My instructor has me doing power out simulted emergency spot landings
in prep for my checkride. I've already had my checkride put back once cause I'm not getting them right often enough. Did some more today but still not 100%. Does anyone ahve any tips? He wants me to land on the numbers. I can sometimes do it 2 or 3 times in a row but next time, I'll be 100 ft too high or just a little too low Rich |
You know about the dirty spot method, right? Find (or make) a spot on the
windscreen...maintain a constant descent path with that spot 50-75 feet from the point on which you want to land. If it moves away from you, you are too high...if it moves off of the runway and into the grass, you are too low. Bob Gardner "Richard Thomas" wrote in message .. . My instructor has me doing power out simulted emergency spot landings in prep for my checkride. I've already had my checkride put back once cause I'm not getting them right often enough. Did some more today but still not 100%. Does anyone ahve any tips? He wants me to land on the numbers. I can sometimes do it 2 or 3 times in a row but next time, I'll be 100 ft too high or just a little too low Rich |
Bob Noel wrote:
get a glider rating. Spot landing a glider is fairly trivial whith those spoilers which let you adjust the glide angle from 1/40 to 1/7 or so without slipping. Those spam cans have way more momentum and no spoilers. Of course you can slip them. Stefan |
In rec.aviation.student Stefan "stefan"@mus. invalid .ch wrote:
Bob Noel wrote: get a glider rating. Spot landing a glider is fairly trivial whith those spoilers which let you adjust the glide angle from 1/40 to 1/7 or so without slipping. Those spam cans have way more momentum and no spoilers. Of course you can slip them. There's also no altitude penalty for closing the spoilers once you have them open so you can continously adjust them during the approach. This makes them work more like a throttle than flaps. Push the lever forward to go further, pull it back to go down. :-) Boris |
"Richard Thomas" wrote in message .. . : My instructor has me doing power out simulted emergency spot landings : in prep for my checkride. I've already had my checkride put back once : cause I'm not getting them right often enough. Did some more today but : still not 100%. : : Does anyone ahve any tips? He wants me to land on the numbers. I can : sometimes do it 2 or 3 times in a row but next time, I'll be 100 ft : too high or just a little too low Go gliding! Your circuit planning will improve out of sight... -- George Black http://www.koekejunction.hnpl.net/ |
"Richard Thomas" wrote in message .. . My instructor has me doing power out simulted emergency spot landings in prep for my checkride. I've already had my checkride put back once cause I'm not getting them right often enough. Did some more today but still not 100%. Does anyone ahve any tips? He wants me to land on the numbers. I can sometimes do it 2 or 3 times in a row but next time, I'll be 100 ft too high or just a little too low Rich The real key to it is to keep the intended landing point from moving up or down. It should be stationary as you approach on final and kept still for as long as possible until you're preparing to touch down (don't fly the plane directly down onto the intended landing point, however - that can happen if you're not concentrating and you don't flare correctly... not good) The other main thing is to be aware of what the airplane is doing as you're keeping that landing point stationary. If you're having to hold too high of an airspeed, then you have an excess of energy that you need to dissipate. The cheezy way to do it is to just dive a bit until the glideslope flattens a bit and then resume your approach airspeed (although not cheezy in my aircraft type which is incapable of slips - that's pretty much my only option). Don't do this on the checkride or even with the CFI on board - they'll slap you upside the head and with good reason. The much better way is to use a slip or, if you're sure you have it made, adding flaps, to accellerate energy dissipation and get you on glideslope without building up too much airspeed. If, on the other hand, you're having to hold too low of an airspeed to keep the landing point from moving up, you don't have enough energy to make it there and you're going to come up short. But that's basically it. What you want to achieve is a stationary landing point (up/down wise) at the correct glide angle (i.e. correct airspeed). That will get you very close to the ballpark and depending on how good you are with the flare, you should touchdown very near the intended landing spot. So, it's really pretty simple. You just have to keep practicing it until you get it down. Energy management without power is a somewhat different skill than with. With one less control, you have to do things a little different with the remaining controls.... LS AC fun racer 503. |
Don't you lose the "dirty spot" when you're slipping? all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"Cub Driver" wrote in message ... Don't you lose the "dirty spot" when you're slipping? My last 3-axis airplane didn't have a windsheild, so there was no dirty spot to lose . Just kept my eyes on the landing spot and kept it from moving,whether I was in a slip or not.... LS AC fun racer 503. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Cub Driver wrote in message . ..
Don't you lose the "dirty spot" when you're slipping? I have my students come out of the slip every once in a while to recheck their "dirty spot". |
| Thread Tools | |
| Display Modes | |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 06:40 PM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 06:40 PM |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
