Yesterday I had an acro lesson scheduled, but since the ceilings were
too low we decided to do some pattern work instead since I'm also working on the TW endorsement. The grass field at the airport had some soft spots from the rain this weekend, so the plan was to fly over to Queens City Airport, just outside of Allentown, PA. While I have managed to make some good three point landings on the grass, the majority of my eight or so hours in the Super Decathlon has been devoted to acro, with pattern work making up only a small percentage of my time up to this point. Although I knew the winds were 310 with gusts between 20-24 kts, when we departed from Rwy 25 I was still surprised at how quickly the wind was pushing me off centerline. I corrected, but as we had been warned by a glider pilot a few minutes earlier, the ten minute trip over was extremely bumpy and likely made worse by the numerous ridges in the area. After arriving I overflew the field to verify the most appropriate runway, which was Rwy 33. My instructor informed me that the pattern is particularly tight, with one reason being that there is a ridge on the approach end of Rwy 33. I flew out and made the 45 to the downwind while getting knocked around the entire time. On the first pattern I found myself rushed and not able to get properly set-up. I knew that I was too fast on final and while I flared at about the right time, I allowed my attitude to fall somewhere between that required for a wheel landing and a three point. Combining those two factors caused me to bounce more times than I care to remember, so I decided to go around. What became readily apparent to me is that while one can get away with excess speed on the grass, the margin for error on the hard top. One the next trip around the pattern I think I was more relaxed and was able to not only get my prop and throttle setting nailed, but I managed to get my speed closer to where it should be. This approach was far more stable with a good flare, but again my attitude was a hybrid between a wheel and three point. I think part of the problem was that I wasn't keeping the stick far enough back for a good three point attitude. My instructor commented that if I had just given it a little more forward pressure it would have been a good wheel landing, although that's not what I was trying to do. We did one more trip around the pattern before heading back and that was probably the worst of the three. Back at Van Sant we had about a 60 degree crosswind, but I managed to keep the upwind wing down. Fortunately, the grass allows more mistakes to be forgiven than on asphalt. I think my biggest problem happens to be speed control. While I'm comfortable with no flap landings in a 172, I think the higher speed on downwind in the SD makes it harder to bleed off speed for the approach. I'm 23 squared on downwind then once abeam the numbers I bring the MP to 15" and prop full forward. At that point my airspeed is about 120 mph. My instructor mentioned that he often keeps cruise speed on downwind until abeam. I've done enough spins and stalls in the SD to know that with throttle to idle it still takes some work getting the airspeed down. Because I don't want to make my pattern too wide I'm reluctant to spend too much time bleeding off airspeed before completing the pattern. But I think that if I can get my airspeed control nailed consistently I can really get a handle on this. When my airspeed is on point my landings are pretty good, but it's a matter of nailing the airspeed more often. Doing this in a 172 is almost a no brainer. Perhaps I should let the instructor demonstrate a few landings for me. It was humbling experience and I felt like I was a new student pilot all over again. I think my feet are still tired from all the dancing I had to do. Dave |
| Thread Tools | |
| Display Modes | |
| Tailwheel ID | R. Mueller | Aviation Marketplace | 2 | February 5th 08 11:25 PM |
| Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 03:42 AM | |
| Tailwheel question | Steve B | Aerobatics | 4 | January 30th 04 04:35 AM |
| Advice on flying Pitts with Haigh Locking Tailwheel | Ditch | Home Built | 19 | January 4th 04 11:18 PM |
| Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 02:48 PM |
