Introduction: Hello everyone.
Old February 16th 06, 11:50 PM posted to rec.aviation.homebuilt
Default Introduction: Hello everyone.
Hello everyone,
I'd like to introduce myself to the group since I'll probably
be around here for a while. I've been lurking for the last several
months.
My name is Don, and I'm a retired electrical engineer / business owner
from Austin, TX. I soloed a Cessna 150 in 1973, and took my check ride
in a Grumman Cheetah in 1976. IFR rated in 2003, so that makes me a
slow learner I guess. I was sixteen in 1973, so those of you who are
good at math can figure out that I'm somewhere between "been there" and
"old fart".
My dad talked me out of buying a BD-5 kit in the 70's (whew!)
I'd really like to build something like a pressurized turboVelocity with
the VNE pushed up to 250kts. I'd also like it to have a built in
ballistic chute system which jettisons the engine (to its own chute)
before deployment.
Realistically, I'm more likely to buy something that already flys, but
you never know. Right now, I'm in the middle of house remodeling, and
my wife looks daggers at me when I even talk about airplane kits ;-)
Looking forward to learning something from those of you who aren't
scared of your wives...
Don W.
Old February 17th 06, 12:46 AM posted to rec.aviation.homebuilt
"Don W" wrote in message . com...
Hello everyone,
months.
"old fart".
before deployment.
Don W.
Hello Don from someone who first soloed in a C-150 in '75. I now have BD4 parts in the hanger that my wife insisted
that I buy. Lucky me!
Dan DeVillers
http://www.ameritech.net/users/ddevillers/start.html
Old February 17th 06, 01:55 AM posted to rec.aviation.homebuilt
before deployment.
Welcome, Don!
Wow, you really want to jump in, huh? g
Realistically, getting the engine out sounds like such a complicated task,
as to be un-do-able in a plane of this size, and probably even in a much
larger size.
You have to sever the fuel lines/fuel system, in a running engine, and that
sounds like fire.
You have to get the engine mounts separated, and that sounds like explosive
bolts in a hot environment, and they need to be 110% reliable. Problems
there.
The engine has to have all of the other systems separate cleanly, and the
cowl get out of the way. Reliability problems, it would seem to me, since
they also have to be assured to not separate during normal operations.
How would it jettison? Rocket type of things, like an ejection seat? That
is a pretty volatile system, and it would have to put up with the difficult
environment of the engine compartment.
There is certainly more to consider, but that is enough for now, I think.
I have to ask, what is the payoff of having the engine separate? Less
weight for the chute? OK, but chutes can be made bigger to handle all of
the weight. Not having the heavy engine to worry about it shifting into the
cockpit during a parachute landing? OK, but the landing should be at a
relatively low speed, and that should not be a big concern. Cirrus seems to
have a pretty big engine, and I have not heard of any engine/cockpit
interactions that were a problem.
I think if you want a challenge to work on, look for something else. The
engine needs to stay right where it was put, IMHO. Work on a chute for the
bigger, heavier plane, perhaps.
Old February 17th 06, 04:49 PM posted to rec.aviation.homebuilt
Hi Jim,
I was _mostly_ kidding about jettisoning the engine. The problem
is how to do a ballistic chute in a pusher _without_ first jettisoning
the engine. There is a problem with the chute streaming behind the
aircraft and getting into the prop! I've thought about twin chutes
deployed from pods in the wing, etc., but that has big problems if
the chutes do not deploy identically.
Jettisoning the engine _might_ be possible if you built the firewall
to attach to the airframe with some type of latching mechanism that
would unlatch with a lever. In a pusher the firewall is being pushed
into the airframe by the engine instead of pulled out of it, so the
main problem would be to support the weight of the engine, and provide
counter torque for the rotation of the prop.
The problem of the fuel lines could be dealt with by quick disconnects
similar to the ones now required in most states at gas stations. When
they pop apart, spring loaded balls stop the flow of fuel on both sides
of the disconnects. You could have a latch which holds them
together until your "jettison" lever is pulled.
The problems left are the control cables: Throttle, Mixture, and Prop.
It _might_ be possible to build an intermediate box which would transfer
force from one set of cables to a secondary set. The cables from the
cockpit controls would run to the box, and a second set of cables would
run from the box to the engine. The box would be designed to pull apart
during engine jettison.
The only thing left that I can think of is the heater hose for cabin
heat. An intermediate box with the hose for the engine on one side
and a hose to the cabin on the other should take care of that.
Have I left anything out? ;-)
Oh yeah. The cowl is attached to the firewall portion that
seperates from the aircraft, so it goes with the engine. Four
small air cylinders and a 10 cubic foot scuba pony bottle
with compressed air at 2000 PSI make sure that the firewall
seperates cleanly from the aircraft. The two chutes (big one
for the aircraft, and smaller one for the engine/cowl/firewall)
are stored between the firewall and the rest of aircraft and
deploy when they are seperated. The whole assembly is made
such that you can remove the cowl, support the engine, and
seperate the two parts for inspection.
When you pull the lever, the compressed air blows the firewall
off the back, seperating the fuel lines, control box, and
heater box, and exposing the chutes.
Could work, and would be a lot of fun to design and test ;-)
What do you think?
Don W.
before deployment.
Welcome, Don!
larger size.
sounds like fire.
there.
Old February 17th 06, 06:06 PM posted to rec.aviation.homebuilt
t...
So - the problem is the prop, not the engine. Think along those lines.
Welcome to the feud. There are several sub-groups in this Appalachian-style
family, one or more you must join as you develop your persona. No need to
consciously decide, your postings will indicate where you fit. It could be
over there in the meadow, grazing with the "Ilk". The RAH 15 is a closed
group, but you didn't want to be with them, anyhow. You're obviously not a
serious troller - heck you even gave us a real sounding name. There's the
pro-auto and the anti-auto and the "I can't even spell Otto" adherents. The
one's I've grown fond of are the "Ploinks". I probably have a list of them
around here someplace. Their only vice is they keep changing their email
addresses so I need to repeatedly ploink them. There's Latchless and Juan,
and Ludwig and many others.
Again, welcome and come on down!
Rich "Beware the BWB, my son. . ." S.
Old February 17th 06, 06:07 PM posted to rec.aviation.homebuilt
I dunno, Don.
ESPECIALLY about the "testing" part. g
What's wrong with just shutting the engine down before pulling
the ripcord?
Richard
Old February 17th 06, 09:28 PM posted to rec.aviation.homebuilt
Hi Richard,
Richard Lamb wrote:
I dunno, Don.
the ripcord?
Windmilling? Now if you had a full feathering prop, and the time
to wind it down it might work. There is still a chance of getting
the lines tangled in the prop even if it isn't rotating.
Don W.
Old February 17th 06, 10:14 PM posted to rec.aviation.homebuilt
om...
Hi Richard,
Richard Lamb wrote:
I dunno, Don.
the ripcord?
Don W.
If you are going to go to the trouble of figuring out a way to eject the
engine I'd think you could come up with a prop brake to stop the thing.
While I'm not a fan of chutes and would hardly redesign an already well
designed plane to install one aren't there ULs in the pusher configuration
that have them installed?
Old February 17th 06, 06:11 PM posted to rec.aviation.homebuilt
t...
Don...........
I forgot one of the biggest groups - the bottom feede. . . er . . . posters.
Don't **** them off. they eat top posters like a Pratt & Whitney eats
hi-test. It looks as if you may be a top poster, hence this warning. Govern
yourself accordianly.
Rich S.
Old February 17th 06, 07:52 PM posted to rec.aviation.homebuilt
("Rich S." wrote)
posters. Don't **** them off. they eat top posters like a Pratt & Whitney
eats hi-test. It looks as if you may be a top poster, hence this warning.
Govern yourself accordianly.
"June" is official Top Posting Month at rec.aviation.
Montblack (-10 F at noon. Brrrr!)
Lotsa ships are kept at anchor
Jest because the captains hanker
Fer the comfort they ken only get in port!
With the little tail a-swishing'
Ev'ry lady fish is wishin'
That a male would come
And grab 'er by the gills!
All the rams that chase ewe-sheep
All determined there'll be new sheep
and the ewe-sheep aren't even keepin' score!
Just because it's June, June, June!
......sorry, cabin fever. Brrrrrr!
Introduction to AMU spending Jack Allison Owning 12 May 3rd 05 01:06 PM
Introduction to a newbie Shane O Aerobatics 9 December 31st 04 06:13 AM
request for introduction GARY WAINWRIGHT Home Built 1 March 4th 04 01:11 AM
Vietnam era F-4s Q Ed Rasimus Military Aviation 87 September 27th 03 03:59 PM
My introduction and 4 seater kits LFOD76 Home Built 18 July 25th 03 09:36 AM
