I give up, after many, many years!
Old May 20th 08, 07:22 PM posted to rec.aviation.piloting
Maxwell[_2_]
Default I give up, after many, many years!
You're a forger, a liar and a cross posting ass hole.
If I'm lying, prove it. You are already a known liar.
  #502
Old May 20th 08, 07:59 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"Ken S. Tucker" wrote in message
news:c47ef4b0-754f-42b8-bdb5-
Mr. Potato Head, we don't put a big blob of flammable
material in a cock-pit, your sci-phy-math-chem education
is a functional Gr.10.
Whew, that's good to know. I always thought that dripping form the primer
was gasoline.
  #503
Old May 20th 08, 08:36 PM posted to rec.aviation.piloting
Mxsmanic
Default ATC assigned altitude?
Nomen Nescio writes:
Bummer.
It would be fun to fail damn near everything (flight and nav instruments) and
try getting down with marginal instrumentation and ATC vectors.
ATC will be happy to do that if they aren't too busy. Both pilots and
controllers enjoy the practice. Unfortunately, most pilots declaring an
emergency just want attention and priority, not help.
  #504
Old May 20th 08, 08:40 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Steve Foley writes:
What happens if you do not follow their instructions?
You can be disciplined, which can include a suspension or ban from the network
for serious offenses.
Do they have a virtual destruct button to remove you from their airspace?
No, although that has been discussed.
  #505
Old May 20th 08, 08:43 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
MSFS does not even "simulate" an updraft. And, as far as I can tell, the simulated
"turbulence" is nothing more than a random number generator that rolls the
wings a little bit left or right.
Try ActiveSky, which does these things. It also simulates wake turbulence.
You have to because your game gives you nothing else to work with.
Under IFR, I'm not supposed to work with anything else.
That's also the reason it lets you do a "successful landing" that
would trash a real plane.
Not if you are using the right aircraft and you have crashes enabled. I once
damaged my flaps simply by making a somewhat firm landing, and I've damaged
gear on several occasions.
  #506
Mxsmanic
gatt writes:
You wouldn't know. You haven't done it.
It is rather exhaustively documented.
  #507
Old May 20th 08, 08:44 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
gatt writes:
I quoted you chapter and verse directly from the FAA, and you
contradicted it, liar.
The FAA is not saying what you claim.
  #508
Old May 20th 08, 08:46 PM posted to rec.aviation.piloting,rec.aviation.student
Ken S. Tucker
was gasoline.
You should fix you drip.
Ken
  #509
Old May 20th 08, 08:51 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"Mxsmanic" wrote in message
I once
damaged
I guess you're not very good at it.
  #510
Old May 20th 08, 09:01 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Steve Foley writes:
I get better all the time.
DC-3 parts to give away Robert Little Restoration 2 November 23rd 06 03:30 AM
Who can give a checkout? Mark S Conway General Aviation 2 May 9th 05 12:15 AM
Winch give-away KP Soaring 6 January 11th 05 08:04 PM
Did you ever give up on an IR? No Such User Piloting 24 November 26th 03 02:45 PM
FS 2004 give away Ozzie M Simulators 0 November 23rd 03 03:50 PM
