Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin on Turnfrom Base to Final' mutually exclusive?
Old November 29th 16, 12:46 AM posted to rec.aviation.soaring
Andrzej Kobus
Default Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin onTurn from Base to Final' mutually exclusive?
One important factor is speed: As we all know, aircraft fall if a wing or a large part of it goes too slow.
The glider does not stall because you fly too slow, it stalls because the wing reaches a critical angle of attack. That is why when you deflect an aileron you can stall a good chunk of a wing.
Old November 29th 16, 02:12 AM posted to rec.aviation.soaring
George Haeh
Default Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin on Turn from Base to Final' mutuall
Fly into the top of a rotor in the same direction as the circulation
and you will gain some altitude, lose airspeed and increase alpha
- then deal with the consequences.
Old November 29th 16, 01:27 PM posted to rec.aviation.soaring
Bruce Hoult
On Monday, November 28, 2016 at 10:23:01 PM UTC+3, danlj wrote:
This question has generated a long string of notes about the landing pattern & few about the stall.
Why would an intelligent, thoughtful pilot like us go too slow when close to the ground (turn to final)?
Because of the vection (false motion) illusion.
At 1000ft/300 meters, the ground passes by slowly. At 200ft/60 meters, the ground passes more swiftly and *it feels as though we have sped up*!
Only with frequent glances at the ASI can we be confident of not having to respond to one of Tom Knauf's six signs of the stall. The seventh of which is the ground rushing up and the controls being all floppy.
This is independent of the shape of the circuit pattern...
This may be a factor for flatland pilots, who spend only a few seconds each flight flying near to the ground.
Many of us are flying near to ridges from the first flight of our training. If there is a wind and a suitable ridge near the airfield then pretty much every training flight will be doing this, especially in the winter. The concept of "safe speed near the ground" and how to judge it is drummed in to the student continuously.
Old December 17th 16, 11:36 PM posted to rec.aviation.soaring
Duster
Recent AOPA online article on the topic of "continuous" base/final pattern turn (apologies if this was noted previously)
https://www.aopa.org/news-and-media/...-pattern-study
Downwind to final turns Jonathan St. Cloud Soaring 18 June 7th 15 02:19 PM
Base to Final - Fatal Orval Fairbairn[_2_] Piloting 0 August 8th 10 03:23 AM
The Art of Racing - Final Turn.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 February 27th 10 12:42 PM
Final Approach, pt 3 - KFME final.jpg (1/1) Mitchell Holman[_3_] Aviation Photos 0 April 8th 09 12:56 PM
Turn to Final - Keeping Ball Centered skym Piloting 224 March 17th 08 03:46 AM
