I have flown it 6~7 times now, and still find starting the engine of
new Cessna 172S quite tricky, and often I have to try two or three times to start it. I never had problem in older C172s. So what's the trick, guys? How much throttle (1/8, 1/4 or 1/2 inch) do you open? How fast do you advance the mixture when the engine starts to fire? Anthing else? Thanks |
Well I think each airplane is slightly different.
However I fly most the newer 172SP, and what I have found is that you need to prime (Fuel pump on, mixture rich) for a little longer than what the POH specifys. Otherwise it just cranks, and cranks while of course the fuel that was there to prime it is now gone, so you restart the process but this time you use even less prime because you think you have primed plenty the first time. Which makes the issue worse. Also make sure you have 1/4 throttle, any less and it may be have enough to get it going. As far as when to advance the mixture.... As soon as it first starts to catch, advance it in all the way, rather quickly but smoothly. One thing you DO NOT want to do (I learned this the easy way, by watching my instructor do this) is pump the throttle open and close to force prime it. We (rather he) tried this method and we started smelling fuel, we got out and saw a puddle of fuel near the front wheel. We waited 5 mins and it finally started. |
Having three hands helps a bit.
WBR "navghtivs" wrote in message oups.com... I have flown it 6~7 times now, and still find starting the engine of new Cessna 172S quite tricky, and often I have to try two or three times to start it. I never had problem in older C172s. So what's the trick, guys? How much throttle (1/8, 1/4 or 1/2 inch) do you open? How fast do you advance the mixture when the engine starts to fire? Anthing else? Thanks |
navghtivs wrote: I have flown it 6~7 times now, and still find starting the engine of new Cessna 172S quite tricky, and often I have to try two or three times to start it. I never had problem in older C172s. So what's the trick, guys? How much throttle (1/8, 1/4 or 1/2 inch) do you open? How fast do you advance the mixture when the engine starts to fire? Anthing else? Thanks I prime it per the manual, then start it with the throttle closed. If it does not start immediately, I crack the throttle ever so slightly, leave the fuel pump on, and start it. If the engine tries to die after starting, I leave the fuel pump on until it warms up. Pretty much all of this can be found in the manual. Most people who have trouble starting C172s have tried to learn to start the airplane by using the checklist without first gaining a thorough understanding of what the manual says. There are way too many instructors who fall into that category. |
On 5 Sep 2005 08:40:45 -0700, "navghtivs"
wrote: I have flown it 6~7 times now, and still find starting the engine of new Cessna 172S quite tricky, and often I have to try two or three times to start it. I never had problem in older C172s. So what's the trick, guys? How much throttle (1/8, 1/4 or 1/2 inch) do you open? How fast do you advance the mixture when the engine starts to fire? Anthing else? Thanks I rent from a Cessna dealer FBO at VNY. The procedure there is: Throttle - open 1/4 inch Mixture - Idle Cutoff Propeller area - Clear Master Switch - ON Beacon - ON Aux Fuel Pump - ON Mixture - Advance full - 2 to 3 seconds, then return to Idle Cutoff Aux Fuel Pump - OFF Ignition - START Mixture - Advance full, when engine fires Works every time for me. BTW... same procedure when the engine is hot - EXCEPT - Mixture - advance full - 1 second, then return to Idle Cutoff. Ron Kelley |
OP wrote:
I rent from a Cessna dealer FBO at VNY. The procedure there is: Throttle - open 1/4 inch Mixture - Idle Cutoff Propeller area - Clear Master Switch - ON Beacon - ON Aux Fuel Pump - ON Mixture - Advance full - 2 to 3 seconds, then return to Idle Cutoff Aux Fuel Pump - OFF Ignition - START Mixture - Advance full, when engine fires Works every time for me. I take it from the procedure the new 172s are fuel injected? -- Mortimer Schnerd, RN VE |
| Thread Tools | |
| Display Modes | |
| Starting Prop Engines in FS2002 | [email protected] | Simulators | 3 | August 30th 04 03:54 PM |
| Starting Engine Question (O-320, Warrior) | Lisa | Piloting | 13 | April 1st 04 07:45 AM |
| New A&P: Typical Starting Salary Range ? | Robert11 | General Aviation | 1 | February 6th 04 10:02 PM |
| Hot Starting Fuel Injected Engines | Peter Duniho | Piloting | 23 | October 18th 03 03:50 AM |
| Boeing 307 Starting Up! | Jay Honeck | Piloting | 5 | August 8th 03 07:53 PM |
