#51
Roy Smith wrote:
Skywise wrote: I've been seriously thinking of getting an account [on Wikipedia] so I can make changes as I see the need. In about the same amount of time it took you to write that sentence, you could have made your account. Just got to http://tinyurl.com/6fvtg, type in a user name and a password, and you're done. Wikipedia and usenet are similar in many ways. On both, there are experts and idiots and everything in between. The difference is that on Wikipedia, articles have a decent chance of evolving towards containing better and more correct information. On usenet, the same crap just gets recycled. What causes it to evolve towards more accuracy? I haven't used it, but I thought most anyone could add to or change the definitions contained therein. Is this not how it works? Is there some sort of review and approval process? Matt |
#52
Jim Macklin wrote:
Unless the wing is producing lift, there is no rotation to reduce the angle of attack. If the wing was really stalled, the airplane would fall flat, if it was spinning it would be a flat spin, but if was fully stalled, it would be a deep stall and would not rotate the nose down and it would stay in the stall. The lift from the wing doesn't go to zero during a stall. Under normal conditions, neither the wing or the tail fully stalls. Stall strips, wing twist or air foil changes along the span keep the wing from reaching the critical angle of attack at one moment in time. Also the tailplane is usually a different airfoil and more heavily loaded and is designed to begin shedding lift [down-force] before the wing. The CG range is set so that a certified airplane will have that stable pattern. I'm now really curious to hear your definition of what stall means. The weight of the airplane does not cause the stall break rotation, it is the lift moment. If it was not for the wing lift, the airplane's mass as concentrated on the CG would simply fall as a unit in the same attitude as it was in at the moment. No it won't because there is still some lift from the wing, however, it is now less than the weight of the airplane so the imbalance in forces causes the airplane to both descend and rotate. It would only fall downward in a flat attitude of the lift (and drag) of the wing and tail and fuselage went either completely to zero or remained perfectly equal forward and rearward of the CG. If the center of pressure was located at the same location as the CG, there would be no moment or force to cause rotation. Sure, there is still the force from the tail. Are you really a CFI and ATP as your .sig advertises? Matt |
#53
T o d d P a t t i s t wrote:
"Jim Macklin" wrote: Unless the wing is producing lift, there is no rotation to reduce the angle of attack. If you simply drop an aircraft flat, it will rotate nose down. The wing is fully stalled (AOA=90) and the CP is well behind the CG producing the rotation. When the main wing stalls, lift is reduced and the same thing happens. If the wing was really stalled, the airplane would fall flat, Why do you think so? A stalled wing is still producing lift, and unless the CP and CG are aligned the plane will rotate. Planes are designed to rotate nose down in this situation. And it still produces drag in any event. It doesn't matter if the force applied is due to lift or drag, it will still cause a rotation about the CG if the forces are unbalanced. Matt |
#54
#55
"Matt Whiting" wrote in message
... Jim Macklin wrote: If the center of pressure was located at the same location as the CG, there would be no moment or force to cause rotation. Sure, there is still the force from the tail. No, Jim is right if he's referring here to the plane's CP (not just the wings' CP). --Gary |
#56
... T o d d P a t t i s t wrote: A stalled wing is still producing lift, and unless the CP and CG are aligned the plane will rotate. Planes are designed to rotate nose down in this situation. And it still produces drag in any event. It doesn't matter if the force applied is due to lift or drag, it will still cause a rotation about the CG if the forces are unbalanced. No, not necessarily. Even if the forces are unbalanced (which just means there's nonzero acceleration), there's still no rotation if the plane's CP coincides with its CG (as Jim pointed out). Moreover, at least for a high-wing plane, rotation caused by drag upon the wing would be nose-up rotation, not nose-down, and thus would not account for the nose-down pitch at the stall onset, which is what's under discussion. --Gary |
#57
Gary Drescher wrote:
"Matt Whiting" wrote in message ... Jim Macklin wrote: If the center of pressure was located at the same location as the CG, there would be no moment or force to cause rotation. Sure, there is still the force from the tail. No, Jim is right if he's referring here to the plane's CP (not just the wings' CP). True, and the odds of that happening are infinitesimal. Matt |
#58
... Gary Drescher wrote: "Matt Whiting" wrote in message ... Jim Macklin wrote: If the center of pressure was located at the same location as the CG, there would be no moment or force to cause rotation. Sure, there is still the force from the tail. No, Jim is right if he's referring here to the plane's CP (not just the wings' CP). True, and the odds of that happening are infinitesimal. You're referring to the odds of the plane's CP and CG coinciding? There's nothing unlikely about that--it's what happens whenever the plane is *not* changing pitch. --Gary |
#59
"Matt Whiting" wrote in message ... Gary Drescher wrote: "Matt Whiting" wrote in message ... Jim Macklin wrote: If the center of pressure was located at the same location as the CG, there would be no moment or force to cause rotation. Sure, there is still the force from the tail. No, Jim is right if he's referring here to the plane's CP (not just the wings' CP). True, and the odds of that happening are infinitesimal. You're referring to the odds of the plane's CP and CG coinciding? There's nothing unlikely about that--it's what happens whenever the plane is *not* changing pitch. The topic is stalling the airplane. That isn't a steady-state situation as is straight and level and unaccelerated flight. Matt |
#60
Feel free to look me up on the FAA web. Certificated
airplanes are designed to not fully stall the wing or the tail for that matter. But within the limits of what does happen, and without discussing wash-in, wash-out, twist, airfoil section changes, control stops, stick shaker and pullers, gust loading, accelerated stalls, mushing, getting a useable idea of what happens when the controls are applied smoothly, violently or the airplane breaks apart in flight. If the nose would always go down from a stall, spin chutes would not be required. If the airplane is abused in flight, it will do some pretty remarkable things. I know a Beech test pilot who wondered about what would happen in an E90 at cruise if you put the props into reverse. The airplane did not break, but they were reported to have changed their clothes after the flight. Same pilot tried the same thing in an F90 with the T-tail and nothing really uncontrollable happened. It is possible to design a wing that will stall, 100% across the entire span, but it won't be certified for civil use. If the tail surface reaches max lift (down-force) and you try to go slower, it will begin the stall as air flow reaches the critical angle of attack on the tail PROGRESSIVELY and the nose will drop because the moment between the CP and CG will not be countered by the tail forces. Do it slowly and the nose pitches down slowly. Pull a few Gs and the reaction is faster and the degree to which the stall progresses on the tail and wing is much faster because inertia will carry the aircraft past the critical angles at a higher kinetic energy level. -- James H. Macklin ATP,CFI,A&P "Matt Whiting" wrote in message ... | Jim Macklin wrote: | | Unless the wing is producing lift, there is no rotation to | reduce the angle of attack. If the wing was really stalled, | the airplane would fall flat, if it was spinning it would be | a flat spin, but if was fully stalled, it would be a deep | stall and would not rotate the nose down and it would stay | in the stall. | | The lift from the wing doesn't go to zero during a stall. | | | Under normal conditions, neither the wing or the tail fully | stalls. Stall strips, wing twist or air foil changes along | the span keep the wing from reaching the critical angle of | attack at one moment in time. Also the tailplane is usually | a different airfoil and more heavily loaded and is designed | to begin shedding lift [down-force] before the wing. The CG | range is set so that a certified airplane will have that | stable pattern. | | I'm now really curious to hear your definition of what stall means. | | | The weight of the airplane does not cause the stall break | rotation, it is the lift moment. If it was not for the wing | lift, the airplane's mass as concentrated on the CG would | simply fall as a unit in the same attitude as it was in at | the moment. | | No it won't because there is still some lift from the wing, however, it | is now less than the weight of the airplane so the imbalance in forces | causes the airplane to both descend and rotate. It would only fall | downward in a flat attitude of the lift (and drag) of the wing and tail | and fuselage went either completely to zero or remained perfectly equal | forward and rearward of the CG. | | | | If the center of pressure was located at the same location | as the CG, there would be no moment or force to cause | rotation. | | Sure, there is still the force from the tail. | | Are you really a CFI and ATP as your .sig advertises? | | Matt |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 06:23 PM |
| Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 05:05 AM |
| military men "dumb, stupid animals to be used" Kissinger | B2431 | Military Aviation | 3 | April 26th 04 06:46 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
