Building an electronic Angle of Attack indicator
Old May 11th 09, 09:15 PM posted to rec.aviation.homebuilt
Frank Stutzman[_3_]
Default Building an electronic Angle of Attack indicator
jan olieslagers wrote:
who cares? schreef:
I would like to see a vain mounted on each wingtip
Great idea, yes. Any preference of vains in the glossy magazines?
For myself I'd much like Madonna and Prince - if they are more or less
balanced.
(or could it be you meant a couple of vanes? That's a whole another
story...)
Could be worse. He could have said 'veins' ;-)
Frank Stutzman
Bonanza N494B "Hula Girl"
Boise, ID
  #52
Old May 11th 09, 09:38 PM posted to rec.aviation.homebuilt
Dan[_12_]
balanced.
story...)
Vain vanes, something in that vein?
Dan, U.S. Air Force, retired
  #53
Old May 11th 09, 10:59 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"rich" wrote
Well of course, the best is to use an AOA vane, like the jets use. The
biggest problem is where the jets conveniently mount it on the side of
the fuselage, on most singles, that's right in the prop blast,
rendering it useless. If you could find someplace to mount it outside
of the prop blast, then it would work great. But finding that
place......
On a mast like a pitot tube, out on the wing.
I propose 4 or 5 microswitches with a mechanical linkage to go from the vane
to the switches in the wing. Send the signal to some led's, and you are
done. Cheap and easy.
  #54
Old May 11th 09, 11:08 PM posted to rec.aviation.homebuilt
Dan[_12_]
place......
That should be fun to calibrate, but once everything is secured it
should be reliable.
  #55
Old May 12th 09, 05:44 AM posted to rec.aviation.homebuilt
Brian Whatcott
There is one central location that is not subject to prop blast,
exactly: - that's the nose cone of the prop.
Visualize a small hole set about an inch back from the front.
Use a local pressure sensor chip and a wireless transmitter.
The flow from off axis would module the air pressure slightly
one cycle per revolution, with amplitude in proportion to
AofA (maybe :-)
Brian W
place......
  #56
Old May 12th 09, 08:14 AM posted to rec.aviation.homebuilt
Ed
On Mon, 11 May 2009 22:44:23 -0500, Brian Whatcott
AofA (maybe :-)
Brian W
The wiring might be a little tricky
  #57
Old May 12th 09, 12:10 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"Brian Whatcott" wrote in message
news
AofA (maybe :-)
Yeah, that sounds eaaaaasssy, and cheeeep, too!
NoT ! ! ! ;-)
  #58
Old May 12th 09, 01:57 PM posted to rec.aviation.homebuilt
Brian Whatcott
AofA (maybe :-)
Brian W
A wireless chip to a fixed receiver chip is not a biggie. But getting
that sensor chip and transmitter chip inside the nose cone in dynamic
balance would be an issue, I reckon....
Brian W
  #59
Old May 12th 09, 02:00 PM posted to rec.aviation.homebuilt
Brian Whatcott
news
AofA (maybe :-)
NoT ! ! ! ;-)
I'm the one who likes the mouth organ reed, tube and wing slot approach
- but Experimental class is dedicated to folks who don't take the cheap,
easy approach!
Brian W
  #60
Old May 12th 09, 04:06 PM posted to rec.aviation.homebuilt
RST Engineering - JIm
It is not a biggie if price is no concern. However, if you are trying to
bring it to market it is cost prohibitive.
A wireless chip to a fixed receiver chip is not a biggie. But getting that
sensor chip and transmitter chip inside the nose cone in dynamic balance
Brian W
Prop angle of attack vs age sid Piloting 47 July 13th 08 05:46 PM
Glider angle of attack indicator by SafeFlight Bill Daniels Soaring 53 December 20th 07 01:29 PM
Angle of attack Bill Daniels Soaring 27 December 19th 07 07:17 AM
preferrred bank angle indicator? Matt Herron Jr. Soaring 34 July 10th 06 03:22 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 11:55 PM
