Mustang Collision Oshkosh
Old July 31st 07, 04:19 PM posted to rec.aviation.piloting
Peter Dohm
Default Mustang Collision Oshkosh
"Big John" wrote in message
Mx
Thank you. After this reply your gone. Please do me the same and put
me in your killfile.
Big John
Your solution is probably the best use of time and effort. However, this is
still the same "troll of the troll" and imposter--he simply corrected the
"organization" line in his header.
Peter
  #62
Old August 2nd 07, 01:32 AM posted to rec.aviation.piloting,rec.aviation.military,or.politics
Blueskies
"Dudley Henriques" wrote in message ...
With nose wheel airplanes, stacked laterally at co-speed through the landing with no stack down for the trailer on
final I never had a problem with section landings. Of course there was always the ever present potential for a tire
blowout on the lead at touchdown. (hopefully the tire away from me :-)
Never did section landings in prop fighters and never recommended them either. Bad juju, especially in Mustangs. Much
better to have at least several thousand feet between touchdowns in these airplanes.
Dudley Henriques
The latest pictures to crop up do seem to show that they were not planning a section landing...
  #63
Old August 2nd 07, 01:56 AM posted to rec.aviation.piloting,rec.aviation.military,or.politics
Dudley Henriques[_2_]
Dudley Henriques
I wouldn't go by the pictures. They tell a lot, but wouldn't indicate
that assumption to me at all.
The ATC or the tape from the com trailer will tell that story. My gut
tells me that Gerry Beck was WAY to good a stick to have been that close
in on the D unless he wanted to be that close in with the D on final,
but as with all speculation, I could be way off base.
I do know there would be no way in hell that I would have been that
close on final behind the D unless I had planned to be that close. There
is just way too much time through an approach like this one was to make
any spacing adjustments necessary to maintain nose to tail separation.
Again, my gut tells me that if Beck wanted to space wider longitudinally
he could have done that easily.
It's all a guessing game at this point, even for me. Having flown these
airplanes myself, I naturally have gut feelings about what Beck was
seeing at different points during his approach, but I can't be certain
what was planned and what wasn't.
I can say with some degree of certainty that I would be absolutely
amazed to find out that Gerry Beck allowed his airplane to close on the
D the way it did had he been planning a normally spaced approach and
landing. I just think he was too good to have allowed that to happen.
Something obviously went terribly wrong with whatever it was that was
happening.
I learned a long time ago that what seems obvious initially in a crash
like this one sometimes turns out to be way off base.
Dudley Henriques
  #64
Old August 2nd 07, 04:29 AM posted to rec.aviation.piloting,rec.aviation.military,or.politics
Ron Lee[_2_]
happening.
Yes. The second pilot screwed up royally. Of course we can wait a
year for the NTSB to come to that conclusion.
Ron Lee
  #65
Old August 2nd 07, 05:01 AM posted to rec.aviation.piloting
Paul Dow (Remove CAPS in address)
Default I was there, was Mustang Collision Oshkosh
I was down there too near taxiway P5. I was taking pictures of the race,
but it appears I don't know how to work the shutter speed priority of
the camera. I got a lot of white .jpg files in between real photos and
video clips.
It looked to me like there was no evasive maneuvering before the impact.
As I saw them coming in, I was thinking they were close, but there must
be enough left-to-right spacing. I was wrong. I still can't figure out
why they were oriented with the front plane landing first. I think Jerry
may have lost sight of the front plane. When the plane flipped over it
hit quite hard, so it looked bad right from the beginning.
Paul
Tater wrote:
I was at the ultralight barn looking over my new student sport pilot
liscence at about 3pm waiting for the big warbird show that day.
I didnt get to see the very first part of the crash, nor have i looked
for any videos or pictures(yet, on dialup) but i'll give some
firsthand comments.
  #66
Old August 2nd 07, 05:04 AM posted to rec.aviation.piloting,rec.aviation.military,or.politics
happening.
Ron Lee
The fact that someone screwed up or didn't screw up isn't what takes all
the time to figure out in an aircraft accident. That part of it,
especially in an accident like this one, is usually solved fairly
quickly. To be quite frank, I'd be surprised to discover that the NTSB
didn't have the answer to this one as we speak.
What takes a bit of time is going into the P51 and warbird demonstration
communities and implementing the changes, education, and re-education
necessary to increase safety awareness generally.
The easy part can be the discovery that somebody made a mistake, or
"screwed up". The hard part is discovering WHY that someone made that
mistake or "screwed up", then finding a way to help prevent it from
happening again.
It's the WHY that takes the year; at least this has been my experience
dealing with aviation accidents, flight safety, and prevention.
Dudley Henriques
  #67
Old August 2nd 07, 09:04 PM posted to rec.aviation.piloting,rec.aviation.military,or.politics
Gattman[_2_]
I can say with some degree of certainty that I would be absolutely amazed
to find out that Gerry Beck allowed his airplane to close on the D the
way it did had he been planning a normally spaced approach and landing. I
just think he was too good to have allowed that to happen. Something
obviously went terribly wrong with whatever it was that was happening.
Question: If they were active military aircraft they would more likely have
same powerplants, same construction, same mechanics and maintenance policies
and all the things that would make them behave similarly at identical pitch
and power settings. Is this correct?
If so, is it possible that since the two aircraft were manufactured and
maintained separately, there could have been subtle performance variations
that made it more possible for the rear plane to overtake the other when the
approach configuration is the same? There's a pretty big difference
between a scratch-built A model and a D (that's already crashed once) is
there not?
-c
  #68
Old August 2nd 07, 10:44 PM posted to rec.aviation.piloting,rec.aviation.military,or.politics
Not exactly. The A has an Allison V1710 power plant and the D had a
Merlin V1650-7. This shouldn't have been a factor in this accident
anyway. The A, because of the canopy construction, in my opinion anyway,
would have a lower visual cue factor on approach than the D and this in
my opinion could have been a relative factor.
there not?
-c
Not knowing exactly what was done to either airplane prior to the
accident I would not attempt to comment on this, but my gut feeling is
no. The factors you have stated would appear to me not to have been
relevant.
Let me add this addendum to this thread at this time please, if everyone
will bear with me and try to understand that what I'm about to say isn't
meant as a put down to anyone here.
There is a lot of idle speculation going on about this accident; much of
it by well meaning people in the General Aviation community who all
believe they have a clue, a cause, or an angle on what happened based on
this video tape or that bit of information about the P51 in general. I
myself, having some degree of experience in the Mustang have offered
some comment on the thread.
I am in contact with flight safety people in the P51 community as we
speak who are actively engaged as we speak in aiding the investigation.
Naturally the NTSB will have the final answers to the many questions
being tossed around by us here. May I respectfully suggest that because
this accident is so recent, and that as a result of this, there are
families and friends in the P51 community whose lives have been terribly
affected by this tragedy; that all of take a step back and let the NTSB
do it's job and let this thread go.
Please understand as I tried to say before, that I'm not blaming anyone.
I have posted on this subject with the rest of you.
Asking for this in the name of the P51 community at large, and thanking
those of you who understand and will attempt to comply.
Thanks gang.
Dudley Henriques
  #69
Old August 3rd 07, 12:14 AM posted to rec.aviation.piloting,rec.aviation.military,or.politics
Gattman[_2_]
The A, because of the canopy construction, in my opinion anyway, would have
a lower visual cue factor on approach than the D and this in my opinion
Fascinating. Thanks, Dudley.
May I respectfully suggest that because this accident is so recent, and
that as a result of this, there are families and friends in the P51
community whose lives have been terribly affected by this tragedy;
Hopefully, on the off-chance that any of them lurk here or come across the
discussion, they know that the people who
discuss it here understand their loss and hope they are able to overcome the
tragedy.
At the risk of sounding callous, when my time comes, I hope it's doing
something huge like flying a P-51 instead of driving to work, crossing the
street or surfing the internet.
"The P51 community at large." As far as I'm concerned, if you even make it
IN to "the P51 community" you've won the game. Thanks again for your
comments.
-c
  #70
Old August 3rd 07, 12:28 AM posted to rec.aviation.piloting,rec.aviation.military,or.politics
Immediately after I posted asking for patience and restraint on the P51
thread, I received an email from a good friend who is a P51 owner and
active in the flight safety section of the P51 community.
He sent me the information I will be posting here under a separate
header concerning the NTSB preliminary report on the accident.
He asked that I post the information for all to read.
Hopefully it will answer some of the questions.
Dudley Henriques
tragedy.
comments.
-c
Today in Oshkosh [9/9] - "09 Another Mustang (wasn't this Dazzling Donna).JPG" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 4 July 28th 07 11:09 PM
Today in Oshkosh [7/9] - "07 Reno Mustang.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 27th 07 01:49 AM
Today at Oshkosh [26/34] - "25 Eagle shadows Mustang (Heritage flight).JPG" yEnc (1/1) Just Plane Noise Aviation Photos 0 July 25th 07 04:32 AM
Post-accident photos of RV/TBM Avenger Oshkosh taxi collision Jim Logajan Piloting 39 August 28th 06 03:49 PM
Post-accident photos of RV/TBM Avenger Oshkosh taxi collision Jim Logajan Home Built 49 August 28th 06 03:49 PM
