#51
William Hung wrote:
Do small planes have parking brakes? I don't remember having ever seen one that I could set the brakes. Most do. The parking brake designs on early model 172s and 150/152s were known for sticking in the "on" position. As such, many instructors would either tell students not to use it, or not bother even telling the student there was one (it was an inconspicuous knob on the lower panel). The procedure for unsticking the brake involved several people pushing and pulling on the plane until it freed up. John Galban=====N4BQ (PA28-180) -- Message posted via http://www.aviationkb.com |
#52
William Hung wrote:
On Dec 29, 11:57 am, Matt Whiting wrote: JGalban via AviationKB.com wrote: RST Engineering wrote: No chocks, only tiedowns could have kept that aircraft from moving. Chocks aren't perfect. At my home field we often get violent downbursts from thunderstorms in the summer. Peak gusts of 60-70 kts aren't unusual. I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. Yes, chocks are temporary restraints and no better on ice than are the tires and brakes. Tie downs are the only way to go for permanent restraint (other than a hangar!). Matt Do small planes have parking brakes? I don't remember having ever seen one that I could set the brakes. I can't speak for all small airplanes, but the Cessnas from the 150 through the 182 all have parking brakes as does the Piper Cherokee family from the 160 through the Arrow. Matt |
#53
On Dec 27 2007, 6:03 pm, Andy Hawkins wrote:
In article , Robert M. wrote: On Dec 27, 3:18 pm, "Bob Gardner" wrote: Chocks, Robert, chocks. Use your dictionary. How do you know I don't use chalks? I doubt they'd do much to stop a plane moving.... Andy Chalks are for outlining the airplane during the investigation. |
#54
#55
Hi,
In article , William wrote: Do small planes have parking brakes? I don't remember having ever seen one that I could set the brakes. The Warriors I've flew (and the Cherokee I haven't) all have parking brakes. Andy |
#56
On Jan 2, 4:14 am, Marty Shapiro
wrote: I thought chalks were used on the end of the cue so you could get money to pay for flying. :-) That'll work for you, if you're playing against me ;( |
#57
On Dec 31 2007, 1:20*pm, William Hung wrote:
On Dec 29, 11:57*am, Matt Whiting wrote: JGalban via AviationKB.com wrote: RST Engineering wrote: No chocks, only tiedowns could have kept that aircraft from moving. * Chocks aren't perfect. * At my home field we often get violent downbursts from thunderstorms in the summer. *Peak gusts of 60-70 kts aren't unusual. *I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. Yes, chocks are temporary restraints and no better on ice than are the tires and brakes. *Tie downs are the only way to go for permanent restraint (other than a hangar!). Matt Do small planes have parking brakes? *I don't remember having ever seen one that I could set the brakes. Wil Thank you Bertie, Barry, John Matt and Andy for your replies. I've only flown in C150/2s and yes, my CFI hasn't pointed them out to me yet. Wil |
#58
William Hung wrote:
On Dec 31 2007, 1:20 pm, William Hung wrote: Do small planes have parking brakes? I don't remember having ever seen one that I could set the brakes. Wil Thank you Bertie, Barry, John Matt and Andy for your replies. I've only flown in C150/2s and yes, my CFI hasn't pointed them out to me yet. Hasn't s/he introduced you to checklists yet? I'd expect them to be on a decent checklist. (I've flown a 150 or 152 - too tall - so I don't know for a fact they'd be there, but it's hard to believe not.) |
#59
William Hung wrote in
: On Dec 31 2007, 1:20*pm, William Hung wrote: On Dec 29, 11:57*am, Matt Whiting wrote: JGalban via AviationKB.com wrote: RST Engineering wrote: No chocks, only tiedowns could have kept that aircraft from moving. * Chocks aren't perfect. * At my home field we often get violent d ownbursts from thunderstorms in the summer. *Peak gusts of 60-70 kts aren't un usual. *I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. Yes, chocks are temporary restraints and no better on ice than are the tires and brakes. *Tie downs are the only way to go for permanent restraint (other than a hangar!). Matt Do small planes have parking brakes? *I don't remember having ever seen one that I could set the brakes. Wil Thank you Bertie, Barry, John Matt and Andy for your replies. I've only flown in C150/2s and yes, my CFI hasn't pointed them out to me yet. Little handle down below somewhere. You push the toe brakes then pull the handle and a small chatter strip grabs the the piston rod and holds them on. They're not the easiest things to set or the most reliable. Bertie |
#60
William Hung wrote:
On Dec 31 2007, 1:20 pm, William Hung wrote: On Dec 29, 11:57 am, Matt Whiting wrote: JGalban via AviationKB.com wrote: RST Engineering wrote: No chocks, only tiedowns could have kept that aircraft from moving. Chocks aren't perfect. At my home field we often get violent downbursts from thunderstorms in the summer. Peak gusts of 60-70 kts aren't unusual. I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. Yes, chocks are temporary restraints and no better on ice than are the tires and brakes. Tie downs are the only way to go for permanent restraint (other than a hangar!). Matt Do small planes have parking brakes? I don't remember having ever seen one that I could set the brakes. Wil Thank you Bertie, Barry, John Matt and Andy for your replies. I've only flown in C150/2s and yes, my CFI hasn't pointed them out to me yet. Wil He probably isn't aware of the parking brake either! :-) Matt |
| Thread Tools | |
| Display Modes | |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Instrument Flight Rules | 1 | December 1st 07 06:05 AM |
| Proof FAA Managers are full blown certified IDIOTS | SOS | Piloting | 1 | November 29th 07 08:44 PM |
| Ramp riders 5 | Paul | Aviation Photos | 0 | November 19th 06 11:09 PM |
| MMU ramp fee | Peter Gottlieb | Piloting | 25 | August 9th 03 01:49 AM |
| Flight TWA 800 was shot down/blown up by Al Quadea? | Tiger | Military Aviation | 0 | July 3rd 03 06:38 PM |
