A careful read of the Minden accident report will reveal what two very
experinced pilots did. The owner P1 was a famous glider pilot, and P2 was a WW II trained Naval Aviator, also famous. Eyewitness reports (in the NTSB report) stated that the rotation had stopped, the glider nosed down, then the wings bent up to about 45 deg, then failed. The spoilers were found actuated. The wings broke just outboard of the spoiler. The report refers to an interconnction between the flaps and the spoiler, full spoiler also produces full flap. The report also states time for the glider to accelerate to Vne and Vd, indicating quite rapid acceration. Further in the report it is indicated that the N4DM was certified by JAR with exceptions for stall/spin behavior. The implication is that the pilot(s) stopped the yaw, the glider dropped it's nose and started accelerating as expected, and then at or above Vd, spoilers were actuated, and the wings broke. Neither pilot got out. The Spanish accident reports notes that the spoilers were found in the locked position. So, in summary, one pilot pulled the stick and broke the aircraft, and one pilot pulled the spoilers and broke the aircraft. Faced with going through Vd and breaking the aircraft, or trying to recover and breaking the aircraft--maybe the best chioce is to jump while it's still intact? -- Hartley Falbaum "Robert William" wrote in message ... At 02:06 24 June 2005, Andreas Maurer wrote: On Thu, 23 Jun 2005 16:34:41 -0500, Bob Johnson wrote: Frankly spoken, pulling the stick back hard enough to break off the wings shows that the pilot was lacking the most basic skills to fly that bird. well, possibly, but having got to the position where you could either go through Vd or pull back what would YOU do? |
HL Falbaum wrote:
Further in the report it is indicated that the N4DM was certified by JAR with exceptions for stall/spin behavior. How so? You cannot get a glider certificated without adhering to all JAR 22 requirements. So, in summary, one pilot pulled the stick and broke the aircraft, and one pilot pulled the spoilers and broke the aircraft. Wrong. Neither of the two would have done any damage. They broke the glider by doing both things at the same time. Stefan |
Stefan writes
Wrong. Neither of the two would have done any damage. They broke the glider by doing both things at the same time. No. With the Spanish tragedy the pilots didn't open the airbrakes but the P1 broke the wings by pulling back too hard. Presumably it wasn't necessarily Vne that broke the wings but excessive load (pulling back too hard in a panic) once past maximum maneuvouring speed? Given the P1's self-confessed lack of currency in spin-training (paraphrased from memory; "did it once twenty years ago and swore never again") is it fair to say that without the panic from an unpractised situation the spin and resulting dive recovery might not have broken the wings? Limiting your spin recovery to just pulling back hard is going to have unfortunate consequences which ever way it turns out. That said, it was a terrible thing to happen and my heart really does go out to the pilot and his family. The Minden tragedy involved opened airbrakes which in turn contributed to breaking the wing. Still from pulling back too hard, but in quite different circumstances where "too hard" might not have been so apparent because of the reduction in wing area and thus perceived wing-loading. But had the airbrakes not been out the wing might have sustained the load. Though Vne may then have been passed. So it would seem the answer is to not open the airbrakes but respect the yellow band on your ASI when loading the aircraft with g. Even if this means passing through Vne? Or, if you do open the airbrakes in a last ditch attempt to avoid breaching Vne be even more respectful with the loading when pulling out of the dive. But, between the devil and the deep blue sea you're better off not having stepped out onto the gunwale in the first place ![]() -- Bill Gribble http://www.scapegoatsanon.demon.co.uk - Learn from the mistakes of others. - You won't live long enough to make all of them yourself. |
Bill Gribble wrote:
But, between the devil and the deep blue sea you're better JAR 22 requires that a glider can be recovered from a spin of at least 5 full turns (or the number at which the spin transfers to a spiral, if that number is smaller) by applying the "standard procedure" and without exceeding the load limits. Last I've heard there are a couple of Nimbi 4DT registered in Germany and other European countries. Which means they are JAR certificated, hence... Stefan |
I would question the 99% but surely theproblem is that
the 1% tend to be spectacular, and stings a bit. At 02:06 24 June 2005, Andreas Maurer wrote: On 23 Jun 2005 21:27:25 GMT, Don Johnstone wrote: Now here's a question. Given the answer above why when the wing drops at the start of a take off run (winch or aero-tow) does everyone almost without exception try and lift the downgoing wing with aileron? .... because it works in 99 percent of the cases? Bye Andreas |
At 22:24 23 June 2005, Ian Johnston wrote:
snip OK, so how would you described the difference. How far does the wing have to drop before /you/ use spin recovery rather than stall recovery? I'm genuinely interested: it's not supposed to be a trick question in any way. Ian Its not about how far the wing has dropped, its about whether the glider has started to rotate about the dropped wing. A wing drop stall has a lot of roll, some pitch but not much yaw so your first action is to unstall the wings by moving the stick forward. If you've been slow to intiate the recovery, the glider will start to yaw/rotate around the dropped wing and once this has happened, your first action should be full opposite rudder. Ed |
Edward Lockhart writes
Its not about how far the wing has dropped, its about whether the glider has started to rotate about the dropped wing. I think //that's// the answer the question was looking for. If you've been slow to intiate the recovery, the glider will start to yaw/rotate around the dropped wing and once this has happened, your first action should be full opposite rudder. Or the nose drop self-corrects the stall and the glider develops into a spiral dive, in which case centring the controls and kicking in a boot-full of opposite rudder is only going to delay recovery in the face of a now rapidly approaching Vne. Despite knowing the difference, being practised and familiar with the characteristics, recovery and differences of both, it's the prospect of mistaking a spiral dive for a spin in the adrenaline rush of the moment that actually still scares me, despite the fact that I quite enjoy being upside down in a glider ![]() -- Bill Gribble http://www.scapegoatsanon.demon.co.uk - Learn from the mistakes of others. - You won't live long enough to make all of them yourself. |
At 15:12 24 June 2005, Stefan wrote:
HL Falbaum wrote: Further in the report it is indicated that the N4DM was certified by JAR with exceptions for stall/spin behavior. How so? You cannot get a glider certificated without adhering to all JAR 22 requirements. So, in summary, one pilot pulled the stick and broke the aircraft, and one pilot pulled the spoilers and broke the aircraft. Wrong. Neither of the two would have done any damage. They broke the glider by doing both things at the same time. Stefan No, in the accident in Spain which started this thread, all evidence points to the brakes not being deployed, at all. |
Andrew Warbrick wrote:
No, in the accident in Spain which started this thread, all evidence points to the brakes not being deployed, at all. Please read the thread before commenting. HLF, to whom I was responding, was explicitely referring to the Minden accident. Stefan |
I agrre with most of this except the exceed VNe bit.
The damger from exceeding VNe is flutter and flutter WILL break the aircraft. I think the last paragraph is the only option. The only time a pilot (test pilots excepted) is likely to experience a spin in a big wing aeroplane is if it happens accidentally. Non aerobatic means no deliberate spinning (in the UK anyway) which means there is no opportunity to practice. Makes prevention and early recognition even more vital. At 16:00 24 June 2005, Bill Gribble wrote: Stefan writes Wrong. Neither of the two would have done any damage. They broke the glider by doing both things at the same time. No. With the Spanish tragedy the pilots didn't open the airbrakes but the P1 broke the wings by pulling back too hard. Presumably it wasn't necessarily Vne that broke the wings but excessive load (pulling back too hard in a panic) once past maximum maneuvouring speed? Given the P1's self-confessed lack of currency in spin-training (paraphrased from memory; 'did it once twenty years ago and swore never again') is it fair to say that without the panic from an unpractised situation the spin and resulting dive recovery might not have broken the wings? Limiting your spin recovery to just pulling back hard is going to have unfortunate consequences which ever way it turns out. That said, it was a terrible thing to happen and my heart really does go out to the pilot and his family. The Minden tragedy involved opened airbrakes which in turn contributed to breaking the wing. Still from pulling back too hard, but in quite different circumstances where 'too hard' might not have been so apparent because of the reduction in wing area and thus perceived wing-loading. But had the airbrakes not been out the wing might have sustained the load. Though Vne may then have been passed. So it would seem the answer is to not open the airbrakes but respect the yellow band on your ASI when loading the aircraft with g. Even if this means passing through Vne? Or, if you do open the airbrakes in a last ditch attempt to avoid breaching Vne be even more respectful with the loading when pulling out of the dive. But, between the devil and the deep blue sea you're better off not having stepped out onto the gunwale in the first place ![]() -- Bill Gribble http://www.scapegoatsanon.demon.co.uk - Learn from the mistakes of others. - You won't live long enough to make all of them yourself. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
