter A good reason to have manual flaps - and a non-electric "emergency" wheels down mechanism. If the fuse blew for a reason, you want to be able to get the wheels down - WITHOUT electricity |
| Thread Tools | |
| Display Modes | |
| Master cylinders | [email protected] | Home Built | 25 | July 29th 08 03:08 AM |
| Battery Contactor Diode? | Skrud | Home Built | 25 | September 11th 06 07:17 PM |
| PA28-180 Power Contactor Relay source? | Mike Noel | Owning | 5 | August 10th 05 05:40 AM |
| Master Switch | Lakeview Bill | Piloting | 23 | July 20th 05 02:46 AM |
| RC Plane Master | Steve | Simulators | 0 | December 20th 03 03:40 PM |
