![]() "Ray" wrote in message ... Okay, so all kidding aside, what are the issues between high and low wings? I know that in terms of flying, there are very few differences between your average Cessna and Piper, but for higher performance aircraft, what are the aerodynamic/design tradeoffs? For example: Why are most of the more expensive private aircraft (cirrus, pilatus, pretty much all multi engine and jet) low wings? In high-performance aircraft a low wing makes a convenient place to stow the landing gear and also makes engine inspection easier. But there are high-performance aircraft with high wings; Mitsubishi MU-2, Extra 400, Cessna 210, etc. Why do all fighters since the biplane era have low wings? Ever heard of the McDonnell F-15? Why do most military transports (C-130, C-17, C-5) have high wings, It allows the fuselage to be closer to the ground for easier loading/unloading. but all airliners have low wings? BAe 146, ATR 72, Dornier 328, etc. Why are a lot of cold weather/high altitude planes high wing? Aerodynamic superiority. |
![]() Why do all fighters since the biplane era have low wings? Ever heard of the McDonnell F-15? Okay, when I said all I really meant to say most, or a lot. What I was thinking about in particular were the WWII fighters. I can't think of any propeller driven fighter with a high wing. Your comment about low wings being easier for landing gear makes a lot of sense, many of those aircraft stowed their gear in the wings, but I wonder if there were any other reasons. The first jet fighters were also mostly low wing (f-80, f-86, f-100, mig-15, mig-19, etc). Only the latest generation of fighters (f-15, f-14, f-22, etc) are predominately high wing. Why do most military transports (C-130, C-17, C-5) have high wings, It allows the fuselage to be closer to the ground for easier loading/unloading. This makes sense. But going back to WWII again, why were the early transport aircraft (like the C-47) low wing? but all airliners have low wings? BAe 146, ATR 72, Dornier 328, etc. Again I meant most instead of all, and I was referring to the larger airliners (200+ seats). Basically, if all other things were equal, why wouldn't they have made the 747 high winged, since some 747s are used for cargo? Why are a lot of cold weather/high altitude planes high wing? Aerodynamic superiority. To clarify here, by high altitude I meant planes that are designed to take off and land at high altitudes - the pilatus pc-6 for example. |
![]() "Ray" wrote in message ... Okay, when I said all I really meant to say most, or a lot. What I was thinking about in particular were the WWII fighters. I can't think of any propeller driven fighter with a high wing. Morane-Saulnier L, Bristol M. 1C, Fokker D VIII, Wibault 72 C 1, Loire-Gourdou-Leseurre LGL 32 C 1, Dewoitine D 27, Morane-Saulnier MS 225 C 1, Loire 46 C 1, Nakajima Army Type 91, Focke Wulf Fw. 56 A-1, PZL P.7, were all propeller driven fighters with a high wings. This makes sense. But going back to WWII again, why were the early transport aircraft (like the C-47) low wing? Cargo aircraft of that era were not built for the purpose but adapted from civil airliners. Again I meant most instead of all, and I was referring to the larger airliners (200+ seats). Basically, if all other things were equal, why wouldn't they have made the 747 high winged, since some 747s are used for cargo? Used for cargo but designed for people. A low wing tends to be preferred for people carriers for several reasons. Using a low wing gives the passengers a better view, a high wing would have them looking at the engines and unserside of the wings. The lower portions of the fuselage aren't going to be used for the passenger deck anyway so it's a good place to put the wing carry through structure, and the wing-fuselage junction makes a good place to put the landing gear. A high wing would require the bulbous appendages you see on the C-17 to stow the gear or giving up baggage/cargo space. |
Neither the F-15 nor the F-14 are "high wing" aircraft. Most of the fuselage, and all of the cockpit, are above the wing. I suppose you could call them "mid-wings," if you wanted to split hairs, but in my opinion if you step out of the cockpit ON TO the wing, it's a "low wing" aircraft. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message news:KCpnc.11372$536.2196107@attbi_s03... Neither the F-15 nor the F-14 are "high wing" aircraft. Of course they are, don't be ridiculous. |
![]() "Jay Honeck" wrote in message news:KCpnc.11372$536.2196107@attbi_s03... Ever heard of the McDonnell F-15? Neither the F-15 nor the F-14 are "high wing" aircraft. Most of the fuselage, and all of the cockpit, are above the wing. Almost none of the fuselage is above the wing. |
Ray wrote:
Okay, so all kidding aside, what are the issues between high and low wings? I know that in terms of flying, there are very few differences between your average Cessna and Piper, but for higher performance aircraft, what are the aerodynamic/design tradeoffs? OK, if you want a serious answer rather than a punch line, here goes. Typically, high-wing planes have struts bracking the wings, and those add extra drag (some high wings, like the Cessna Cardinal, manage to avoid struts) -- that drag can become very significant at higher speeds. On the other hand, low-wing planes that want a lot of roll damping (such as trainers) have to use a higher dihedral angle than high-wing planes, and that also adds drag. If you want to build a high-performance, highly-responsive plane (i.e. very little roll damping), a low wing is probably the best choice, but I'm not an engineer or a scientist, so others may step in to correct me. High-wing planes are far better for bush work. The wings are less likely to hit bushes, shrubs, fenceposts, and so on, and on floats, the high wings will easily clear the dock. I'm happy to take my low-wing Piper Warrior onto a well-maintained grass strip, but I won't land on a farmer's field outside of an emergency. Of course, I wouldn't land a high-wing nosewheel plane like a 172 or 182 on a farmer's field either -- high-wing or low-wing, with a nosewheel you're only one gopher hole away from a prop strike and engine teardown. Serious bush types around here (central Canada) normally fly high-wing *tailwheel* planes like the Super Cub, C-180, C-182, DHC-2 (Beaver), etc. You can land and taxi those almost anywhere. High-wing pilots also worry less about hitting a snowbank with a wingtip during the winter -- that might be an advantage if you fly in snow country. Low-wing planes are better for crosswind landings and taxiing, because the wheels are considerably further apart than they can be on a high-wing single. If you're flying mainly to paved airports or well-maintained grass strips, that can be a measurable advantage. Others have already mentioned visibility issues. High-wing planes give a better view of the ground for backseat passengers, but low-wing planes give the pilot better visibility of conflicting traffic in a turn. As a related point, I have one daughter who gets motion sick easily, so I appreciate not having to lift my inside wing to check for traffic before turning, the way I would have to in a high wing. In a low-wing plane you can see the top of the wing, which is where the ice can accumulate if you stumble into icing conditions -- that can be a comfort if you fly IFR, but it's not a big deal. High-wing planes can have a "both" position on the fuel selector, which simplifies fuel management. Low-wing planes need to use pumps rather than gravity, so they cannot have a "both" postition, and you have to manage the fuel more actively: I'd guess that fuel-exhaustion accidents are more common in low-wing planes (especially with renters who usually fly high-wing and never touch the fuel selector), but I don't have the stats in front of me. You can probably extrapolate the answers to these questions from what I've written above: Why are most of the more expensive private aircraft (cirrus, pilatus, pretty much all multi engine and jet) low wings? Why do all fighters since the biplane era have low wings? Why do most military transports (C-130, C-17, C-5) have high wings, but all airliners have low wings? Why are a lot of cold weather/high altitude planes high wing? If you're doing most of your flying to proper airports (pavement or well-maintained grass strips), just pick the plane you like best and don't worry about the high-wing/low-wing thing. If you're going to do serious bush work, fly a high-wing taildragger. All the best, David |
"David Megginson" wrote in message
.rogers.com... High-wing planes can have a "both" position on the fuel selector, which simplifies fuel management. Low-wing planes need to use pumps rather than gravity, so they cannot have a "both" postition Why not? Mine has one. Paul Scottish Aviation Bulldog G-DOGG |
![]() "Ray" wrote in message ... Okay, so all kidding aside, what are the issues between high and low wings? I know that in terms of flying, there are very few differences between your average Cessna and Piper, but for higher performance aircraft, what are the aerodynamic/design tradeoffs? For example: Why are most of the more expensive private aircraft (cirrus, pilatus, pretty much all multi engine and jet) low wings? Good thing you said "pretty much", since I co-pilot a Jetprop (Twin Commander) which is a high wing. :~) |
![]() Ray wrote: Why do all fighters since the biplane era have low wings? Because attackers will probably be approaching from either the same level or above - it's difficult to make an effective attack from below. It's also important to be able to see in the direction of a turn when you turn in to attack an opponent. And not all fighters are/were low-winged; many were mid-winged aircraft. Why do most military transports (C-130, C-17, C-5) have high wings, but all airliners have low wings? The wing spars have to pass through the fuselage. With a low-wing, that means a hump in the floor. With a high-wing, that means a lwo ceiling at that point. Planes that carry cargo would rather have a flat floor to ease loading. People, on the other hand, will step over a hump in the floor and bang their heads on a drop in the ceiling. Why are a lot of cold weather/high altitude planes high wing? Dunno about "cold weather" planes, but the high-altitude aircraft which come to my mind are mid-wing aircraft; the U-2 and SR-71. George Patterson If you don't tell lies, you never have to remember what you said. |
High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 11:10 AM |
High wing vs low wing | temp | Owning | 11 | June 10th 04 02:36 AM |
High Wing or Low Wing | Bob Babcock | Home Built | 17 | January 23rd 04 01:34 AM |
End of High wing low wing search for me | dan | Home Built | 7 | January 11th 04 10:57 AM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
